[OpenFOAM] OpenFOAM (2.3.0) guide for ParaView (4.1.0) is not ok with actual software |
March 25, 2014, 14:52 |
Fatema Zandi Goharrizi
Rep Power: 17 |
Hi friends
I installed OpenFOAM 2.3.0 and ParaView 4.1.0 I did the first tutorial "Lid-driven cavity flow" in user guide (presented in the official website of OpenFOAM). But first of all the discribtion is not compatible with GUI in ParaView. It seems the user guide is an old version guide. And another problem is that I couldn't see the results as the same as in tutorial presented. Please help me if you have the answer!! Thank you |
March 26, 2014, 17:09 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick request: please show images of what you're seeing and to which images your referring to in the User Guide.
Otherwise, I would say that it all seems perfectly fine to me |
March 28, 2014, 00:16 |
Rep Power: 17 |
Hello and thank you
It was my fault in order to result. I have not specified the time which mentioned in guide. when I did it, it got to be ok. but the paraview window is a little different from what showed in guide, in properties and display tabs,.. |
March 28, 2014, 05:09 |
Derek Mitchell
Rep Power: 13 |
I have had the same issue. The differences are sufficient to throw a new user, and small enough not to be noticed by one who is familiar.
Classic issue of testing introductory documentation:the difficulty of getting the correct level of tester and once they have run through a few times they are no longer the correct level. The act of testing changes the tester. IMHO: However, in the scale of documentation omissions that exist in OpenFoam, this one is relatively small beer. Fully commented files in the Tutorial examples would be higher up the list. |
March 28, 2014, 19:08 |
#5 | |||
Bruno Santos
Rep Power: 128 |
Greetings to all!
ParaView 3.12.0 was the default version for all OpenFOAM versions since 2.0 to 2.2, if I'm not mistaken. Here the differences between the images and 3.12.0 isn't very big. Problem is that OpenFOAM 2.3 currently has support for both ParaView 3.12.0 and 4.1.0. But ParaView is 4.x is following a new interface that is considerably different. Although the mnemonic is as simple as the following:
Best regards, Bruno
March 29, 2014, 02:13 |
Rep Power: 17 |
Thank you friends, but is there any documentation about ParaView which can be used? (tutorial or guide)
The help of software may be useful but it just works in the ParaView window! is there any individual help document? |
March 31, 2014, 01:18 |
Rep Power: 17 |
Thank you very much
openfoam 2.3.0, openfoam guide, paraview 4.1.0 |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 26 | June 21, 2024 07:54 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
[OpenFOAM.org] How to remove manually installed OpenFOAM 2.3.0? | sisi | OpenFOAM Installation | 2 | December 23, 2014 11:09 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
Best postprocessing software for OpenFOAM | johannes | OpenFOAM Post-Processing | 3 | December 30, 2007 09:34 |
