February 25, 2010, 09:30 |
#201 |
Sandeep Menon
Rep Power: 25 |
Ideally, I'd like to Glyph the fluxes at face centres. So, a glyph in the face-normal direction if the flux is positive, and vice-versa. That's basically what I'm looking for. Is this possible?
February 25, 2010, 09:39 |
#202 | |
Mark Olesen
Rep Power: 40 |
This would equivalent to a Lagrangian field (cloud) and you could glyph that immediately. |
February 25, 2010, 12:00 |
#203 |
Sandeep Menon
Rep Power: 25 |
This could be a convenient workaround for now, yes. I can't seem to find an example of constructing a cloud with position vectors (face-centres), though. Could you point me to the most relevant Lagrangian class?
February 26, 2010, 05:51 |
Symmetric Tensor
#204 |
Matteo Carpentieri
Rep Power: 17 |
Hi all
I may have found a bug in the native paraView reader. I'm using OpenFoam 1.6.x with the packaged ParaView (3.6) from the ThirdParty directory. When I visualise data from R (the Reynolds stress tensor) I believe ParaView picks up the wrong components. The order of the 6-component array (symmTensorField) is intepreted by PV as Rxx Ryy Rzz Rxy Rxz Ryz, while the correct order in OpenFoam is Rxx Rxy Rxz Ryy Ryz Rzz. Please tell me if I'm wrong... Cheers Matteo |
February 26, 2010, 06:01 |
#205 | |
Mark Olesen
Rep Power: 40 |
However, the simplest would probably be to simply examine the output (eg, by tutorials/combustion/dieselFoam/aachenBomb) and forge the output files yourself. |
February 26, 2010, 06:09 |
#206 |
Takuya OSHIMA
Rep Power: 20 |
Hi Matteo,
That's intended. The reader reorders the symmTensor components so that the order matches with the order shown in the selection combo box of the ParaView GUI. symmTensorComponents.png Note that the component order is defined by the ParaView GUI so every reader has to follow the order (readers cannot change the order displayed in the component selection). Takuya Last edited by 7islands; February 26, 2010 at 06:19. Reason: Hit post too early; added a note |
February 26, 2010, 07:27 |
#207 | |
Matteo Carpentieri
Rep Power: 17 |
However, my post wasn't too clear, I'm afraid. What I mean is that the reordering you mention is not done properly (at least with my data). I'm not concerned with the order. If ParaView orders the components like in the image you posted, it's fine for me, as long as it picks up the right components of the original data. For example: I'm trying to visualise the boundary conditions for the inlet patch, so I know the values in advance. And I know that R is something like this: (<positive value> 0 <negative value> <positive value> 0 <positive value>) This, in OpenFoam means: xx xy xz yy yz zz When I try to visualise it with paraFoam, I see the correct values ONLY for xx. When i visualise yy i see all 0 values (like xy in the original data). When i visualise zz i see negative values (like xz in the original data) which is clearly wrong, since Rzz can't be negative. An so on... So, I think the bug is in the fact that the reordering you mention is not performed at all. I hope it is clearer now Thanks for your help Matteo |
February 26, 2010, 07:57 |
#208 |
Takuya OSHIMA
Rep Power: 20 |
Matteo,
paraFoam?? Sorry but I'm confused. To clarify, which reader are you talking about (PV3FoamReader or vtkPOpenFOAMReader)? The reader I'm talking about (and am responsible for) is vtkPOpenFOAMReader, which has nothing to do with the paraFoam script. Takuya |
February 26, 2010, 08:07 |
#209 | |
Matteo Carpentieri
Rep Power: 17 |
.....OK.... forget it... I posted in the wrong thread. I'm indeed talking about the PV3FoamReader... I'm sorry if you wasted time after my problem... I'm going to post it in the right thread. |
March 1, 2010, 04:42 |
#210 | |
Mark Olesen
Rep Power: 40 |
Apart from using inspection of the paraview GUI, is there any documentation about how 6-component data are interpreted? Presumably the component ordering should be VTK and not paraview-specific. The only thing I've seen in VTK is vtkTensor which seems to be 9-component, but haven't seen anything about the interpretation of generic n-Tuple datasets. Is this a new fix in your reader or did something change in VTK? I noticed that the corresponding code is conditionally enabled: Code:
#if vtksys_DATE_STAMP_FULL >= 20080620 |
March 1, 2010, 06:47 |
#211 |
Takuya OSHIMA
