Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] setting up pvpython to act like parafoam
Like Tree3Likes
  • 3 Post By jonathanbyrn
Old   September 25, 2013, 08:10
Default setting up pvpython to act like parafoam
Jonathan byrne
jonathanbyrn is on a distinguished road
Hey.
I used trace to generate a python script that would add a slice to a model and render it. It works fine when I run:
paraFoam --script=genimage.py
but it opens up paraview to do the rendering. I wanted to do all this from the commandline so I tried using pvpython and pvbatch but they cannot find the source.
I examined the the paraFoam script and it seems to be creating a config file that specifies the initial source but when I open x.OpenFOAM but there is nothing in it.
My question is how do I get pvpython to load my source in the same way paraFoam does?
I also tried pyFoamPVSnapshot.py but it seems to be expecting an older version of paraview, has it been deprecated?
jonathanbyrn is offline   Reply With Quote
Old   September 26, 2013, 10:42
Jonathan byrne
It turns out paraFoam just creates a dummy file, e.g.; cfd.OpenFOAM and then calls paraview with the command:
paraview --data=cfd.OpenFOAM
The equivalent can be done in a pvpython script by calling:
cfd_OpenFOAM = PV3FoamReader( FileName='/home/cfd/cfd.OpenFOAM' )
wyldckat, taalf and Knusper like this.
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 07:08
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Warning 097- AB Siemens 6 November 15, 2004 05:41
