October 19, 2015, 16:31 |
ParaView doesn't work:
Hey guys,
Paraview does not work since I've updated to OpenFOAM 2.4.0. I'm running OpenFOAM on Ubuntu 15.04. The problem is when I've executed ./Allrun in any tutorial case (e.g. laplacianFoam/flange) and then started paraview by typing "paraview" within the terminal paraview opens and is completely empty. See the screenshot attached. I'm new to openFOAM and I've tried to find a solution via google, without any success. Can anyone help?? Many Thanks in andvance! Cheers Fabian |
October 20, 2015, 03:17 |
If you start paraview with paraview, empty pipeline is normal behavior, since you did not pass --data flag. So either you start paraview with paraFoam (it is a wrapper that creates foam file for you and then starts paraview with all necessary flags), or you do this sequence of commands in case folder: Code:
$ touch case.foam $ paraview --data=case.foam |
October 20, 2015, 18:01 |
#3 | |
[General] Paraview 5 does not work on a .py created by trace | blabhblah_gc | ParaView | 1 | February 5, 2016 17:56 |
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) | chrisb2244 | OpenFOAM Installation | 2 | August 21, 2013 14:24 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 08:11 |
Paraview not found | fusij | OpenFOAM Installation | 2 | January 1, 2011 21:44 |
paraview does not work on ubuntu 10.10 maverick | sebonator | OpenFOAM | 2 | December 18, 2010 11:33 |
