How to visualize the difference of fields btween two simulation |
September 1, 2013, 10:05 |
#21 |
Ehsan
Rep Power: 27 |
Hi Bruno,thanks
I used parallel run,now I have to reconstruct specified times?(the equivalent times in two sequential times) and then how use that command?!
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
September 1, 2013, 10:13 |
#22 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Ehsan,
Please provide more details. Best regards, Bruno
September 1, 2013, 10:30 |
#23 |
Ehsan
Rep Power: 27 |
Bruno I don't know how to use the command when the fields are decomposed in processor folders! I have been mixed up!
September 1, 2013, 10:38 |
#24 |
Bruno Santos
Rep Power: 128 |
Why don't you use the reconstructPar with the "-time" option?
And why don't you manually copy only the fields that you want to look at, form one time folder to the other?
September 1, 2013, 11:33 |
#25 |
Ehsan
Rep Power: 27 |
I thought it have to be done through -parallel option.
do you know how can get rid of those red cells and have a more smooth result? they are both in p field and subtract field.
September 1, 2013, 11:57 |
#26 |
Bruno Santos
Rep Power: 128 |
A few advices:
September 1, 2013, 12:36 |
#27 |
Ehsan
Rep Power: 27 |
may it be a characrestic of rhoCentralFoam?
its an image from near,are cells few in your opinion? I didn't grasp totally about writePrecision and its role,I have set it to 16,but these results existed when it was only 6,and I don't think time step be responsible for that because it was in lower time steps too(maxCo=.1 till maxCo=.2 that I've tried)
September 1, 2013, 13:53 |
#28 |
Bruno Santos
Rep Power: 128 |
From the looks of it and from what I can remember from this test case...
September 1, 2013, 16:25 |
#29 |
Ehsan
Rep Power: 27 |
yes you are true,they are the points that originated oblique shocks hit together and make pressure to be higher than neighbor cells.It was odd for me that had forgotten about it and ignored this problem,thank you for saving me
Overflow problem in steady simulation | ReeKo | CFX | 11 | October 8, 2008 18:57 |
Difference of temporally and spatially simulation? | leaf | Main CFD Forum | 0 | May 14, 2006 22:35 |
Unsteady vs Steady simulation - any difference? | Sally | Main CFD Forum | 16 | December 16, 2005 10:15 |
Fire simulation using FDS from NIST | Jens | Main CFD Forum | 1 | January 22, 2004 02:53 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 11:06 |
