Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] paraFoam does not show results of Cavity tutorial
Like Tree1Likes
Old   July 14, 2010, 12:07
Default paraFoam does not show results of Cavity tutorial
Josef
wischenbartj is on a distinguished road
I have just installed openFoam with ParaView 3.8.0 on Ubuntu
I did this by exactly going throw all steps of http://www.openfoam.com/download/ubuntu.php
As written at this side a started the cavity example. Everything working well. But after starting paraFoam I am not able to visualize anything.
In the Pipline Browser I see - in black letters - "cavity.OpenFOAM". Also after turning beside "eye" on and selecting the green "Apply" button i can not see anything.
I also tried "Upsate GUI", Mesh Parts,... but without success.
Can anyone help me ?
wischenbartj is offline   Reply With Quote
Old   July 14, 2010, 12:52
Retired Super Moderator
Bruno Santos
Greetings Josef and welcome to the forum!
In what language is your Ubuntu working? If it isn't working in English, then try running this before paraFoam:
export LC_ALL=C
If things now show up, then run this:
gksu gedit /opt/openfoam170/bin/paraFoam
And add that export line right after the first block of comments in the file.
Save, close and try to run paraFoam again.
Best regards,
Bruno
Old   July 14, 2010, 13:14
Smile
Josef
Thank you for your welcome.
Your tip solved the problem immediately.
Josef
Old   July 31, 2010, 09:05
Luiz Eduardo
DudaAPD is on a distinguished road
Ola Bruno!
Hope you can help me as well.
I am trying to run paraview in ubuntu 10.04 guest with VirtualBox 3.2.6, but I am having problems. What is happening is that after enabling the 3D accelaration I am having this message in the terminal when I try to run paraview:
"OpenGL Warning: No pincher, please call crStateSetCurrentPointers() in your SPU
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-1.7.0/ParaView-3.8.0/VTK/Rendering/vtkOpenGLExtensionManager.cxx, line 358
vtkOpenGLExtensionManager (0x91d7e60): Extension GL_VERSION_1_5 could not be loaded"
Then paraview opens but the darkblue screem stays in the same place when I move the program window and it stays in front of everything else. For instance if I click on "Open" to open a file, the new window stays behind the darkblue screem (geometry, mesh, etc display). the cavity tutorial seems to work fine.
I have no idea how to solve this. I have installed the guest additions successfully previously.
Muito Obrigado!!!
DudaAPD is offline   Reply With Quote
Old   July 31, 2010, 14:52
Bruno Santos
Olá Luiz and welcome to the forum
that's a bad idea turning on 3D acceleration in VMs... at least by my experience. But I haven't tried VirtualBox, so maybe their 3D acceleration system might work properly.
Anyway, the problem you're having with ParaView is the same as some other users have reported when they install the drivers for their graphics card!
I've answered about this before on this thread: http://www.cfd-online.com/Forums/ope...tml#post267127 post #6
You can also try following my instructions to install the official pre-built ParaView 3.8.0: Using the official pre-built ParaView 3.8.0 version with OpenFOAM...
Or you can try rebuilding ParaView 3.8.0, by following the official instructions in OpenFOAM's website.
Best regards,
Bruno
Old   July 31, 2010, 17:51
Luiz Eduardo
Bruno muito obrigado pela resposta!
I've disabled the 3D acceleration and rebuilt paraview. It seems to be working well at least for the cavity case. Another error I was having before is not happening now.
Thank you again!
Luiz Eduardo
Old   February 26, 2011, 16:42
Default I cannot plot the 2D field for the cavity example with Paraview
Francesca
Francesca Scaramuzzino is an unknown quantity at this point
Hi there, so I'm fresh with paraview..I've tried to run the cavity example and I taped the instructions icoFoam and paraFoam. When I launched paraFoam, Paraview started so I was able to visualize a block and the mesh but not the 2D field. I read in the manual that I should load the 0.5 time data but I cannot find anything when I go to open the file..So, what should I do to view the 2D field that is reported in the on-line manual? Please give me your help
Francesca
Francesca Scaramuzzino is offline   Reply With Quote
Old   February 27, 2011, 09:32
Bruno Santos
Greetings Francesca and welcome to the forum!
