[OpenFOAM] Problem with paraview and paraFoam |
January 16, 2009, 05:06 |
stephane sanchi
Rep Power: 18 |
Dear OF users,
When i want to lauch paraview (or paraFoam) I got the following error message : ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 398 vtkXOpenGLRenderWindow (0x1289b90): Could not find a decent visual ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 398 vtkXOpenGLRenderWindow (0x1289b90): Could not find a decent visual X Error: BadValue (integer parameter out of range for operation) 2 Extension: 129 (Uknown extension) Minor opcode: 3 (Unknown request) Resource id: 0x21 ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 623 vtkXOpenGLRenderWindow (0x1289b90): Cannot create GLX context. Aborting. Could someone help me to solve this problem. Thanks in advance. Stephane. |
January 16, 2009, 06:39 |
Hi Stephane,
Did you rebuil
Gijsbert Wierink
Rep Power: 18 |
Hi Stephane,
Did you rebuild ParaView or just unpacked the binary? I think you need to build it as explained in the README (http://www.opencfd.co.uk/openfoam/do...ME.html#README). I also had some problems with openGL headers and stuff and installing "X Software Development" solved it (yum groupinstall 'X Software Development' in Fedora). Rgds, Gijsbert
Regards, Gijs |
January 16, 2009, 06:54 |
Hi Gijsbert,
Now we use Sus
stephane sanchi
Rep Power: 18 |
Hi Gijsbert,
Now we use Suse 11.1 (since last week). I have rebuilt Paraview. Paraview alone (with setenv for OpenFoam) works well. But when I want to use it (or paraFoam) with the setenv parameters for OpenFoam (.cshrc file) it does not work. I have done the installation test and have the following critical error : gcc ...figure WARNING: Conflicting installations: OpenFOAM settings : /bin/gcc current path : /usr/bin/X11/gcc CRITICAL ERROR Stephane. |
January 19, 2009, 08:58 |
Dear O-F users,
I have inst
stephane sanchi
Rep Power: 18 |
Dear O-F users,
I have installed OpenFOAM-1.5 with Suse 11.1. The installation test seems ok. Checking basic setup... ------------------------------------------------------------------------------- Shell: tcsh Host: cfs10 OS: Linux version 2.6.27.7-9-default ------------------------------------------------------------------------------- Checking main OpenFOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /shared/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/sanchi/OpenFOAM/sanchi-1.5 yes no $WM_THIRD_PARTY_DIR /shared/OpenFOAM/ThirdParty yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /shared/OpenFOAM/OpenFOAM-1.5 yes yes yes $FOAM_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes yes $FOAM_USER_APPBIN ...1.5/applications/bin/linux64GccDPOpt yes yes no $WM_DIR /shared/OpenFOAM/OpenFOAM-1.5/wmake yes yes yes ------------------------------------------------------------------------------- Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OAM/OpenFOAM-1.5/lib/linux64GccDPOpt yes no yes $FOAM_USER_LIBBIN ...nFOAM/sanchi-1.5/lib/linux64GccDPOpt yes no no $MPI_ARCH_PATH ...nmpi-1.2.6/platforms/linux64GccDPOpt yes no yes ------------------------------------------------------------------------------- Third party software ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc 4.3.1 ...penFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc gzip 1.3.12 /usr/bin/X11/gzip tar 1.20 /bin/tar icoFoam .../OpenFOAM-1.5/applications/bin/linux64GccDPOpt/icoFoam ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_cfs10 Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the OpenFOAM enviroment. ------------------------------------------------------------------------------- Base configuration ok. Critical systems ok. I have also installed Qt-4.3.5. But when I launch paraFoam (or paraview) paraview opens and suddently close with the following error message : ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 398 vtkXOpenGLRenderWindow (0x12876e0): Could not find a decent visual ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 398 vtkXOpenGLRenderWindow (0x12876e0): Could not find a decent visual X Error: BadValue (integer parameter out of range for operation) 2 Extension: 129 (Uknown extension) Minor opcode: 3 (Unknown request) Resource id: 0x21 ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 623 vtkXOpenGLRenderWindow (0x12876e0): Cannot create GLX context. Aborting. I need your help to solve this problem !!! Stephane. |
January 20, 2009, 05:43 |
Dear OpenFOAM users,
nobody
stephane sanchi
Rep Power: 18 |
nobody has encountered the same kind of problem ? I do not have any idea how to solve it. Stephane. |
January 20, 2009, 05:50 |
i had also a lot of pro
Bastien Holbek
Rep Power: 17 |
i had also a lot of problem with paraFoam. Converting the data to VTK format with foamToVTK utility and visualising them directly with paraview is a solution (not the best...) Bastien |
January 20, 2009, 06:39 |
I have also the same pr
stephane sanchi
Rep Power: 18 |
I have also the same problem with paraview ! So with paraFoam and paraview I have the following error message : ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 398 vtkXOpenGLRenderWindow (0x12876e0): Could not find a decent visual ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 398 vtkXOpenGLRenderWindow (0x12876e0): Could not find a decent visual X Error: BadValue (integer parameter out of range for operation) 2 Extension: 129 (Uknown extension) Minor opcode: 3 (Unknown request) Resource id: 0x21 ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 623 vtkXOpenGLRenderWindow (0x12876e0): Cannot create GLX context. Aborting. The problem is linked with /OpenFOAM/ThirdParty/Paraview3.3-cvs !!! Because when I use Paraview3.5 I have no problem and the Paraview window remains normally openned ! Stephane. |
January 21, 2009, 04:47 |
Any idea how to solve my probl
stephane sanchi
Rep Power: 18 |
Any idea how to solve my problem ?
