Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] View problem with Paraview 3.6.1
Old   July 28, 2009, 11:50
Default View problem with Paraview 3.6.1
Remy is on a distinguished road
Hi everyone,
I'm a new user of Ubuntu and I would like to use paraview as a post processing tool to OpenFoam. But when I open a VTK file, everything seems to work correctly exept that in cannot see anything in the graphic window. I can only see a picture when I'm manipulating the object (e.g. rotating it).
I tried to find the solution in the help file and on several forums, but couldn't find any, could you help me out ?
Remy is offline   Reply With Quote
Old   July 28, 2009, 18:35
Default Turn off the funky desktop effects
Charles
CapSizer is on a distinguished road
Ubuntu by default gives you some nice desktop effects, such as windows becoming transparant or even floppy when you move them. Try deactivating the advanced desktop effects, there seems to be an OpenGL problem with Paraview if you have them active.
CapSizer is offline   Reply With Quote
Old   July 29, 2009, 04:09
Thanks a lot, it worked !
Old   August 4, 2009, 02:40
Default -
Jiwon Kang
jiwon is on a distinguished road
how can I deactivate the desktop effect?
Is any body to help, pleaz?
jiwon is offline   Reply With Quote
Old   August 4, 2009, 02:59
Default To kill the desktop visual effects
Charles
If you are running Gnome, from the Menu system:
System
Preferences
Appearance
Visual Effects
Select "None"
You lose the funky wobbly and transparent windows, and gain a working Paraview. I have seen this with both NVidia and ATi/AMD graphics processors.
Old   August 4, 2009, 04:15
Default wow
Jiwon Kang
now it works very well! lol
thanks, Charles
Problem with viewing graphic view when running in UNIX pitisrisuk Main CFD Forum 1 April 15, 2016 12:39
[OpenFOAM] Can not view mesh in ParaView weamelsahar ParaView 2 October 30, 2015 08:06
[OpenFOAM] Problem switching from terminal to paraView Maxime Thomas ParaView 10 October 4, 2014 11:59
LINUX newbie with paraView installation problem kenya0514 OpenFOAM Installation 4 January 16, 2013 18:51
[OpenFOAM] ParaView 3.6.1 & 3.7.0: Can't view STL files johannes ParaView 2 December 3, 2009 15:07
