March 23, 2013, 08:08 |
#21 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I haven't tried that (but would be interested if you succeed): use the sample-utility to write out a sampledSurface type sampledPatch and read that with timeVaryingMappedFixedValue (you'll have to find out which writer-format is working)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
March 23, 2013, 13:16 |
#22 |
Thanks for the suggestion, did not yet consider that option, but it sounds promising. I'll keep you updated once I find a solution.
April 4, 2013, 10:48 |
reaction rate
#23 | |
Is there any function in the new version of swak4foam to evoke reaction rate (combustion->R(Yi) in YEqn.H) of species? I need to write reaction rate of some soecies in a file. Thank you in advance for any hint Hossein |
April 4, 2013, 11:12 |
#24 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Just add "libswakChemistryModelFunctionPlugin.so" to the libs-entry in controlDict. Now if you use any swak-thing (function-object or also funkySetFields) that uses the Field-parser for the first time you see an output like this: Code:
Creating expression field muEff ... "Loaded plugin functions for 'FieldValueExpressionDriver':" psiChem_RR: "volScalarField psiChem_RR(primitive/word speciesName)" psiChem_RRError: "volScalarField psiChem_RRError()" psiChem_RRSumPositive: "volScalarField psiChem_RRSumPositive()" psiChem_Sh: "volScalarField psiChem_Sh()" psiChem_dQ: "volScalarField psiChem_dQ()" psiChem_deltaTChem: "volScalarField psiChem_deltaTChem()" psiChem_tc: "volScalarField psiChem_tc()" psiChem_updateChemistry: "volScalarField psiChem_updateChemistry(primitive/scalar timestep)" All this uses the results from the last run-through of the chemistry-solver. In funkySetFields you've got to trigger this calculation with the psiChem_updateChemistry-function (only use it once): "psiChem_updateChemistry(0.001)+psiChem_RR(CO)+psi Chem_RR(CO2)" for Reaction rates of CO and CO2. Of course you can use it to check whether the time-step influences the reaction rates "(psiChem_updateChemistry(0.001)+psiChem_RR(CO ))-(psiChem_updateChemistry(0.002)+psiChem_RR(CO))" but that of course calculates everything twice
April 5, 2013, 09:27 |
reaction rate(2)
#25 |
Thanks Bernhard. It's very useful but when I try implementing the following sentences in my solver, I encounter the following error that states ‘psiChem_RR’ was not declared in this scope.
if (Y[i].name() == "O2") { volScalarField wO2 = psiChem_RR(Y[i].name()); wO2.write(); } I inserted the #include "swakPsiChemistryModelPluginFunction.H" header in my .C file and the address of it in "option" which is in following: EXE_INC = \ . . . -I$(HOME)/Swak4Foam_2.x_release_0.2.3/Libraries/swak4FoamParsers/lnInclude/ \ -I$(HOME)/Swak4Foam_2.x_release_0.2.3/Libraries/swakSourceFields/lnInclude/ \ -I$(HOME)/Swak4Foam_2.x_release_0.2.3/Libraries/functionPlugins/swakChemistryModelFunctionPlugin/lnInclude EXE_LIBS = \ . . . -lsampling \ -lmeshTools \ -L$(FOAM_USER_LIBBIN) \ -lswak4FoamParsers \ -lswakChemistryModelFunctionPlugin \ -lswakSourceFields How can I solve above problem? Best Regards, Hossein |
April 5, 2013, 10:58 |
#26 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
- create an instance of FieldValueExpressionParser. Feed it the expression you want to get and get the result from that. I don't explain this in detail because for the purpose of what you want to do this would be like using dynamite to go after the cockroaches in your drain: lot of fun, but the neighbours might think it is a little bit excessive. - have a look at the source of the plugin and try to lift the parts you need (If I remember it correctly: get from the registry the object-registry the object with the name "thermophysicalProperties". Cast it down to the combustion-thermo and then call the RR there). That might be the easiest (for your purposes)
April 6, 2013, 00:11 |
reaction rate(3)
#27 |
April 6, 2013, 07:26 |
#28 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
I was hoping you might find the answer there
June 11, 2013, 23:48 |
Release 0.2.4
#29 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
A new version of swak4Foam has been released. It is the version found on the USB-stick of the 8th OpenFOAM workshop. New features include (but for all see the README which has a complete list):
- functionObjects now store their data in the sub-directory postProcessing according to the new convention OpenFOAM has (sorry: this may break existing scripts relying on the old location) - slight change in the format written may break the restart of cases where swak-specific restart data was written with older swak-version (should not hit many people) - Example cases are adapted to run with OF 2.2. This may prohibit them from running with 2.1 or 2.0 But now the good parts: - build scripts have been adapted to run on more machines, allow tuning of the compilation process, compile on non-gcc compilers and give more information for finding problems - A new library with additional searchableSurfaces (to be used in snappyHexMesh) that allow boolean operations and coordinate transformations of searchable surfaces - Function objects to calculate the distributions of variables (and expressions) - specification of aliases for field names that contain special characters (like thermo:rho) - functionObject to list all registered objects (basically for finding out what is there) - functionObjects to handle global variables - functionObject that executes a list of other functionObjects only if the run is parallel/serial - A new type of variable (stacked) that allows recording multiple values - More flexible output control for functionObjects based on simpleFunctionObjects - swakDataEntry is improved - other stuff and bug fixes (check the README) Also to make life easier for the non-Emacs people who have problems converting the (still incomplete ) reference guide to a more readable form it can be downloaded here: http://openfoamwiki.net/images/d/db/...mReference.pdf
August 13, 2013, 15:22 |
OpenFOAM 2.2.1 + Swak4Foam 0.24 ?