Linux 11.1 OpenFOAM 1.5 I need your help. Thanks in advance, Stephane. |
January 21, 2009, 05:37 |
Hi Stephane,
Check out this
#9 |
Gijsbert Wierink
Rep Power: 18 |
Hi Stephane,
Check out this post: http://www.cfd-online.com/OpenFOAM_D...es/1/4438.html. Also, try to install the X Software development package. This solved it for me when I had problems with openGL libraries in Fedora and your error seems similar. In Fedora I just did "yum groupinstall 'X Software Development'". I think, in your openSUSE system, you need to go to Yast, select Software Management, and install gcc, xorg-x11-devel, and libpng-devel. My experience with openSUSE is minimal, but you could give it a go. Your error message contains "Cannot create GLX context. Aborting." and this issue seems to have been solved by pUl| in the post mentioned above. I hope any of this is useful. Regards, Gijsbert
Regards, Gijs |
January 21, 2009, 05:59 |
Hi Gijsbert,
gcc, xorg-x11-
#10 |
stephane sanchi
Rep Power: 18 |
Hi Gijsbert,
gcc, xorg-x11-devel, and libpng-devel are already installed. The problem does not seem to be here. It is very strange because : 1. When I use ParaView 3.5 it works well and the window remains openned ! 2. When I use ParaView3.3-cvs it (paraFoam and paraview) does not work any more and the paraFoam window closes immediatly with the ERROR message written in the previous post ! Stephane. |
January 21, 2009, 06:38 |
Hi Stephane,
Line 623 in Op
#11 |
Gijsbert Wierink
Rep Power: 18 |
Hi Stephane,
Line 623 in OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow.cxx checks that your system supports GLX rendering. Maybe it's an issue with your GLX modules and extensions (check http://www.susegeek.com/graphics/setup-nvidia-graphics-card-with-aiglx-rendering -for-opensuse-110/) and I guess you need /usr/lib64/xorg/modules/extensions/libglx.so or /usr/lib/xorg/modules/extensions/libglx.so, but this is all a shot from the hip . Gijsbert
Regards, Gijs |
January 22, 2009, 03:36 |
Hi Gijsbert,
I have tried
#12 |
stephane sanchi
Rep Power: 18 |
Hi Gijsbert,
I have tried to modify the settings of the NVIDIA card but without any success. The problem still remains. Dear users any suggestion is welcome !!! Stephane. |
January 23, 2009, 03:03 |
Dear OF users,
Any ideas ?
#13 |
stephane sanchi
Rep Power: 18 |
Dear OF users,
Any ideas ? I can't use paraFoam (and paraview) any more ... Stephane. |
January 26, 2009, 04:40 |
I need help.
I can't solve
#14 |
stephane sanchi
Rep Power: 18 |
I need help.