Rep Power: 20 |
Hi Mark,
No, I am not aware of any concrete documentation about this. The date stamp in the reader source code corresponds to a change to ParaView3/Qt/Core/pqScalarBarRepresentation.cxx, where the component labels are hard-coded. ---------------------------- revision 1.7 date: 2008-06-27 21:30:35 +0900; author: utkarsh; state: Exp; lines: +26 -10; commitid: PAb32eXp878ziA8t; ENH: Fixed BUG #5979. 6 component vectors are now labelled as [XX, YY, ZZ, XY, XZ, YZ]. The color component chooser as well the calculator use this convention while naming components. ---------------------------- The reason why the date is off a week (20080620 vs. 2008-06-27) has totally slipped out of my memory though - it's 1.5 years ago. Before the change IIRC the components were labelled with numbers (0, 1, ... 5). If we visit the bug #5979 in the tracker, we find that the component labels were named along with a particular file format (Exodus). Feel free to reopen the issue at the paraview or vtk-developers list if you'd like Takuya |
March 1, 2010, 09:18 |
#212 | |
Mark Olesen
Rep Power: 40 |
Thanks for the info. It's too bad that it is otherwise a bit difficult to find in paraview/vtk. For a micro-optimization of your reader code, you can reduce the number of operations a little: Code:
// swap the components of symmTensor to match the component names in paraview // OpenFOAM: XX, XY, XZ, YY, YZ, ZZ // ParaView: { "XX", "YY", "ZZ", "XY", "YZ", "XZ" } if (nComponents == 6) { vtkstd::swap(tuple[1], tuple[3]); vtkstd::swap(tuple[2], tuple[5]); } |
May 28, 2010, 08:26 |
#213 |
Takuya OSHIMA
Rep Power: 20 |
Just wanted to drop notes about the current status of the reader.
Takuya |
June 3, 2010, 14:19 |
Paraview-3.8 reading time problem
#214 |
Pablo Caron
Rep Power: 17 |
Hi Takuya,
I've used version 173 through pvFoam for a long time. Everything works fine. Thanks for your great jobs, again! I just installed P-3.8 to test both paraview and the new integrated reader. I have a case with integer time steps, from 0 to 1100 (for simpleFoam), and after that fractional time steps, 1100 to 1100.5 (for icoFoam). When I used pvFoam (v173) there wasn't any complain. So, I used this case to test the integrated reader in P-3.8. First I created a dummy file Code:
touch caseName.foam Code:
Warning: In /home/pablo/Programas/ParaView-3.8.0/VTK/IO/vtkOpenFOAMReader.cxx, line 4273 vtkOpenFOAMReaderPrivate (0x21d2820): Different time directories with the same time value 1100.03 and 1100 found. 1100 will be ignored. Regards Pablo |
June 3, 2010, 23:09 |
#215 | ||
Takuya OSHIMA
Rep Power: 20 |
Hi Pablo,
Takuya |
June 4, 2010, 00:16 |
Adding export LC_ALL=C to pvFoam
#216 |
Pablo Caron
Rep Power: 17 |
Takuya, maybe I can use the pvFoam script and add this setting there, and pointing to paraview-3.8. Say pvFoam-3.8
I'll modify it tomorrow, at work. Thank you! Pablo |
June 4, 2010, 10:58 |
pvFoam-3.8 working!
#217 |
Pablo Caron
Rep Power: 17 |
Hi Takuya, everything is working fine now. I added the "export ..." line and changed the paraviewPath to point to the correct paraview in pvFoam. Then I renamed to pvFoam-3.8.
Thanks for your help. Regards Pablo |
June 4, 2010, 13:19 |
#218 |
Takuya OSHIMA
Rep Power: 20 |
Thanks for the report, Pablo.
Coincidentally, another push to the PV developers finally had the fix to the setlocale problem of PV itself go into the Git head of PV 3.9 (just now!) Takuya Last edited by 7islands; June 4, 2010 at 13:24. Reason: clarification of the fixed problem |
June 4, 2010, 14:30 |
#219 |
Pablo Caron
Rep Power: 17 |
Takuya I want to test pv-3.9 but I can't. If I'm successful I'll implement this at work. So, I prefer to stay in version 3.8 with the workaround. I think it's the safe option.
Regards, and thank you for your help Pablo |
[OpenFOAM] Extract Block with paraview native reader | kandelabr | ParaView | 4 | August 30, 2021 03:28 |
[OpenFOAM] Decomposed multiregion cases in Paraview with native reader | Yann | ParaView | 2 | January 16, 2019 06:48 |
Updated native OpenFOAM reader for ParaView 5.3 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 4 | July 13, 2017 11:14 |
[OpenFOAM] Native VisIt Reader Bugs | tj22 | ParaView | 8 | November 8, 2013 05:21 |
[OpenFOAM] Paraview Windows VTK Reader | trex930 | ParaView | 0 | November 3, 2010 20:31 |