It's simple:
  • You ran blockMesh, then icoFoam.
  • No errors in sight and you have the 0.1 to 0.5 time folders.
  • You ran paraFoam. ParaView opens with the case folder. You pressed the big green "Apply" button.
  • The mesh/box appears.
  • Now look at the top right half of ParaView's top toolbar and see the "Time" edit box with a spin box to the right (spin box has two triangles, one pointing up and the other down). Click on the top triangle to change the current time snapshot.
  • Then start reading here: Post-processing
To learn more about ParaView and how to use it with OpenFOAM:
Best regards,
Bruno
Old   February 27, 2011, 14:29
Francesca
Bruno thanks a lot...my problem was the set of the time..I thought I should open a file, while it was the simple setting of 0.5 in the time box...then the problem was the colour scale, because I've the new version (blue to red)...anyway at the moment I fixed the problem...but I think I'll ask to you a lot of things in the future..so "be prepared" !
Thanksthanksthanks
Francesca
Old   February 27, 2011, 19:09
Bruno Santos
Hi Francesca,
You're welcome. But don't ask just me, because I have a very limited knowledge about CFD
Best regards,
Bruno
Old   March 7, 2011, 11:30
Francesca
Hi Bruno,
so I'd like to ask to u help about the format for paraview. I have output files that I opened with tecplot (these files are "var" files) that contains for many zones of the computational domain the informations about thermodynamics variables like temperature, pressure etc..Now, I'd like to open these files in paraview, to do this I should convert the var files into vtk files, I guess. So, what should I do to achieve that?
Best regards
Francesca
Old   March 7, 2011, 17:30
Bruno Santos
Hi Francesca,
I've never used Tecplot. All I know about Tecplot is that there is an executable in OpenFOAM named "foamToTecplot360" that can convert OpenFOAM data to Tecplot's format. So my best guess would be to visualize both results in Tecplot, instead of trying to visualize both in ParaView.
Nonetheless, the easiest thing next to that would be to see what formats Tecplot exports to and which ParaView can read. Failing that, then search this forum for "tecplot" and find out which user is working for Tecplot's company, because I vaguely remember someone responded on their behalf a few months ago.
Best regards,
Bruno
Old   March 30, 2011, 10:04
Default x-y plot in paraview
  #13
Francesca
Hi Bruno,
I need of your help. I should draw an x-y graph in paraview, where the x axis is the time.
Now I've tried with filters, alphabetical and plot over line but obviously I see a constant line because on the x axis it doesn't show the time. How can I plot for example the velocity vs the time on a graph in paraview?
Old   March 30, 2011, 20:32
Bruno Santos
Hi Francesca,
Uhm, I didn't know either, but after searching in google for:
site:cfd-online.com plot time
I saw this post: http://www.cfd-online.com/Forums/ope...tml#post287523 post #3
I haven't tried it yet, so I can only assume it should work
Best regards and good luck!
Bruno
PS: I've hit the 1000 posts barrier!
Old   April 3, 2011, 11:06
Francesca
Hi Bruno,
it doesn't work. Listen, I'm trying to do that with the tutorial in the combustion directory, combustion/ras/counterflowflame2D. So, could you try to use the same instructions you post to me and see if, for example, you can visualize the behaviour of the axial velocity vs the time?
Sorry because I know I'm bothering you!
Best regards
Francesca
Old   April 3, 2011, 12:09
Bruno Santos
Hi Franscesca,
I played around a bit with the filters but I don't think I found the right solution.
Basically I:
  1. Used the filter "Plot Over Line".
  2. Then click on the button that splits the view in two and selected spreadsheet on the second window.
  3. Selected the results from the "Plot Over Line" by pressing Ctrl+A.
  4. The used the "Plot Selection Over Time".
The result wasn't very comforting... it only showed one line in the plot.
