February 9, 2012, 05:43 |
Parallel sHM error
#1 | ||
Rep Power: 15 |
Hi folks,
i'm trying to run snappyHexMesh (OF 2.1.x) in parallel mode using following commands: Code:
blockmesh decomposePar (using scotch in decomposeParDict) mpirun -np 6 snappyHexMesh -parallel -overwrite (using ptscotch in decomposeParDict) reconstructParMesh -constant -mergeTol 1E-6 Quote:
Thanks in advance! Last edited by vigges; February 9, 2012 at 06:26. Reason: Provide version of used sofware |
April 4, 2012, 10:18 |
I'm having the same issue… did you manage to solve sort it out eventually?
April 4, 2012, 10:42 |
Rep Power: 15 |
Sorry, I haven't got any solution.
I gave up after trying an entire weekend |
April 18, 2012, 12:17 |
Rep Power: 14 |
Have you solve your problem ? What command line did you executed before reconstructPartMesh ?
Maybe I have a solution to solve your problem |
April 24, 2012, 04:37 |
Rep Power: 14 |
Ive a similar problem when running my solver. I had a closer look in the C++documentation and somehow figured out the reason.
The problem is caused by the decomposition of the domain. There a default_matchTolerance for the faces which is automatically applied (the value is 1e-4). You can see this setting in your processor*/constant/polyMesh/boundary file at the processor-patches. " [2] face 7 area does not match neighbour by 0.276304% -- possible face ordering problem. patchrocBoundary2to1 my area:9.14844e-07 neighbour area:9.17375e-07 matching tolerance:9.08608e-11 " The matching tolerance 9.08608e-11 is calculated as followed: matchTol*length^2 The length is the maximal distance from the face center to a vertice ( in this case: ~ 9.532e-4 Squared this corresponds to a kind of equivalent face area. This value is compared with the difference between "my area" and "neighbour area". I could not figure out how to change this matchTolerance so I just changed the entry in the boundary-files after the decomposition with this command: " sed 's/0.0001/0.05/g' processor*/constant/polyMesh/boundary -i " -> the matchTolerance is 0.05 now I think it is very difficult to match this very small default tolerance for a refined mesh. I also use SHM and therefore have the same problem. I dont know yet if the calculation is stable. Do you know any better solution (e.g. where to set the matchTolerance - entry, e.g. in the decomposeParDict)?? |
April 24, 2012, 04:43 |
Rep Power: 14 |
Could you copy your files here ? (decomposePar, snappyHexMesh, controlDict)
April 30, 2012, 05:59 |
Rep Power: 14 |
I decomposed with "method hierarchical"
This error just occured when running my solver; I had no problems with snappyhexmesh. Did you try my solution? Do you use cyclic boundary conditions? |
May 2, 2012, 07:44 |
#8 | |
Rep Power: 14 |
No, but it's difficult to help you, if we don't see what parameters you used |
March 18, 2013, 07:27 |
exit with error when parallelized
#9 |
I just run sHM in serial and it finished correctly, without snapped and layered mesh.
it seems that the problem in sHM
practice makes perfect |
November 23, 2018, 09:45 |
#10 |
Rep Power: 8 |
Hi guys,
I know, that this thread is pretty old, but I'm having the same issues. I am using OpenFOAM 6 and snappyHexMesh. Here is how I get the same matching Error: 1. blockMesh 2. decomposePar 3. runParallel snappyHexMesh -overwrite SnappyHexMesh is running until it is snapping and displacing the mesh to fit to my surfaceFeatureExtract-Object (or in some cases until layerAddition). Here is the last bit of my log.snappyHexMesh file: Code:
Morph iteration 3 ----------------- Calculating patchDisplacement as distance to nearest surface point ... Wanted displacement : average:0.000594714 min:5.62277e-07 max:0.00214618 Calculated surface displacement in = 0.11 s Detecting near surfaces ... Overriding nearest with intersection of close gaps at 0 out of 27372 points. Overriding displacement on features : implicit features : false explicit features : true multi-patch features : false Morph iteration 3 ----------------- Calculating patchDisplacement as distance to nearest surface point ... Wanted displacement : average:0.000594714 min:5.62277e-07 max:0.00214618 Calculated surface displacement in = 