[snappyHexMesh] How to visualize the castellated mesh? |
August 25, 2011, 06:15 |
#1 | |
Rep Power: 15 |
I am totally beginner on snappyHexMesh, and my problem is pretty simple : how can I visualize the castellated mesh. I did : Quote:
Thanks for your help! |
August 25, 2011, 07:13 |
Hi Hikachu!
There are many ways to visualize the mesh in paraview. You can select how to display the geometry (surface, outline, wireframe, ...) in a dropdown menu. I think the best way to start is reading the user guide for paraview on http://www.paraview.org/paraview/hel...mentation.html There you can learn how to do slices, cutouts and so on to visualize everything. Good luck! Tobias |
August 25, 2011, 07:45 |
Advanced Paraview Tutorial @ Sixth OpenFOAM workshop, Dave DeMarle, Kitware, Inc.
http://www.openfoamworkshop.org/6th_...rle_slides.pdf |
August 26, 2011, 10:54 |
Zeroing in on the "castellated" part of the question
Michael Roth
Rep Power: 17 |
Btw, if you're interested in looking at the castellated i.e. block-like structure of your mesh, a good filter in Paraview is "Extract Cells By Region" e.g. attachment below.
Steps:
Mike |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[snappyHexMesh] Disturbance in the mesh after the addition of layers | Dorian1504 | OpenFOAM Meshing & Mesh Conversion | 0 | June 13, 2017 03:27 |
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) | shubham jain | ANSYS Meshing & Geometry | 1 | April 10, 2017 06:03 |
[snappyHexMesh] Snappyhex mesh: poor inlet mesh | Swagga5aur | OpenFOAM Meshing & Mesh Conversion | 1 | December 3, 2016 17:59 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 08:05 |
