Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Paraview gray scale from white to black
Like Tree1Likes
  • 1 Post By wyldckat
Old   August 4, 2012, 13:36
Default Paraview gray scale from white to black
Jeong Kim
enoch is on a distinguished road
I wanted to create a contour plot with the gray scale from white (lowest value) to black (highest value) in paraview.
The default gray scale is opposite to what I want.
How can I make a contour plot with white to black?
Thanks in advance for your help.
enoch is offline   Reply With Quote
Old   August 4, 2012, 16:23
Retired Super Moderator
Bruno Santos
Greetings Jeong,
Simple:
  1. You export the gray one to an XML file.
  2. Switch the values for "x" in the saved file.
  3. Import the modified file.
Here's the modified file contents:
<ColorMap name="Grayscale" space="RGB">
  <Point x="0" o="1" r="1" g="1" b="1"/>
  <Point x="1" o="0" r="0" g="0" b="0"/>
  <NaN r="1" g="0" b="0"/>
</ColorMap>
I also swapped the lines of the two "Point" elements.
You can also change the "name" of the "ColorMap".
Best regards,
Bruno
Old   August 4, 2012, 20:16
Default thanks. This works.
Jeong Kim
Thanks a lot for your tip.
Originally Posted by wyldckat View Post
Greetings Jeong,
Simple:
</ColorMap>
Best regards,
Bruno
Old   March 2, 2014, 08:51
Bruno Santos
OK, so somebody who I won't mention, has asked me for more details on this topic.
So here goes a quick step-by-step guide:
  1. Start ParaView.
  2. Load your data file(s).
  3. Turn on the data set you want to represent. Example, see first attached image.
  4. Click on the "Edit Color Map" button, shown in the second image.
  5. Click on the "Choose Preset" button, shown in the third image.
  6. As shown in the fourth image, you can either choose one of the presets or click on the "Import" button to load a manually created file.
  7. Once the preset is chosen, by clicking on it, then click on the OK button and you're good to go!
Best regards,
Bruno
File Type: jpg Screenshot from 2014-03-02 12:43:53.jpg (41.2 KB, 76 views)
File Type: png Screenshot from 2014-03-02 12:47:10.png (52.6 KB, 104 views)
File Type: png Screenshot from 2014-03-02 12:48:05.png (33.5 KB, 85 views)
Luttappy likes this.
[OpenFOAM] Black Screen with Paraview 5.6.0 on Ubuntu 18.04 after OpenFOAM update ksmithgall ParaView 12 August 29, 2019 12:52
[OpenFOAM] Paraview client/server does not work with ParaView 5.0.1 snak ParaView 0 October 17, 2016 11:22
paraFoam / paraview black screen gfilip OpenFOAM 6 July 13, 2009 05:30
[OpenFOAM] Suface data displayed as a black color aerovargas ParaView 1 September 10, 2008 20:22
CFX-Post: black and white legend/plots? Sjoerd Romkes CFX 0 March 8, 2002 12:20