Like I said, I didn't know and basically I still don't know how to solve your problem. But if you use the search tools to search here in the forum, you should find the solution.
Bruno
Old   March 6, 2015, 10:31
Default export LC_ALL=C file empty and not possible to be saved
  #17
Andres Salazar
viscous is on a distinguished road
I followed the advice of Bruno to the question of Josef
paraFoam does not show results of Cavity tutorial) as I was having the same issue.
So I ran:
export LC_ALL=C
in the terminal, and then an empty file opened. Bruno says "add that export line right after the first block of comments in the file." but the file is empty, I still copied pasted this:
export LC_ALL=Cand when trying to save it, then an error message appeared:
Could not find the file “/opt/openfoam170/bin/paraFoam”.
Please check that you typed the location correctly and try again.
Does anyone know how can I solve it and finally visualize this very "first example case of incompressible laminar flow in a cavity" ?
p { margin-bottom: 0.1in; line-height: 120%; }a:link { } By the way, paraview opened, I clicked on "apply" and changed the time to 5s, then I clicked on "refresh" but i dont see anything happening.
What should I be seeing actually and how can I make it happen?
Thanks!
Andres
export LC_ALL=C
Best regards,
Bruno
viscous is offline   Reply With Quote
Old   March 8, 2015, 09:40
Bruno Santos
Greetings Andres and welcome to the forum!
(paraFoam does not show results of Cavity tutorial) as I was having the same issue.
So I ran:
 export LC_ALL=C
Sorry, but I don't understand what is the problem you're having. Please provide more specific details. For example, what were the exact steps you've done and what is the specific error message you've gotten.
Best regards,
Bruno
Old   June 10, 2015, 00:00
Default Problem with Cavity Tutorial in paraFoam
  #19
Michu
michu is on a distinguished road
Hello All,
I am new to OpenFoam and was also trying to complete the cavity tutorial. It all seemed to work, but when I opened ParaFoam, at time t=0, it had one image then at time =0.1 it had another, but then t=0.2 it had the same image as t=0.1 and so on until it ended. I then extended the time to ten seconds and again at t=0 it had one image then at t=0.1, 0.2, 0.3....10.0 seconds it had the other image (image did not change between the second part). So in the end I only had two images in paraFoam. I thought Parafoam should keep changing the image each time interval to reflect the environment as it changes due to the flow. The image shows the velocity component U. Can someone help me with this issue, I would greatly appreciate it?
The programs I am using:
Oracle VM Virtual Box
Ubuntu-14.04.2
Openfoam240
Paraviewopenfoam410
PS I am also new to this forum, sorry if I am incorrectly doing something.
michu is offline   Reply With Quote
Old   June 12, 2015, 19:03
Bruno Santos
Greetings Michu and welcome to the forum!
If you could have provided screenshots of what you were seeing, it would have been easier to diagnose the problem.
Since you did not, the most efficient answer I can think of is that you take a look at the YouTube tutorials provided here: http://openfoamwiki.net/index.php/Tu...VideoTutorials
Best regards,
Bruno
michu likes this.
cavity problem, parafoam
[OpenFOAM] Refresh Times does not seem to work (Cavity tutorial) MBttR ParaView 2 June 7, 2016 09:53
[OpenFOAM] icoFsiElasticNonLinULSolidFoam (foam-extend 3.1)>>How to see results with paraFoam? steven123 ParaView 7 December 5, 2015 03:34
[OpenFOAM] Open Sample results using paraFoam lpashwin ParaView 0 June 24, 2015 12:04
[OpenFOAM] Trouble running paraFoam in cavity tutorial sweisenb ParaView 2 October 10, 2014 16:56
Viscositymodel tutorial, problems when changing test case to cavity sur4j OpenFOAM Programming & Development 1 December 8, 2013 10:53