I can't solve this problem !!! Stephane. |
January 26, 2009, 10:58 |
Hi Stephane,
What version
#15 |
Michael Jaworski
Rep Power: 17 |
Hi Stephane,
What version of QT do you have installed? You *need* to have QT-4.3.5 installed if you're going to use ParaView 3.3 and the buildParaView3 script file. If you search the forum, there are some explicit instructions for how to do this into a home directory. Good luck! -Mike J. |
January 27, 2009, 02:39 |
Hi Michael,
I have Qt 4.3.5
#16 |
stephane sanchi
Rep Power: 18 |
Hi Michael,
I have Qt 4.3.5 installed ! But Alberto passalacqua told me that it is not necessary. With Linux 11.1 you could use Qt4 with libqt4-devel. Now I am trying his solution. Stephane. |
January 27, 2009, 04:51 |
Dear OF users,
Alberto Pass
#17 |
stephane sanchi
Rep Power: 18 |
Dear OF users,
Alberto Passalacqua told me that it is possible to run paraView with Qt4 under Linux 11.1. I did it following the installation commands (his website). But I have the following ERROR message : paraview: symbol lookup error: /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc/bin/libpqCore.s o: undefined symbol: _ZN11QFormLayout16staticMetaObjectE Has someone already encountered the same error message. Thanks for helping me .. Stephane |
January 27, 2009, 09:12 |
After having followed t
#18 |
stephane sanchi
Rep Power: 18 |
After having followed the instructions of Alberto Passalacqua I have again the same ERROR message : ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 398 vtkXOpenGLRenderWindow (0x12876e0): Could not find a decent visual ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 398 vtkXOpenGLRenderWindow (0x12876e0): Could not find a decent visual X Error: BadValue (integer parameter out of range for operation) 2 Extension: 129 (Uknown extension) Minor opcode: 3 (Unknown request) Resource id: 0x21 ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 623 vtkXOpenGLRenderWindow (0x12876e0): Cannot create GLX context. Aborting. The problem is linked with /OpenFOAM/ThirdParty/Paraview3.3-cvs !!! Because when I use Paraview3.5 I have no problem and the Paraview window remains normally openned ! Stephane. |
January 29, 2009, 07:45 |
I still have the foolow
#19 |
stephane sanchi
Rep Power: 18 |
I still have the foolowing problem : ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 398 vtkXOpenGLRenderWindow (0x12876e0): Could not find a decent visual ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 398 vtkXOpenGLRenderWindow (0x12876e0): Could not find a decent visual X Error: BadValue (integer parameter out of range for operation) 2 Extension: 129 (Uknown extension) Minor opcode: 3 (Unknown request) Resource id: 0x21 ERROR: In /shared/OpenFOAM/ThirdParty/ParaView3.3-cvs/VTK/Rendering/vtkXOpenGLRenderWindow .cxx, line 623 vtkXOpenGLRenderWindow (0x12876e0): Cannot create GLX context. Aborting. Nobody with the same problem ? Need help !!! I can't use OpenFOAM anymore !!! With Suse11.0 paraview was running well. With Suse11.1 I can't run anymore paraview !!! Stephane. |
February 5, 2009, 09:08 |
I enco
#20 |
Markus Ritter
I encountered the same problem when starting Paraview 3.4.0. The window closed immediately after starting. The error message was: [ritt_mu@kauz ~]$ /opt/paraview/bin/paraview > ERROR: In > /tmp/Kitware/ParaView3/VTK/Rendering/vtkXOpenGLRenderWindow.cxx, line 623 > vtkXOpenGLRenderWindow (0x9b7d2b0): Cannot create GLX context. Aborting. > > > Abort Adding the line Option "AIGLX" "false" to the xorg.conf file like proposed in [1] didn't solve the problem. I don't know the exact origin of this error, but after reconfiguring the driver of the graphics card (nvidia) paraview starts normally. (We updated the kernel some days ago but not the driver of the graphics card) BTW, we use Red Hat in our Institute. Maybe this information helps you. Regards, Markus [1] http://www.cfd-online.com/OpenFOAM_D...es/1/4438.html |
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/paraview/61051-problem-paraview-parafoam.html
Posted By | For | Type | Date | |
Untitled document | This thread | Refback | July 13, 2009 13:10 |
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] | u2berggeist | OpenFOAM Installation | 2 | July 2, 2018 17:03 |
[Other] Openfoam for windows 16.02 [CFD support] -problem with paraview | ditmeyer | OpenFOAM Installation | 3 | May 15, 2017 12:04 |
[OpenFOAM] Problem with spaces in paraFoam execution | chrisb2244 | ParaView | 1 | November 9, 2013 15:06 |
problem with running parafoam & paraview | padmanathan | OpenFOAM | 3 | June 12, 2009 07:30 |
Problem running paraFoam paraview command not found | spdracer22 | OpenFOAM Pre-Processing | 2 | December 7, 2005 05:32 |
