[mesh manipulation] more than two regions to join using stitchMesh partial or perfect option
Like Tree6Likes
  • 1 Post By Lada
  • 1 Post By jherb
  • 4 Post By wyldckat
Old   October 30, 2011, 15:05
Default more than two regions to join using stitchMesh partial or perfect option
vladimir krejci
Lada is on a distinguished road
It seems when attaching a mesh using partial option there can be only one such interface and it must be the last one in the joining sequence.
I have created a rather simple case made of three cylinders which I want to join to make a single pipe. The cylinders are meshed completely the same. The only difference is they are offset axially by their respective heights.
When I merge them and stitch them using perfect option, everything goes smoothly. When the first interface is stitched as perfect and the second one as partial, no problems rise. But when the first stitching is partial and the second one perfect, the second one is not performed resulting in an error:
--> FOAM FATAL ERROR:
Master or slave face zone contain no faces. Please check your mesh definition.
From function void slidingInterface::checkDefinition()
in file slidingInterface/slidingInterface.C at line 97.
Has anyone encountered this weird behaviour of stitchMesh utility when applied to join more than two meshes?
Is there a way out?
I hope the attached case might help to solve the puzzle. Just run the Allrun script to see the error in the log.stitchMesh_2 file.
Zhiheng Wang likes this.
Lada is offline   Reply With Quote
Old   November 25, 2011, 14:09
Default bugreport
Joachim Herb
jherb is on a distinguished road
I can reproduce this problem (with/without the -partial option) and have reported a bug at:
http://www.openfoam.com/mantisbt/view.php?id=347
jherb is offline   Reply With Quote
Old   October 20, 2013, 04:48
Retired Super Moderator
Bruno Santos
Greetings to all!
I was browsing the list of bugs still open at OpenFOAM's bug tracker, when I spotted the bug report that points to this thread.
I gave the case a try and reproduced the same error. But I applied the solution I had found some time ago here: http://www.cfd-online.com/Forums/ope...tml#post433137 post #10 - and attached is the result.
It can stitch the 3 meshes just fine, as long as the file "constant/polyMesh/meshModifiers" is removed between stitches.
In addition, the attached case also demonstrates how to use my own little utility stitchMeshMultiPatch: https://github.com/wyldckat/stitchMeshMultiPatch
Best regards,
Bruno
Old   May 28, 2015, 10:52
braker is on a distinguished road
@wyldckat
Thank you very much, that just solved the problem!
braker is offline   Reply With Quote
Old   April 12, 2017, 12:00
Laszlo Barta
LaszloBarta is on a distinguished road
I have a multiregion case, I would like to stitch or merge meshes of the regions into a single mesh. But I would like to retain the zones for defining porous zones. Could anyone tel me if that is possible and if yes, how?
Thanks
Laszlo
LaszloBarta is offline   Reply With Quote
Old   June 17, 2018, 17:29
Bruno Santos
Quick note: As I've just indicated in report https://bugs.openfoam.org/view.php?id=347
This issue was fixed back in April 2018, in commit 484c16a5da1896d1141f832aecfbfc0ce251f434 of OpenFOAM-dev.
The solution was to not write the mesh modifiers, therefore 'stitchMesh' would not load those modifiers the next time it is run.
@LaszloBarta: I hope you've solved your problem.
stitchmesh
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 18:19
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
