Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] ParaFoam reader
Old   March 10, 2009, 14:43
Default ParaFoam reader
Duarte Albuquerque
duartealbuquerque is on a distinguished road
when i run ParaFOAM it appears a windows saying that a reader for the file cavity.OpenFOAM cannot be found.
In this way i cannot see the mesh or the results.
The instalation of the OpenFOAM was sucessufull
duartealbuquerque is offline   Reply With Quote
Old   March 10, 2009, 14:54
Default Hi, you have to build PV3F
Tomislav Maric
tomislav_maric is on a distinguished road
you have to build PV3FoamReader.
cd ~/OpenFOAM/OpenFOAM-yourVersionHere
find . -type d -iname 'PV*FOAMReader*'
My directory is i.e.:
~/OpenFOAM/OpenFOAM-1.5-dev/applications/utilities/postProcessing/graphics/PV3Fo amReader
cd to that directory
./Allwmake
When asking a question, prepare a SSCCE.
tomislav_maric is offline   Reply With Quote
Old   March 18, 2009, 13:00
Default lpqcomponents error
Rishi .
hellorishi is on a distinguished road
I tried to compile paraFoam and I end up with the following error concerning lpqcomponents. I googled but I could not find an answer. Does anybody have a clue what is this about?
Here is the output of Allwmake
+ cd PV3FoamReader
+ mkdir -p Make/linux64GccDPOpt
+ cd Make/linux64GccDPOpt
+ cmake ../..
-- Check for working C compiler: /home/cfdtest/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc
-- Check for working C compiler: /home/cfdtest/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/gcc -- works
-- Check size of void*
-- Check size of void* - done
-- Check for working CXX compiler: /home/cfdtest/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/c++
-- Check for working CXX compiler: /home/cfdtest/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/c++ -- works
-- Loading ParaView CMake commands
-- Loading ParaView CMake commands - done
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - found
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found.
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found.
-- Found Qt-Version 4.3.5
-- Configuring done
-- Generating done
-- Build files have been written to: /home/cfdtest/OpenFOAM/OpenFOAM-1.5.x/applications/utilities/postProcessing/graphics/PV3FoamReader/PV3FoamReader/Make/linux64GccDPOpt
+ make
[ 8%] Generating qrc_PV3FoamReader.cxx
[ 16%] Generating moc_PV3FoamReaderPluginImplementation.cxx
Scanning dependencies of target PV3FoamReader
[ 25%] Building CXX object CMakeFiles/PV3FoamReader.dir/moc_PV3FoamReaderPluginImplementation.o
[ 33%] Building CXX object CMakeFiles/PV3FoamReader.dir/PV3FoamReaderPluginImplementation.o
[ 41%] Building CXX object CMakeFiles/PV3FoamReader.dir/qrc_PV3FoamReader.o
Linking CXX shared library /home/cfdtest/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libPV3FoamReader.so
/usr/bin/ld: cannot find -lpqComponents
collect2: ld returned 1 exit status
make[2]: *** [/home/cfdtest/OpenFOAM/OpenFOAM-1.5.x/lib/linux64GccDPOpt/libPV3FoamReader.so] Error 1
make[1]: *** [CMakeFiles/PV3FoamReader.dir/all] Error 2
make: *** [all] Error 2
I have Qt-4.3.2 on SuSE SLED 10, 64 bit. Paraview-3.4.0 binary in installed as well.
I am using foamToVTK for now, but would like to use paraFoam.
Thanks
Rishi
hellorishi is offline   Reply With Quote
Old   March 21, 2009, 07:25
jan ramboer
janra is on a distinguished road
+ cd PV3FoamReader
+ cmake ../..
-- Configuring done
-- Generating done
+ make
Thanks
Rishi
I have the same error. I run ubuntu intrepid and get this error.
janra is offline   Reply With Quote
Old   May 29, 2009, 13:28
Default lpqcomponents not found
Nurye
carlos is on a distinguished road
Hello Rishi
I got the same error when i tried to compile paraFoam. Can you give me a hint how you have solved it? tks
+ cd PV3FoamReader
+ cmake ../..
-- Configuring done
-- Generating done
+ make
Thanks
Rishi
carlos is offline   Reply With Quote
Old   May 29, 2009, 13:34
Rishi .
Hello Nurye,
Unfortunately I could not solve that error.
I am using a workaround, i.e. using foamToVTK and Paraview binary.
Regards,
Rishi
Old   May 30, 2009, 15:38
Default Can't compile Paraview 3.3
Kenny is on a distinguished road
When I try to build Paraview3.3 I get a couple of error messages as follows:
gcc fails the compling test --broken
libmpfr.so.1 Cannot open shared object file: No such file or directory.
