[OpenFOAM] Xlib: extension “NV-GLX” missing on display "Ip Address" |
September 26, 2013, 10:23 |
Ivy
Rep Power: 13 |
Hi
I am using Mac system and access to another linux machine via "ssh". When I create the mesh and then type "paraFoam", I can open the paraview, however, in the terminal it was written "Xlib: extension “NV-GLX” missing on display "****" " How should I solved the problem ? Thanks very much. I am currently doing my bachelor thesis, which is driving me a bit crazy since I often get stuck Any help would be really appreciated |
September 28, 2013, 13:53 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Ivy,
As I said on your other thread http://www.cfd-online.com/Forums/par...ux-system.html - I'll answer to this issue here. Last year I helped someone with a similar issue on a Mac: http://engits.eu/vanilla/index.php?p...ard-engrid./p1 The answer is this: Quote:
Bruno
September 30, 2013, 11:32 |
Ivy
Rep Power: 13 |
Hi Bruno~~~
Thanks soooo much )) I think it works Yeah~~ Best Regards!! Ivy |
May 6, 2014, 04:07 |
I have similar problem using win7 mobaxterm to connect to redhat
#4 | |
Chen Yu
Rep Power: 13 |
Hi Bruno
I have similar problem to remotely use paraview on RHEL from win7 Xlib: extension "NV-GLX" missing on display "localhost:10.0". Do you have any idea to fix the problem? Quote:
May 6, 2014, 15:33 |
Bruno Santos
Rep Power: 128 |
Greetings Chen Yu,
Did you try to follow the instructions given in post #2? Namely the post you quoted? Best regards, Bruno
May 7, 2014, 06:12 |
Chen Yu
Rep Power: 13 |
May 11, 2014, 16:35 |
Bruno Santos
Rep Power: 128 |
Hi Chen Yu,
I had a look into mobaXterm and I don't trust it. It's not open-source and I have some trouble trusting "free" software nowadays. The best I can do is ask you for details on how are you setting up the interface, namely:
Bruno
May 16, 2014, 05:22 |
#8 | |
Chen Yu
Rep Power: 13 |
Answering your question
1. Yes, the win7 machine and RedHat linux machine are in the same network 2. I think the driver is installed properly, the monitor connected to the linux machine also works well 3&4. X11 port is open, gedit and other Xwindows work fine. 5. My paraview version is 3.12.0 64bit, how can I make sure whether it supports "LIBGL_ALWAYS_INDIRECT"? Thank you Quote:
May 18, 2014, 15:15 |
#9 |
Bruno Santos
Rep Power: 128 |
If gedit works, and the graphics are correctly installed in the RHEL machine, then the problem might be with how the flag is being set. ParaView 3.12.0 should work just fine with this flag.
Try this instead: Code:
export LIBGL_ALWAYS_INDIRECT=1 paraview And after a quick search, it seems that this errata might be related to the problem you're having: https://rhn.redhat.com/errata/RHBA-2013-0344.html - try following the instructions given there to fix the problem on the RHEL machine. |
[Other] paraFoam error | scybchenjun | OpenFOAM Meshing & Mesh Conversion | 0 | May 12, 2016 00:25 |
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 | sam.ho | OpenFOAM Installation | 35 | April 5, 2014 16:31 |
[OpenFOAM] Xlib: extension "GLX" missing on display | goldbeard | ParaView | 5 | March 24, 2013 14:12 |
errors when installing openfoam2.1 on ubuntu12.o4 | hewei | OpenFOAM Installation | 5 | May 29, 2012 08:43 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 16:46 |