0.11 s Detecting near surfaces ... Overriding nearest with intersection of close gaps at 0 out of 27372 points. Overriding displacement on features : implicit features : false explicit features : true multi-patch features : false Detected 0 baffle edges out of 54250 edges. --> FOAM Warning : From function Foam::treeBoundBox::treeBoundBox(const Foam::UList<Foam::Vector<double> >&) in file meshes/treeBoundBox/treeBoundBox.C at line 136 cannot find bounding box for zero-sized pointField, returning zero Initially selected 0 points out of 27372 for reverse attraction. Selected 0 points out of 27372 for reverse attraction. Stringing feature edges : changed 0 points Attraction: linear : max:(0.00183956 -0.00110546 -7.51662e-06) avg:(4.50171e-05 -2.00879e-05 -2.80543e-09) feature : max:(0 0 0) avg:(0 0 0) Feature analysis : total master points:27048 attraction to : feature point : 0 feature edge : 0 nearest surface : 0 rest : 27048 Smoothing displacement ... Iteration 0 Iteration 10 Iteration 20 Displacement smoothed in = 6.6 s Moving mesh ... Iteration 0 Moving mesh using displacement scaling : min:1 max:1 Correcting 2-D mesh motion--> FOAM Warning : From function void Foam::motionSmootherAlgo::modifyMotionPoints(Foam::pointField&) const in file motionSmoother/motionSmootherAlgo.C at line 657 2D mesh-motion probably not correct in parallel ...done [1] processorPolyPatch::calcGeometry : Writing my 14323 faces to OBJ file "/media/agit/Volume/OpenFOAM/_baseCaseTest01/1_cases/0.507/5E-02/processor1/procBoundary1to2_faces.obj" [2] processorPolyPatch::calcGeometry : Writing my 14323 faces to OBJ file "/media/agit/Volume/OpenFOAM/_baseCaseTest01/1_cases/0.507/5E-02/processor2/procBoundary2to1_faces.obj" [2] processorPolyPatch::calcGeometry : Dumping cell centre lines between corresponding face centres to OBJ file"/media/agit/Volume/OpenFOAM/_baseCaseTest01/1_cases/0.507/5E-02/processor2/procBoundary2to1_faceCentresConnections.obj" [1] processorPolyPatch::calcGeometry : Dumping cell centre lines between corresponding face centres to OBJ file"/media/agit/Volume/OpenFOAM/_baseCaseTest01/1_cases/0.507/5E-02/processor1/procBoundary1to2_faceCentresConnections.obj" [2] [2] [2] --> FOAM FATAL ERROR: [2] face 5738 area does not match neighbour by 0.0267405% -- possible face ordering problem. patch:procBoundary2to1 my area:3.99941e-06 neighbour area:3.99835e-06 matching tolerance:1.03479e-09 Mesh face:1177078 vertices:4((-0.0929725 0.00598575 0.04625) (-0.0993708 0.00603835 0.04625) (-0.0993676 0.00603726 0.045625) (-0.0929683 0.00598432 0.045625)) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with processor debug flag set for more information. [2] [2] From function virtual void Foam::processorPolyPatch::calcGeometry(Foam::PstreamBuffers&) [2] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 284. [2] FOAM parallel run exiting [2] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 2 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0 with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [1] [1] [1] --> FOAM FATAL ERROR: [1] face 5738 area does not match neighbour by 0.0267405% -- possible face ordering problem. patch:procBoundary1to2 my area:3.99835e-06 neighbour area:3.99941e-06 matching tolerance:1.03424e-09 Mesh face:1187038 vertices:4((-0.0929725 0.00598575 0.04625) (-0.0929683 0.00598432 0.045625) (-0.0993664 0.00603686 0.045625) (-0.0993686 0.00603759 0.04625)) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with processor debug flag set for more information. [1] [1] From function virtual void Foam::processorPolyPatch::calcGeometry(Foam::PstreamBuffers&) [1] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 284. [1] FOAM parallel run exiting [1] Detected 0 baffle edges out of 54250 edges. --> FOAM Warning : From function Foam::treeBoundBox::treeBoundBox(const Foam::UList<Foam::Vector<double> >&) in file meshes/treeBoundBox/treeBoundBox.C at line 136 cannot find bounding box for zero-sized pointField, returning zero Initially selected 0 points out of 27372 for reverse attraction. Selected 0 points out of 27372 for reverse attraction. Stringing feature edges : changed 0 points Attraction: linear : max:(0.00183956 -0.00110546 -7.51662e-06) avg:(4.50171e-05 -2.00879e-05 -2.80543e-09) feature : max:(0 0 0) avg:(0 0 0) Feature analysis : total master points:27048 attraction to : feature point : 0 feature edge : 0 nearest surface : 0 rest : 27048 Smoothing displacement ... Iteration 0 Iteration 10 Iteration 20 Displacement smoothed in = 6.6 s Moving mesh ... Iteration 0 Moving mesh using displacement scaling : min:1 max:1 Correcting 2-D mesh motion--> FOAM Warning : From function void Foam::motionSmootherAlgo::modifyMotionPoints(Foam::pointField&) const in file motionSmoother/motionSmootherAlgo.C at line 657 2D mesh-motion probably not correct in parallel ...done [1] processorPolyPatch::calcGeometry : Writing my 14323 faces to OBJ file "/media/agit/Volume/OpenFOAM/_baseCaseTest01/1_cases/0.507/5E-02/processor1/procBoundary1to2_faces.obj" [2] processorPolyPatch::calcGeometry : Writing my 14323 faces to OBJ file "/media/agit/Volume/OpenFOAM/_baseCaseTest01/1_cases/0.507/5E-02/processor2/procBoundary2to1_faces.obj" [2] processorPolyPatch::calcGeometry : Dumping cell centre lines between corresponding face centres to OBJ file"/media/agit/Volume/OpenFOAM/_baseCaseTest01/1_cases/0.507/5E-02/processor2/procBoundary2to1_faceCentresConnections.obj" [1] processorPolyPatch::calcGeometry : Dumping cell centre lines between corresponding face centres to OBJ file"/media/agit/Volume/OpenFOAM/_baseCaseTest01/1_cases/0.507/5E-02/processor1/procBoundary1to2_faceCentresConnections.obj" [2] [2] [2] --> FOAM FATAL ERROR: [2] face 5738 area does not match neighbour by 0.0267405% -- possible face ordering problem. patch:procBoundary2to1 my area:3.99941e-06 neighbour area:3.99835e-06 matching tolerance:1.03479e-09 Mesh face:1177078 vertices:4((-0.0929725 0.00598575 0.04625) (-0.0993708 0.00603835 0.04625) (-0.0993676 0.00603726 0.045625) (-0.0929683 0.00598432 0.045625)) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with processor debug flag set for more information. [2] [2] From function virtual void Foam::processorPolyPatch::calcGeometry(Foam::PstreamBuffers&) [2] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 284. [2] FOAM parallel run exiting [2] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 2 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0 with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [1] [1] [1] --> FOAM FATAL ERROR: [1] face 5738 area does not match neighbour by 0.0267405% -- possible face ordering problem. patch:procBoundary1to2 my area:3.99835e-06 neighbour area:3.99941e-06 matching tolerance:1.03424e-09 Mesh face:1187038 vertices:4((-0.0929725 0.00598575 0.04625) (-0.0929683 0.00598432 0.045625) (-0.0993664 0.00603686 0.045625) (-0.0993686 0.00603759 0.04625)) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with processor debug flag set for more information. [1] [1] From function virtual void Foam::processorPolyPatch::calcGeometry(Foam::PstreamBuffers&) [1] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 284. [1] FOAM parallel run exiting [1] Would someone be so kind and enlighten me, please? Since I want to make a parameter study, I need to run the meshing in parallel, otherwise it would take too long for me... I have compressed my blockMeshDict, decomposeParDict and my snappyHexMeshDict to system.zip: |
June 3, 2020, 09:34 |
#11 | |
Franco
Rep Power: 7 |
did you find any solutions? i have the same problem... best regards. |
September 22, 2022, 16:41 |
#12 |
Rep Power: 5 |
I've had the same error, when using SHM and I found this thread, in which the 3rd post suggests that you must not have the boundary type empty in your model.
I just tried it out by switching each empty boundary to type patch and it worked! The same thing applies to type cyclic as far as I know. Best regards Finn |
September 23, 2022, 02:23 |
#13 | |
Franco
Rep Power: 7 |
Yes snappy does not support defining boundaries with, empty cyclic, cyclicAMi, symmetry, symmetry plane. This type of boundaries should be created after the meshing with createPatch utility F. |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 10:40 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 08:11 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