I'm using Open Suse 10.3 32 bit gcc 4.3.1 Qt 4.3.1
Kenny
Kenny is offline   Reply With Quote
Old   June 1, 2009, 11:54
Rishi .
Hello Kenny,
It seems mpfr is missing from your OpenSuSE. Search the forum for OpenSuSE installation procedure & you will find the missing things for OpenSuSE10.3.
e.g.
http://www.cfd-online.com/Forums/ope...tml#post206860
Possibly gmp is also missing from your Linux.
Old   June 2, 2009, 09:46
Rishi .
Hi Kenny,
If you are using OpenSuSE10.3
You can find the QT here:
http://download.opensuse.org/reposit...SUSE_10.3/src/
Can you output the result of following command.
By the way do you have a stand alone machine or a cluster? Can you play around freely with your system ? If ya then you might consider installing Ubuntu and OF script from forum or even simple download the OpenFOAM live Slax from the link in forum.
Rishi
Old   June 2, 2009, 20:47
Rishi,
Thanks. I've been pretty frustrated so far.
I am trying to run on a pentium 4 dual core at home.
What is the OF Script?
What is the OF live Slax?
How are you using OF (what applications)?
Many Thanks,
Old   June 3, 2009, 03:01
Rishi .
Hi Kenny
http://www.cfd-online.com/Forums/ope...ntu-810-a.html
There is possibly another OF installation script. Search it.
There is a live OF that can be run from usb or DVD
http://www.cfd-online.com/Forums/ope...lax-based.html
I am using OF with SuSE, but that was a long story to get it working. I am using icoFoam, turbFoam, rhoSimpleFoam, etc...
Another tip:
forget paraFoam.
use foamToVTK and ParaView.
Paraview binaries are easier to install and no need to compile from source.
Old   June 18, 2009, 12:34
Default PV3FoamReader
  #12
Sylvain Martel
smart is on a distinguished road
Hi guys,
I have trouble with paraview. I correctly buildParaView3.3-cvs but when I do the last task in the "read me" file at the "7 Compiling ParaView 3.3 and the PV3FoamReader module".
When I do :
./Allwclean
+ rm -r PV3FoamReader/Make
rm: ne peut enlever 'PV3FoamReader/Make': Aucun fichier ou dossier de ce type
+ wclean libso vtkPV3Foam
wclean vtkPV3Foam
./Allwmake
+ [ -d /home/sylvain/OpenFOAM/ThirdParty/ParaView-3.3-cvs/platforms/linuxcc -a -r /home/sylvain/OpenFOAM/ThirdParty/ParaView-3.3-cvs/platforms/linuxGcc ]
I think that the Allwmake must be more thing. Could you give me some examples of what it supposed to do? I cannot start paraview at all.
I downloaded the version 3.4 of paraview but I cannot start paraview just by typing paraview in a terminal. All idea is welcome...
Sylvain
smart is offline   Reply With Quote
Old   June 29, 2009, 16:38
Default OF-1.5-dev is ok and paraFoam too!
  #13
Sylvain Martel
Hi all,
I finaly get the OpenFOAM-1.5-dev running perfectly. I changed my linux system to Ubuntu 8.04. I experienced problems with paraFoam and paraview under ubuntu 9.04.
I solved the problem by installing paraview 3.4.0 instead of 3.3-cvs. For this, I changed some file (buildParaView3.3-cvs, in OpenFOAM-1.5-dev/bin and in OpenFOAM-1.5-dev/bin/tools and the bashrc in OpenFOAM-1.5-dev/etc/apps to point to the ParaView-3.4.0 folder (OpenFOAM/ThirdParty/ParaView-3.4.0).
I think it should be OK too with the ubuntu 9.04 in which the qmake version 4.3.5 should be installed.
For me, I used qmake 4.3.4 and gcc 4.3.1.
Thank to all!
Old   August 12, 2009, 10:27
Thomas Wolfanger
anger is on a distinguished road
Hello Nurye,
Regards,
Rishi
not sure whether this is still of interest - today, I ran onto the same error about missing lpqcomponents.
After checking thoroughly through the build logs, I found that while compiling paraview, errors occured (which could not be noticed because the script kept on running...). They were related to a missing Python.h which means that the development files of python were not installed.
