[Other] can prism elements exist in 2D mesh in openfoam
Old   June 19, 2013, 09:04
Default can prism elements exist in 2D mesh in openfoam
Yao Lu
shuoxue is on a distinguished road
I am dealing with the 2D tutorial case, basic →potentialFoam →cylinder.
Mesh is generated in Gambit, and imported into openfoam with fluentMeshToFoam.
All hexahedra, evening is ok.
1922 hexahedra and 1 prism, an error occurs when I run the checkMesh utility.
Can prism elements exist in 2D mesh in openfoam?
Thanks!
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.0-5be49240882f
Exec   : checkMesh
Date   : Jun 19 2013
Time   : 19:11:50
Host   : "luyao"
PID    : 9751
Case   : /home/luyao/OpenFOAM/luyao-2.2.0/run/case/basic-potentialFoam/1/cylinder1
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
    internal points:  0
    faces:            7797
    internal faces:   3740
    cells:            1923
    faces per cell:   5.99948
    boundary patches: 6
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     1922
    prisms:        1
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    defaultFaces        3846     4058     ok (non-closed singly connected)
    up                  60       122      ok (non-closed singly connected)
    right               30       62       ok (non-closed singly connected)
    left                30       62       ok (non-closed singly connected)
    down                56       116      ok (non-closed singly connected)
    cylinder            35       72       ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-2 0 -0.05) (2 2 0.05)
    Mesh (non-empty, non-wedge) directions (1 1 0)
    Mesh (non-empty) directions (1 1 0)
 ***Number of edges not aligned with or perpendicular to non-empty directions: 292
  <<Writing 584 points on non-aligned edges to set nonAlignedEdges
    Boundary openness (-7.50327e-19 -2.79069e-18 1.27596e-18) OK.
    Max cell openness = 1.58683e-16 OK.
    Max aspect ratio = 2.29701 OK.
    Minimum face area = 0.000933415. Maximum face area = 0.00937919.  Face area magnitudes OK.
    Min volume = 9.35413e-05. Max volume = 0.000755163.  Total volume = 0.760783.  Cell volumes OK.
    Mesh non-orthogonality Max: 48.9644 average: 10.6063
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.59933 OK.
    Coupled point location match (average 0) OK.
Failed 1 mesh checks.
End
shuoxue is offline   Reply With Quote
Old   June 20, 2013, 06:21
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi shuoxue,
I think the outputted mesh uses points that are not exactly planar. Try to run the utility
flattenMesh
It will probably fix your errors. Just check the width in the Z-direction afterwards if you are interested in forces/coefficients.
Regards,
Tom
tomf is offline   Reply With Quote
Old   June 21, 2013, 00:19
Yao Lu
Originally Posted by tomf View Post
Hi shuoxue,
flattenMesh
Regards,
Tom
Hi, tomf!
Thank you so much for your hint. I have worked out the problem.
The error in checkMesh is
Hexahedra and prisms elements can exist in 2D mesh in openfoam, other element types cannot. However, edges in Z-condition have to normal to XY plane.
Tips:
To generate a surface with or without divided blocks in xy plane. Then, drag the surface in Z-condition, and a volume with or without separated blocks is built up. Mesh the volume with map or submap algorithm.
There is no error in Gambit, such as a logical cube for meshing was not able to found. CheckMesh in openfoam is also ok.
Prism Layer Mesh resulting in unwanted Pyramid Elements Bromodachi ANSA 1 October 27, 2015 04:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[ICEM] Have bad elements in mesh and am unable to do prism layer generation dushechka ANSYS Meshing & Geometry 4 February 3, 2015 15:14
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
