Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
wallHeatFlux with constAnIso (anisotropic material)
Old   April 1, 2015, 06:11
Default wallHeatFlux with constAnIso (anisotropic material)
hugo17 is on a distinguished road
I'm modelling solids with anisotropic heat conductivity using the chtMultiRegionSimpleFoam solver (OpenFOAM 2.3.1). I define e.g.
kappa (20 80 20);
in the thermophysicalProperties dict and the temperature field is calculated correctly. However, the wallHeatFlux utility gives wrong results because it seems to use the magnitude of kappa ((20^2+80^2+20^2)^0.5=84.9).
Does anybody have an idea what to change in wallHeatFlux in order to use the specific kappa value which is valid for each patch depending on its direction?
Best regards,
Hugo
hugo17 is offline   Reply With Quote
Old   July 5, 2019, 08:21
Marco Bernagozzi
marcoberna23 is on a distinguished road
Hi Hugo,
OpenFOAM newbie here. I'm trying to do the same thing (using the same solver in a problem where a material has anisotropic thermal conductivity).
First of all, I hope you solved your problem!
How did you define the three values in the thermophysicalProperties dict?
Thank you,
Marco
marcoberna23 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
anisotropic material in CFX R13.0 keeper CFX 23 June 1, 2017 21:54
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