#30 |
Jose Rey
Rep Power: 18 |
Hi Bernhard,
Will swak4Foam 0.2.4 install correctly on the new OpenFOAM 2.2.1 ? Also, when will swak4Foam 0.2.4 be posted to the openfoamwiki.net site? Thank you very much. Last edited by JR22; August 13, 2013 at 18:18. Reason: added question about swak4foam availabilty |
August 13, 2013, 19:52 |
#31 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
January 27, 2014, 20:43 |
New Release of 0.3.0 of swak4Foam
#32 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
8 months ago the last release of swak4Foam happened. A week later Edward Snowden blew the whistle on the NSA. Coincidence? Unlikely! (who is back there saying "Correlation does not imply causality"? Obviously someone who doesn't appreciate a good conspiracy theory). Today the next version of swak4Foam is announced and the world is expecting the next Spy-Agency to be exposed. The only question is: will it be China, Russia or Austria.
Most of the features have already leaked to the public through the public development repository and the twitter-acount @swakPyFoam but for all those whose intelligence-branch failed to interpret these informations correctly here is an incomplete list of the new features
For further information see - the Wiki page http://openfoamwiki.net/index.php/Contrib/swak4Foam - the README that comes with the sources - the Documentation-folder of the sources has an incomplete reference guide. It documents all the expression-grammars Have fun and look out for the men in the trenchcoats
July 11, 2014, 17:36 |
New Release of 0.3.1 of swak4Foam
#33 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
This release has been sitting on my hard-disk for several weeks but now I've gotten around to releasing it officially (it is technically identical to the version on the USB-sticks distributed at the Workshop and also the version that is pulled when you compile it as one of the ThirdParty-packages with foam-extend-3.1)
This Release supports the latest versions of OpenFOAM (2.3) and Foam-Extend (3.1). It has its fair share of bug-fixes and also some new features:
November 6, 2014, 10:03 |
#34 |
Dear Bernhard,
How can I store the reaction rate of species O2 in each time step using psiChem_RR? Which expressions should be added to controlDict file after adding "libswakChemistryModelFunctionPlugin.so" in the libs or do something else? I'm using swak4Foam_2.x_release_0.2.3 now. Thank you in advance, Hossein |
November 6, 2014, 11:43 |
#35 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
November 6, 2014, 14:07 |
#36 | |
That is what I need. Sorry for another question. For example If I set the deltaT value in controlDict to 1e-07, Does psichem_RR function consider that value to calculate the reaction rate? Thanks |
November 6, 2014, 15:44 |
#37 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
It reuses the RR that was calculated by the chemistry and used to solve the species transport equations. If you want to check the influence of the timestep there is a separate function for it (it is explained in slides 138ff. Please get into the habit of checking more than just a few pages before asking again. You're one "under-researched" question away from being permanently ignored)
November 19, 2014, 10:58 |
#38 |
Mahdi
Rep Power: 13 |
Dear foamers,
I am trying to install swak4Foam on OF2.3, and I already tried the OF2.2x version suggested by Bruno but still there are some errors. I am wondering if there is a package developed for OF2.3. I am looking forward to your answers, Thanks in advance and Best, Mahdi |
November 19, 2014, 14:10 |
#39 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
November 19, 2014, 16:34 |
#40 | |
Mahdi
Rep Power: 13 |
Thanks a lot for your quick response as always. I tried the 2.x-release downloaded from: svn checkout svn://svn.code.sf.net/p/openfoam-extend/svn/trunk/Breeder_2.0/libraries/swak4Foam/ swak4Foam_2.x I attached the make log file output from this compile. Then I also tried this one which was suggested by Bruno (https://github.com/wyldckat/swak4foam/tree/OF22X), but I am not sure if this principally should work for me or not; anyway it did not Thanks and Best, Mahdi |
Troubles with heat release rate | Xavier Ponticq | CFX | 4 | September 12, 2012 19:49 |
Extend Project Release 1.6-ext | hjasak | OpenFOAM Announcements from Other Sources | 33 | July 14, 2011 19:54 |
OpenCFD release OpenFOAMŪ version 1.7.1 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | August 26, 2010 12:40 |
Diesel combustion simulation ( Heat release rate) | venkatesh | Siemens | 2 | April 29, 2009 08:38 |
Public Release of the Wiki | Jonas Larsson | CFD-Wiki | 3 | November 7, 2005 05:13 |
