Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Temperature and streamlines simultaneously in paraview for wedge-typed mesh
Like Tree9Likes
Old   October 29, 2013, 14:34
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi bobi,
download the binaries of the latest version, unzip it and run it
babakflame likes this.
Tobi is offline   Reply With Quote
Old   October 29, 2013, 16:02
Bobby
babakflame is on a distinguished road
Hi Tobi
I am trying to download paraview 3.14 or 3.98 from
http://http://www.paraview.org/parav...s/software.php However after downloading 30% of it. then suddenly it crashes.
Mt internet speed is 1 Mb/S. I don't think that it is from my internet speed.
Is there any way to get paraview 3.14.1 or 3.98 from terminal of ubuntu(12.10) ?
I have looked into openfoam.org site; maybe this directive:
sudo apt-get install paraviewopenfoam3141
However I am not sure.
Regards
Bobi
babakflame is offline   Reply With Quote
Old   October 29, 2013, 19:13
Retired Super Moderator
Bruno Santos
Greetings to all!
@Bobi:
Originally Posted by babakflame View Post
I am using paraview 3.12 with O.F. 2.2.x.
It seems that I should upgrade my paraview version to 3.14.
What? Why do you want to upgrade?
I didn't say you needed to upgrade, I only said that it depends on which version you're using!
The first picture shows where the controls are in ParaView 3.12.0 and the second one on ParaView 4.0.1.
Now do you understand what I meant?
Best regards,
Bruno
Tobi and babakflame like this.
Old   October 30, 2013, 00:00
Bobby
Dear Bruno
Many thanks. The thing that made me confused was a sentence in your second link that says that some options has been added after 3.14 version.
Cause I didn't find cube axes, maybe I thought its because of my version.
So many thanks of both of you (Bruno and Tobi)
Kind Regards
Bobi
Old   October 30, 2013, 01:41
Bobby
Dear Bruno
I learned how to work with cube axes from your links. I took a pic from my result. Although I put coordinate system on the place that I want, but there are still two more necessary modifications. First of all, I need to non-dimensionalize my axes by 0.025 factor. Secondly, I need to start my Y-axis from the 0.1 point i.e. change 0.1 to 0 .
I think my problem is a need to define a kind of arbitrary axis.
PHP Code:
In case of arbitrary axisthe source or the filter needs to provide such meta-information to the CubeAxes
I haven't tried custom range; cause paraview 3.12 does not have this option.
PHP Code:
The Custom Bounds entry allows you to specify your own extent for that  cube axis where as the Custom Range only change the range of the values  that are used as label
Do you have any hint for me Bruno?
Any hint is appreciated.
Kind Regards
Bobi
Old   November 1, 2013, 19:47
Bruno Santos
Hi Bobi,
You'll have to think the other way around: don't think about changing the "cube axes" representation; think about transforming your geometry into the the shape you need it to be.
For that, use the "Transform" filter.
Best regards,
Bruno
Old   November 2, 2013, 13:29
Bobby
Hi Bruno
You're the best
Exactly I got what should I do. I hope that my questions and your unique answers would help other people confronting same problems.
However I should mention that 2 consecutive transfrom filter is needed one for translate and the other for scale. I don't know that why it wasn't applicable with one transform filter.
Long live Bruno.
Regards
Bobi
Old   November 2, 2013, 16:40
Bruno Santos
Hi Bobi,
2 transformations? That's normal. And consider yourself lucky you didn't need 3 or 4.
This is due to how ParaView provides the transformation filter, since it doesn't expose the final transformation matrix, which would enable us to just do a single transformation.
Best regards,
Bruno
[OpenFOAM] Temperature and streamlines simultaneously in paraview for wedge-typed mesh babakflame ParaView 1 October 23, 2013 14:22
