[OpenFOAM] [Critical] ParaView 3.12.0 breaks monitor signal in Ubuntu 11.04 |
Viktor Mileikovskyi
Rep Power: 14 ![]() |
Dear members!
I install ParaView 3.12.0 with OpenFoam installation. After running ParaView and working with visualization the screen lamp suddenly switches off ![]() This situation reproduced twice. What happen? Please help me. OS: Ubuntu 11.04 Natty x64 Updated 2011/03/16 PC: Acer Extensa 5620Z Processor: Intel Pentium Dual-Core processor T2370 (1.73GHz, 533 MHz FSB, 1 MB L2 cache) Monitor: WXGA Aser CrystalBright(TM) LCD Video: Mobile Intel GMA X3100 2GB DDR2 160GB LED DVD-Super Multi DL 802.11 b/g WLAN - disabled in blacklist.conf Bluetooth 2.0 + EDR - Switched off. Sound Card Intel HDAudio - disabled in blacklist.conf Soft Modem on Intel HDA Bus - I don't know is it work. Sound Card - in USB Speakers Logitech S-150 Last edited by v_mil; March 18, 2012 at 10:43. Reason: Problem solved |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Greetings Viktor and welcome to the forum!
My guess is that you installed this version: http://www.openfoam.org/download/ubuntu.php There might have been a serious issue with the OpenGL library being used the wrong way by ParaView, leading to a severe graphics card crash. This is possibly due to either one of at least two reasons:
My advice is to uninstall this Deb packages version of OpenFOAM and build it from source, along with building ParaView from source as well: http://www.openfoam.org/download/source.php Good luck! Bruno
Viktor Mileikovskyi
Dear Bruno!
Thank You for reply. I re-install OpenFOAM and ParaView from source with the same result: ~/OpenFOAM/user-2.1.0/run/tutorials/incompressible/icoFoam/cavity$ paraFoam Application asked to unregister timer 0x6e00000c which is not registered in this thread. Fix application. The application starts and switches off a display after 3...5 minutes. Hardware info: ~$ lspci 00:00.0 Host bridge: Intel Corporation Mobile PM965/GM965/GL960 Memory Controller Hub (rev 03) 00:02.0 VGA compatible controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (primary) (rev 03) 00:02.1 Display controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (secondary) (rev 03) 00:1a.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 03) 00:1a.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 03) 00:1a.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 03) 00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03) 00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 03) 00:1c.1 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 2 (rev 03) 00:1c.2 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 3 (rev 03) 00:1d.0 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 03) 00:1d.1 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 03) 00:1d.2 USB Controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 03) 00:1d.7 USB Controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 03) 00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f3) 00:1f.0 ISA bridge: Intel Corporation 82801HEM (ICH8M) LPC Interface Controller (rev 03) 00:1f.1 IDE interface: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) IDE Controller (rev 03) 00:1f.2 SATA controller: Intel Corporation 82801HBM/HEM (ICH8M/ICH8M-E) SATA AHCI Controller (rev 03) 00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 03) 02:00.0 Ethernet controller: Broadcom Corporation NetLink BCM5787M Gigabit Ethernet PCI Express (rev 02) 04:00.0 Network controller: Broadcom Corporation BCM4312 802.11b/g LP-PHY (rev 01) 0f:06.0 CardBus bridge: Texas Instruments PCIxx12 Cardbus Controller 0f:06.1 FireWire (IEEE 1394): Texas Instruments PCIxx12 OHCI Compliant IEEE 1394 Host Controller 0f:06.2 Mass storage controller: Texas Instruments 5-in-1 Multimedia Card Reader (SD/MMC/MS/MS PRO/xD) 0f:06.3 SD Host controller: Texas Instruments PCIxx12 SDA Standard Compliant SD Host Controller ~$ |
Bruno Santos
Hi Viktor,
Mmm... looks to me that the graphics card drivers aren't fully up-to-date. Are you 100% certain that you are using the OpenFOAM+ParaView version built from source? Does the following command return the path related to your home folder? Code:
which paraview Code:
mv $ParaView_DIR ${ParaView_DIR}_disable Then install the version from Ubuntu's repositories: Code:
sudo apt-get install paraview Code:
touch case.foam paraview In case ParaView 3.8.1 is unable to open the case, then convert the case to VTK format, by running: Code:
foamToVTK Good luck! Bruno
Viktor Mileikovskyi
Many thanks to Bruno
![]() This problem is solved by installing Xorg-Edgers packets from UBUNTU repository: ppa:xorg-edgers/ppa Read carefully description: https://launchpad.net/~xorg-edgers/+archive/ppa I. Adding PPA repository a) using Ubuntu Software Center To add PPA open Applications->Ubuntu Software Center, select Edit->Software Sources Select second tab "Other Software", press "Add" and paste Apt line: ppa:xorg-edgers/ppa Press "Add Source" b) or by Terminal ( a process from https://launchpad.net/~xorg-edgers/+archive/ppa ): deb http://ppa.launchpad.net/xorg-edgers/ppa/ubuntu natty main deb-src http://ppa.launchpad.net/xorg-edgers/ppa/ubuntu natty main (Replace natty with your version if it is not Natty) II Updating a system In terminal type: sudo apt-get update sudo apt-get upgrade III It is recommended to reboot. After these three steps my graphics start flying and ParaView works. Many thanks to Bruno! |
Bruno Santos
Hi Viktor,
You're very welcome and thank you for the detailed solution! The link to your post is going into this blog post of mine: Related issues to ParaView with OpenFOAM - Fixes and solutions Best regards, Bruno
blank, lamp, monitor, signal, switch off |
openfoam-2.3.0 on ubuntu natty 11.04 | mickjazz | OpenFOAM Installation | 1 | August 5, 2014 13:01 |
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 | wyldckat | OpenFOAM Installation | 14 | February 12, 2013 04:43 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
Successful Installaton Of OpenFOAM-1.6 and Paraview in Ubuntu 9.04 | AlanR | OpenFOAM Installation | 21 | September 17, 2009 11:27 |
[OpenFOAM] Paraview 3.4, ppa.launchpad.net and Ubuntu | francois | ParaView | 1 | May 29, 2009 09:07 |