After installing these (apt-get install python-dev on debian), compiling and building went smoothly.
best regards,
-Thomas
anger is offline   Reply With Quote
Old   August 12, 2009, 14:48
Default paraFoam success
  #15
Timo Kulju
tikulju is on a distinguished road
I had a HUUUGE problems with paraFoam, so it all came to the chipset related problems. Mainly the situation was, that paraview vorked but paraFoam didn't. In intel integrated graphics i915 the problem haven't yet been solved, but with radeon driver the problem solved with the folllowing:
1. download qt-4.3.5 (as the README file states) unpack and install it :
2. set correct PATH and LD_LIBRARY_PATH, which points to INSTALLED Qt-4.3.5/bin and Qt-4.3.5/lib/ paths. Be sure that they are not blocked by any other libraries (such as /usr/lib64/) or binaries
3. Follow the readme step 7 first guide and all should be done
If paraFoam isn't working, make sure you have mesa-libLG*-devel installed. And also the cmake should be the correct version. I compiled it from the source.
ps. the operating system is fedora 11 in both.
tikulju is offline   Reply With Quote
Old   August 28, 2009, 18:43
victor
torvic is on a distinguished road
Hi all
I'm trying to install Paraview in OF-1.6 but I can't get rid of this error. It is related to an unrecognized format.
the "makeParaview" ends without errors, but in the PV3FoamReader step I got the error
Make/linux64GccDPOpt/vtkPV3FoamUtilities.o
/home/foam15/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libfiniteVolume.so: file not recognized: File format not recognized
make: *** [/home/foam15/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libvtkPV3Foam.so] Error 1
+ cd PV3FoamReader
[ 91%] Building CXX object CMakeFiles/PV3FoamReader_SM.dir/vtkSMPV3FoamReader_SMInstantiator.o
[100%] Building CXX object CMakeFiles/PV3FoamReader_SM.dir/vtkPVPluginInit_PV3FoamReader_SM.o
Linking CXX shared library /home/foam15/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libPV3FoamReader_SM.so
/home/foam15/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so: file not recognized: File format not recognized
make[2]: *** [/home/foam15/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libPV3FoamReader_SM.so] Error 1
make[1]: *** [CMakeFiles/PV3FoamReader_SM.dir/all] Error 2
I have SLED 10 SP1, 64 bits. I am using gcc 4.3.1 and compiled cmake. With the gcc 4.3.3 binary of the Thirdparty I got some "broken" messages.
Please, any hint is appreciated
best
Victor
torvic is offline   Reply With Quote
Old   August 31, 2009, 18:19
victor
anyone ?
best
Victor
Old   September 1, 2009, 13:01
BastiL
bastil is on a distinguished road
I am wondering if someone tried to install pv3Foam against an external paraview? I tried and struggled I set paraview_dir to the make install destiantion of paraview and paraview_inst_dir to build or source directory. However, none of them works as OpenFOAM neads headers from paraview sources as well as files from build directory. My final aim is to not distribute build and source of paraview over all of our system - only binaries. Has anyone tried this before? Users should be able to use same paraview than for other codes.
Thanks.
bastil is offline   Reply With Quote
Old   September 2, 2009, 04:38
BastiL
Ok as a documentation what needs to be done to build all the Paraview-related stuff against a Paraview out of the ThirdParty tree of OpenFOAM:
Edit etc/apps/paraview3/bashrc:
- Point cmake to cmake-location
- Point ParaView_DIR to the location where you installed Paraview with make install (out of ThirdParty-Directory)
Copy all header files from your Paraview Source directories VTK/Common, VTK/Filtering and VTK/Rendering to Thirdparty-Paraview. Theses headers are the only files required there.
Copy Header-Files from Paraview Build-directory VTK and the folder VTK/vtkstd and ParaViewConfig.cmake to the directory where you installed paraview.
Afterwards build as usual. For me this runs.
Regards BastiL
Old   September 2, 2009, 21:09
victor
Hi Bastil
thanks for the hint.
In the meanwhile I tried to use the paraview reader I compiled for OF-1.5 to view the results of the icofoam tutorial of OF-1.6 and it worked. Have not tested in other ones, but perhaps it works.
best
Victor
[OpenFOAM] paraFoam vs paraView builtin reader for lagrangian solvers Yann ParaView 2 September 9, 2017 06:32
[OpenFOAM.org] Problems to install openfoam-2.4.0 on Ubuntu 16.04.01LTS matheusmonjon OpenFOAM Installation 3 February 25, 2017 15:46
[OpenFOAM.com] paraFoam reader module libraries do not exist sjtuwjh OpenFOAM Installation 14 May 6, 2016 14:55
Parafoam - FATAL ERROR: ParaView reader module libraries do not exist Amit_Pawarpawar OpenFOAM Installation 1 August 25, 2014 11:31
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 22:41
