Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Problem with sample
Old   June 10, 2009, 06:48
Default Problem with sample
xinguang cui
flying is on a distinguished road
Hey foamers:
Now I need to plot the variables in a line. And I have checked from the Forum. I know that I need to use "sample". And I try to use it in the tutorials/solidDisplacementFoam/plateHole.
It is very sad that although there is no information and there is information such as below lines, I can not find any sample data.
create time
Create mesh for time = 0
Time = 0
Time = 20
Time = 40
Time = 60
Time = 80
Time = 100
End
Moreover, I would like to know if I need to sample data through the internal field, is it enough to change
"sets
leftPatch
to
"sets
internalField
Thanks and best wishes!
flying is offline   Reply With Quote
Old   June 10, 2009, 06:53
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi
Look into
~/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/sampling/sample
where you will find a sampleDict, which shows all (I think) possible usages of the sample utility. Then choose whatever you need, and it should be working.
Best regards,
Niels
ngj is offline   Reply With Quote
Old   June 10, 2009, 06:56
xinguang cui
Thanks, I will try it. But the thing is that I have tried it in the tutorial. Does anybody also find this problem?
Old   June 10, 2009, 07:26
xinguang cui
Hey ngj!
Thanks for your advice.
Follow your advice, I have got the data.However, I could not get the "mag(U)" and mag"UMean".
Would you like to give me more advice about it?
Old   June 10, 2009, 08:08
ngj
Hi
I cannot get the magnitude either, however, you can sample the U vector and calculate the magnitude afterward, i.e.
fields
U
Or you can make a postprocessing tool, which calculates the magnitude of U over the complete computational domain, and extract the samples from this field. However, I believe the first option would be the easiest.
Best regards,
Niels
Old   June 10, 2009, 08:33
xinguang cui
Thanks Niels!
It is a good method to solve the problem. However, I would like to know whether the "sample" Uitily can sample the mag(U), or I don't know how to do it.
Have a nice day!
Old   June 10, 2009, 08:49
ngj
As said, I cannot get the tool to sample the magnitude. However sample the U-field and then use a small postprocessing tool in whatever language you prefer to convert the sampled U velocity components into the magnitude.
You could do something like the following. Put it into a small script and execute it from the case folder:
cd sets
list1=`ls`
for i in $list1
do
cd $i
list2=`ls *U*`
for j in $list2
do
cat $j | awk '{var = sqrt( $2*$2 + $3*$3 + $4*$4)} {print $1,var}' > $j.modified
done
cd ..
done
Best regargs,
Niels
Old   June 12, 2009, 10:33
xinguang cui
I am sorry that I just have time to reply it.
Just now I copy the command line you have written. I am amazed by it. I think you are very great at coding.
Although it works, it is very sorry that I even don't know much about its meaning and I also don't know how to "Put it into a small script and execute it ". I guess you used "linux" for last commands.
If you could spend some time to tell me how to add it into a script and execute it, I will be very very grateful about it.
Old   June 12, 2009, 10:59
ngj
Hi
Thanks for the kind words.
All you need is to copy the text into a text-file, let us call it "calculateUMag.sh". Then copy the file to your root directory, e.g. damBreak.
When you executed the sample utility, then type "sh calculateUMag.sh" in the command line, and it will go through all of the files in the folder "sets" and read all those containing the U velocities, e.g. line_1_U.xy and write the data to the same folder with the name line_1_U.xy.modified. Note that you cannot have more and one vector field you are sampling, as the small script I gave you might not be able to handle that.
I hope this helps.
Best regards,
Niels
Old   June 12, 2009, 11:13
xinguang cui
Thanks for your reply. It is very helpful!
Old   February 11, 2010, 09:51
xinguang cui
Hey Niels:
I hope you are fine. Now I would like to observe the flow field in one plane changing with time. I could sample the plane out, but it is pity that they are put in different folders which is related with time with the same name.
I wish they could be put in one folder and I could read them as a series of time. Then, I could observe the flow field evolution with time.
My idea is to rename the file related with time and copy them in one folder. But I have no enough knowledge about linux programming. Would you like to give me some tips about it during your busy work?
Best wishes and thanks!
Xinguang Cui
sample
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 11:33
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
