Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Paraview graphics window whited out
Old   February 24, 2011, 10:29
Default Paraview graphics window whited out
jeff osborne
ozzythewise is on a distinguished road
Hello all,
I can use paraview fine but when I go to save state, and then re-open that state file, the graphics window is whited out and I cannot view anything. When I try and rotate the camera I can see graphics, but when I let go of the mouse it becomes whited out again. Any thoughts on this?
Thanks
Jeff
ozzythewise is offline   Reply With Quote
Old   February 24, 2011, 18:53
Retired Super Moderator
Bruno Santos
Greetings Jeff,
The issue you are getting is very similar to the one described here: http://www.cfd-online.com/Forums/ope...-rotating.html
The other possibility is that the version of ParaView you are using has a bug that only happens in certain scenarios. Check the solutions in the thread above and if those don't work, try using another version of ParaView.
Best regards,
Bruno
Old   March 14, 2011, 14:15
jeff osborne
For all interested: The solution was that my graphics settings were messed up on my computer. If anyone has this issue try lowering your graphics resolution, that's what worked for me.
J
Graphics card for Paraview flotus1 Hardware 15 January 27, 2019 14:22
[OpenFOAM.org] ParaView: Open File window gets bigger and bigger until it's impossible to press open mn16mg OpenFOAM Installation 3 January 10, 2019 12:17
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
How to change and fix the size of graphics window? Rob FLUENT 1 February 7, 2003 11:15
Problem: graphics display in prostar main window Jiaying Xu Siemens 8 February 14, 2002 09:08
