Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] change in paraview 3.14 version
Like Tree2Likes
  • 1 Post By lakeat
  • 1 Post By nsf
Old   May 4, 2012, 16:47
Default change in paraview 3.14 version
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
For those who want to use paraview 3.14.
please do the following if you see an error message when you are building the PV3FoamReader
cp $paraviewInstDir/CMake/generate_proxydocumentation.cmake $ParaView_DIR/lib/paraview-3.14/CMake/
cp $paraviewInstDir/CMake/smxml_to_xml.xsl $ParaView_DIR/lib/paraview-3.14/CMake/
cp $paraviewInstDir/CMake/xml_to_html.xsl $ParaView_DIR/lib/paraview-3.14/CMake/
cp $paraviewInstDir/CMake/xml_to_wiki.xsl.in $ParaView_DIR/lib/paraview-3.14/CMake/
cp $paraviewInstDir/CMake/generate_qhp.cmake $ParaView_DIR/lib/paraview-3.14/CMake/
nsf likes this.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   May 5, 2012, 03:44
Alberto Passalacqua
Thank you
Alberto Passalacqua
Old   July 9, 2012, 12:14
nsf
Nicolas Edh
nsf is on a distinguished road
I'd like to add one more file that needs to be copied. After a git pull today, compilation of the reader failed with the following message
CMake Error at CMakeLists.txt:13 (INCLUDE):
  include could not find load file:
    $ParaView_DIR/lib/paraview-3.14/CMake/ParaViewUse.cmake
CMake Error at CMakeLists.txt:42 (QT4_WRAP_CPP):
  Unknown CMake command "QT4_WRAP_CPP".
Coping the missing file like Daniels post above resolved the issue.
 cp $WM_THIRD_PARTY_DIR/ParaView-3.14.1/ParaViewUse.cmake  $ParaView_DIR/lib/paraview-3.14/CMake/.
/Nicolas
lakeat likes this.
nsf is offline   Reply With Quote
Old   July 23, 2012, 17:25
caduqued
caduqued is on a distinguished road
Hi There,
I am just wondering... what should be modified in the ParaView 3.14.1 original configuration files to point to this development path?
Any idea? I have been trying for hours, but not luck....
Of course, just copying those files should works (indeed it does), but it would be nice to have a clean, nice and neat OF+PV compilation, without manually altering anything...
Cheers,
caduqued
caduqued is offline   Reply With Quote
Old   July 25, 2012, 14:17
nsf
Nicolas Edh
Hi There,
I don't know to much about the PV3FoamReader nor the internal workings of paraview but I suspect that the modification should be done in the OpenFOAM module rather than paraview it self.
Maybe you can find something if you dive in to how the PV3FoamReader is built.
Have a look in
$WM_PROJECT_DIR/applications/utilities/postProcessing/graphics/PV3Readers
Keep us posted and good luck!
[OpenFOAM] configuring paraFoam to use a different version of Paraview MikeWallis ParaView 5 May 6, 2021 15:05
[OpenFOAM.org] version 2.1.1: problem in making Paraview on LInux 14.04 alireza.sh OpenFOAM Installation 1 December 4, 2018 18:09
[OpenFOAM.org] Paraview 5.4 in shell environment of5x - Segmentation fault (core dumped) dslbkxd OpenFOAM Installation 1 February 3, 2018 01:56
Change in Fluent 13.0 version shubham208011 FLUENT 1 July 23, 2013 02:30
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 08:11
