December 14, 2010, 06:37 |
#21 | |
Mark Olesen
Rep Power: 40 |
December 14, 2010, 12:12 |
#22 |
Alberto Passalacqua
Rep Power: 36 |
Same here.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
December 15, 2010, 15:47 |
#23 |
Hrvoje Jasak
Rep Power: 33 |
Hello Mark,
It looks like our server has identified you as a bit of a Bad Boy (dear, dear). Don't worry, I will help you out. Please point your web browser to: powerlab.fsb.hr/ped/kturbo/OpenFOAM/ and then click on the historicalReleases directory (you may want to have a look around as well if you feel like it). You can then right-click on the archive you want and do a Save-As. If this does not work, I have set up a special link for you: wget http://www.fsb.hr/~hjasak/foam2.3.2_13_12_04.tgz Please shout if you get problems. Hrvoje
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
March 14, 2011, 05:13 |
#24 |
Rep Power: 16 |
Is there a way to install OpenFOAM 1.6-ext on a Red Hat system? Current I use OpenFOAM 1.7.1. Regards, Ralph |
March 16, 2011, 12:19 |
#25 |
are you looking for a binary package (.rpm) Package? So far i only know of the debian binary packages made by Oliver Borm. Are you familiar with "alien"? => http://taufanlubis.wordpress.com/200...or-deb-to-rpm/ You could download debian binaries from https://launchpad.net/~cae-team/+arc...series_filter= or http://ppa.launchpad.net/cae-team/pp...nfoam-1.6-ext/ and convert them into rpm (but because of all the dependecies and so on it is not an ideal method to do so!) But I think it is not harder to get the sources via git and compile the sources. if you have git installed. read http://openfoamwiki.net/index.php/Installation for orientation or https://openfoam-extend.svn.sourcefo...1.6-ext/README cd ~/OpenFOAM/ git clone git://openfoam-extend.git.sourceforge.net/gitroot/openfoam-extend/OpenFOAM-1.6-ext Edit your .bashrc file in ~/.bashrc there are the Scripts for ThirdParty packages =>AllMake.stage0 ,1,2,3,4 https://openfoam-extend.svn.sourcefo...DME.ThirdParty Last edited by elvis; March 20, 2011 at 05:45. |
March 16, 2011, 13:30 |
#26 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
There are binary packages for RedHat/CentOS here
http://sourceforge.net/projects/cent...iles/OpenFOAM/ (but no RPMs I'm afraid) I havn't tried them so I can't comment on them Bernhard |
March 16, 2011, 13:44 |
#27 |
Rep Power: 16 |
Thank you very much!
March 20, 2011, 18:31 |
FOAM 1.6-ext features
#28 |
Jim Carow
Rep Power: 16 |
Hello extendedFOAMERS,
I am trying to locate in the sources the following features that I saw in the announcement for 1.6-ext (www.cfd-online.com/Forums/openfoam-news-...release-1-6-ext.html). Developments to utilities ...* Level-set support tools Model development ...* Updated stress analysis tools, new large deformation solver formulation I have browsed the SVN and have taken a look inside the stress solver sources and I didn't see a large deformation formulation. Can anyone please point me to that and the level-set tools? thanks alot, Jim |
March 22, 2011, 03:12 |
#29 |
Dear Jim,
you might want to contact Kathrin Kissling => see her presentation http://www.uni-ulm.de/fileadmin/webs...les/CLSVOF.pdf you find her contacts below http://www.csi.tu-darmstadt.de/staff...s_37440.en.jsp http://www.extend-project.de/openfoa...ty/165/profile |
March 22, 2011, 10:02 |
Clsvof
#30 |
Hae-Won Choi
Rep Power: 17 |
Dear Elvis and Jim:
That's exactly what we want too. We would like to model two phase flow model in porous media. Thanks for your information. Hae-Won |
March 26, 2011, 15:50 |
#31 |
Andrea Pasquali
Rep Power: 17 |
Hi All,
I have a "new" question about OF 1.6-ext (it's no really new because I already posted it but without reply). During last workshop in Gotheborg Prof. Jasak presented an application for RBF to do morphing for CFD optimization. I tried the tutorial movingBlockRBF. I can rotate and translate the block but I still haven't found how to morph the block surface with control points (for example increase the length or give a curvature). Can I do that? If yes, could anyone help me how to set the RBF for morphing or where I can find some examples? Thanks in advance Andrea
Andrea Pasquali |
April 13, 2011, 19:30 |
#32 |
Sung-Eun Kim
Rep Power: 17 |
Did you get any answers to your queestion or figure it out yourself? I'd like to try sliding mesh for my turbomachinery app that I originally used GGI.
April 14, 2011, 04:12 |
#33 |
Andrea Pasquali
Rep Power: 17 |
Hi Sek,
No I did not get any reply yet (and until now I haven't had time to explore it myself). For sliding mesh you mean you want to use the moveDynamicMesh (with tetra remesh) in 1.6-ext? For my case I need a morpher that, maybe coupled with RBF, can change the shape of my surface. Do you know is there this in OF? Or any other open source morpher else? I known Discretizer but I found it not stable with big models. PS: I already coupled OF with commercial morpher (ANSA), running everything with the DAKOTA open source optimization tool for CFD optimization. But I'd like also test an open source morpher. However, keep in touch in our progress Thanks Andrea
Andrea Pasquali |
July 14, 2011, 19:54 |
#34 | |
Daniel WEI (老魏)
Rep Power: 21 |
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
The FOAM Documentation Project - SHUT-DOWN | holger_marschall | OpenFOAM | 242 | March 7, 2013 13:30 |
OpenCFD release OpenFOAM® version 1.7.1 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | August 26, 2010 12:40 |
Diesel combustion simulation ( Heat release rate) | venkatesh | Siemens | 2 | April 29, 2009 08:38 |
The OpenFOAM extensions project | mbeaudoin | OpenFOAM | 16 | October 9, 2007 10:33 |
CFD project idea | John Cleveland | Main CFD Forum | 4 | March 8, 2005 13:55 |
