Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Alternative to paraFoam
Old   May 25, 2010, 02:00
Lightbulb Alternative to paraFoam
Eric Nutsch
ericnutsch is on a distinguished road
Send a message via Skype™ to ericnutsch
I have had moderate success getting paraFoam to work in the past, so I put together a stupid simple bit of code that does the same thing, just reliably!
Step1: Unzip the attached file and put it into your case directory
Step2: Type ./ParaDisplay into the terminal and hit enter
(while in the case directory of course; operates just like Allrun)
All it does is automate the process of using foamToVTK, opening paraview, locating the vtk file and opening it. But 2 minutes here and there add up.
Let me know what you think.
File Type: gz ParaDisplay.tar.gz (187 Bytes, 59 views)
ericnutsch is offline   Reply With Quote
Old   May 31, 2010, 02:56
Hasselhoff is on a distinguished road
Hi Eric!
Well, it works, so why not:-) I like it, thanks for sharing!
best,
Michael
Hasselhoff is offline   Reply With Quote
Old   July 8, 2010, 20:58
Sunny Karnani
skarnani is on a distinguished road
Thanks, Eric.
I was having a bit of trouble and I'm unsure of how to solve it.
The line:
paraview --data=VTK/${PWD##*/}_..vtk
raises the error
File ' "VTK/cavity_..vtk" ' cannot be read.
I'm guessing it is a trivial fix, but I'm still a bit lost.
Any help would be greatly appreciated.
Thanks.
Sunny
skarnani is offline   Reply With Quote
Old   July 9, 2010, 05:19
Eric Nutsch
Hi skarnani,
Try doing the process manually by first running foamToVTK in the shell.
You can then go into paraview and see if the files are in yourCase/VTK and open them up. If both those things work, but the code doesnt, post back with an ls of your case file and I will see if I over looked something.
Note that there is an issue using this script with OpenFOAM1.5Dev, since sourcing the openfoam variables conflict with paraview. (Still pondering a good approach to this)
Eric
Old   July 9, 2010, 11:15
Takuya OSHIMA
7islands is on a distinguished road
Or if you're using PV 3.8 (downloaded from either Kitware or openfoam.com is ok), try its builtin reader by
touch ${PWD##*/}.foam && paraview --data=${PWD##*/}.foam
under your case directory.
T
7islands is offline   Reply With Quote
Old   July 9, 2010, 15:55
Sunny Karnani
Thank you Eric and Takuya for the replies.
By manually running foamToVTK, I can open paraview and then open the results files. However, I think you called it right, as I am using OpenFOAM-1.5-dev.
Thanks for the help though.
Sunny
Old   July 9, 2010, 16:52
Eric Nutsch
Yeah for the time being, you can open a new shell that is not sourced, cd to the working directory and run ParaDisplay from there.
The extra shell reduces the convenience, but it can be handy in some situations.
I use 1.5Dev myself and will post an updated version of ParaDisplay once I get it working.
Eric
[OpenFOAM] Unable to launch parafoam & boonhow ParaView 5 March 23, 2022 09:09
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] u2berggeist OpenFOAM Installation 2 July 2, 2018 18:03
[OpenFOAM] How to use paraFoam on a cluster andreas ParaView 1 March 6, 2013 18:11
[OpenFOAM] OpenFoam (Ubuntu): paraFoam via Xming+PuTTY raketenmaid ParaView 4 February 5, 2013 06:20
[OpenFOAM] Parafoam basic questions qtian ParaView 0 July 20, 2007 12:52
