Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] No mesh visible in paraview
Old   May 16, 2007, 06:19
Default No mesh visible in paraview
mayank
i have tried running icofoam cavity tutorial with parafoam.The paraview window opens up but no mesh is visible even after hitting the aacept button.
there have been some queries regearding this in previous posts but that did not help.
Kindly elaborate on the error.
Thanks.
Old   September 11, 2009, 06:48
HendrikR is on a distinguished road
the same problem exists in the current version (1.6) of openfoam with paraview (3.6.1)
I follow the first tutorial step-by-step and in chapter 2.1.2 paraview doesn't show me the mesh. If I turn "Show Patch Names" on, it seems that all Patchs are at the same point.
Can someone help me?
Thanks
Hendrik
HendrikR is offline   Reply With Quote
Old   September 11, 2009, 12:57
the solution:
write "export LC_ALL=C" at the beginning of your paraFoam Startskript (which paraFoam)
Old   September 17, 2009, 03:27
Taufiq Muhammadi
taufiq is on a distinguished road
Hmm, i'm just curious, since i don't get this error. What is the cause of the problem? and what does the extra line added do?
taufiq is offline   Reply With Quote
Old   September 18, 2009, 06:58
i'm running an ubuntu in german. The language causes the problem but I also don't know the real problem with the language support.
Hendrik
Old   September 21, 2009, 17:34
James
derjames is on a distinguished road
You can also try exporting first VTK and open the resulting files on paraView
j
derjames is offline   Reply With Quote
Old   September 22, 2009, 07:42
Yes, this worked for me too, but I had the problem that I couldn't select and view patches...
Old   October 18, 2009, 10:02
Aurel is on a distinguished road
Originally Posted by HendrikR View Post
the solution:
I've got the same problem of visualisation anything of the "cavity" example.
After going through the paraForm User Book everything works fine, but there is nothing to see of mesh grids or so on.
I'm using Ubuntu 9.04 (64-bit) and the installed version of openfoam 1.6.
Some more curious:
1) The "cavity.OpenFoam"-file in the Pipeline Browser is empty?!
2) When I try to get Help (Desktop Buttons) following output message appears:
File does not exist: /home/dm2/henry/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/pqClient.adp
Profile '/home/dm2/henry/OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64Gcc/pqClient.adp' does not exist!
That path is definetly not on my computer!
/home/dm2/henry/.. is on someone's other computer!
I would be very happy to get an useful help.
Best regards
Aurel
Aurel is offline   Reply With Quote
Old   October 18, 2009, 13:59
Hi Aurel,
the caviy.OpenFoam-file needs no content, everytime it's empty.
You have installed the 64bit-Version of the thirdparty Tools?
And included the load of the OpenFoam/etc/bashrc in your .bashrc?
If its another Problem, i don't know.
Hendrik
Old   October 18, 2009, 14:57
Hi Aurel,
Hendrik
Hi Hendrik,
yes, I have installed the 64-bit version.
In the /thirdparty/tools is only one file:
makeParaViewFunctions
What do you mean with:
"And included the load of the OpenFoam/etc/bashrc in your .bashrc?"
The .bashrc is in "OpenFoam/etc/" directory.
Could be the different language a problem? Is it necessary to modify the .bashrc file?
For more help I would be very happy.
Regards
Aurel
Old   October 19, 2009, 16:38
Originally Posted by Aurel View Post
Hi Hendrik,
Regards
Aurel
I fixed the problem as follows:
1) Deactivation of the desktop effect!
2) Language problem: ubuntu in German and paraView in English
By modifying the script
$/HOME/OpenFoam/OpenFoam-1.6/bin/paraFoam
with
export LC_ALL=C
paraView it is now working fine.
Regards
Aurel
Old   November 2, 2009, 11:28
Piotr Prusinski
piprus is on a distinguished road
Great thanks for this advice. It fix my problem under polish distribution of Ubuntu 9.10.
One more question. Could you tell me which file I can modify to keep this LC_ALL every time when I open new terminal?
piprus is offline   Reply With Quote
Old   November 4, 2009, 16:28
Hi Piotr,
modify your script:
by adding at the top:
export LC_ALL=C
This should work all time long.
Best regars
Marc Aurel
Old   May 20, 2010, 15:34
Fabio Villa
sturmtruppen is on a distinguished road
Hi to everyone ,
I'm a beginner in OpenFoam and I need help about the language problem.
How did you solve it, Aurel?
I have the same problem of mesh visualization.
I have deactivated the desktop effect and modify the script.
Thanks for your help and to anyone can help me.
with
export LC_ALL=C
Regards
Aurel
sturmtruppen is offline   Reply With Quote
Old   June 10, 2010, 08:21
Fabio Villa
Hi to everyone.
I'm here again.
I modified the language of kubuntu, modified the script and deactivated the desktop effects.
But the problem is not solved. I try to run the cavity tutorial.
After the command "paraFoam" I do not see the mesh, and if I click the accept button I can see only the edge of the volume.
Thanks for any help!
Fabio
I got it.
Just read the user guide to learn how to see the mesh...
Thanks.
Old   November 4, 2010, 16:55
Default No mesh shown in parafoam 3.8.0
  #16
Arnout
The King is on a distinguished road
Hi!
I had the same problem (using opensuse), the mesh was not shown in parafoam, wireframe. Installing the graphical card solves the problem.
Succes!
The King is offline   Reply With Quote
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
ParaView: Number of cells/points in mesh and field don't match Jaggy_Snake OpenFOAM Bugs 2 March 1, 2017 10:06
[OpenFOAM] Can not view mesh in ParaView weamelsahar ParaView 2 October 30, 2015 08:06
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
