Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] extracting data from paraview
Like Tree1Likes
  • 1 Post By sarreshtehdari
Old   May 31, 2010, 22:46
Default extracting data from paraview
Tharek Mohtar
tharem is on a distinguished road
Iīm trying to make a comparative x-y plot using data extracted from paraview. I want to compare the analytical solution of a dambreak problem against the solution given by openFOAM. The issue is that i canīt extract the x-y position of the free surface from paraview. With the paraview function "contour" is posible to visualize the free surfece at a given alfa fraction but i donīt know how to take off this position data into a table of something like this. I know is posible to take this data from the files created by openFOAM while is solving a problem but i think there is a direct way to extract the data from paraview.
In brief, If anybody knows how to extract the data of the free surface position from paraview please reply!
Thanks.
Tharek Mohtar
tharem is offline   Reply With Quote
Old   January 18, 2011, 00:45
Ali Sarreshtehdari
sarreshtehdari is on a distinguished road
you need to define and draw a contour plot for your property (alpha in your case), e.g. alpha=0.9, then go to Filters(Menu)>Alphabetical>Append Geometry after Apply this plot and check the "Show cube axes" your contour plot will observed in a XYZ coordinate system.
Good Luck
Mohamad(AUT) likes this.
sarreshtehdari is offline   Reply With Quote
Visualize Star-CCM+ data in Paraview peresah STAR-CCM+ 3 April 9, 2019 04:25
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
[General] Advice on post processing compressor blade data in paraview Jack001 ParaView 0 February 4, 2016 18:16
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
[General] paraview - plotting difference to reference data joewe ParaView 0 August 30, 2010 19:01
