Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
stressFemFoam results?
Old   August 4, 2009, 07:55
Default stressFemFoam results?
J H
kawuppdich is on a distinguished road
I did the tutorial stressFemFoam (plateHole) with 15dev and after that, i wanted to look at the results with paraFoam but there are no results. Do i have to type in a command in OF to calculate them after running the case?
thanks for help
kawuppdich is offline   Reply With Quote
Old   August 6, 2009, 03:33
Henrik Rusche
henrik is on a distinguished road
Dear Josef,
have you tried foamToVTK?
Henrik
henrik is offline   Reply With Quote
Old   August 6, 2009, 06:26
J H
Hi henrik,
yes i did but there are no results to choose
the only things that I can chosse are cellID and cellNormals
Old   August 22, 2011, 06:12
Default paraview can't show results from FEMfoam in a tetPointVectorField
Sebastian
sebware is on a distinguished road
Hey, i testing the stressFEMfoam tutorial too, and don't see some results in Parafoam or in the VTK version.
but i am sure, we have the results vor the U and se sigmas, i think the problem depents from the tetPointField format of the data. Normal Solvers create the data in the surfaceVectorField or the volVectorField. The streeFEMfoam create the Data in tetPointVectorField or tetPointScalarField.
So we use am method in Paraview to read that file an print the points
Have somebody an idea to solve the problem ?
Sebastian
sebware is offline   Reply With Quote
Old   June 4, 2012, 16:52
blackbirdinapie is on a distinguished road
Hi sebware
Did you manage to find a solution to this?
Thanks
Sujan
blackbirdinapie is offline   Reply With Quote
Old   October 31, 2014, 14:08
crixman's Avatar
Christian
crixman is on a distinguished road
foamToVTK seems to work on extend 3.1!
crixman is offline   Reply With Quote
Old   November 1, 2014, 11:49
Retired Super Moderator
Bruno Santos
Greetings to all!
Actually, it was the solver stressFemFoam that was updated in commit "a3b9ee8fac50db3decf0715003e3f05dcb819923" on the 10th of April 2014. You can browse the changes made online at the following locations:
Essentially, the new/updated solver loads the U file of type "tetPointVectorField" for initial field and for solving the equations, but it then operates the other field files as type "pointVectorField". This last type is supported by foamToVTK, which is why it works!
Best regards,
Bruno
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 12:33
validation of CFD results andy FLUENT 0 June 13, 2007 14:55
Problems with repeating results Lee Siemens 4 May 26, 2006 04:39
CFX cylinder or sphere benchmark results Mel CFX 1 August 8, 2005 19:47
benchmark results stefan Siemens 3 September 10, 2001 10:48
