[snappyHexMesh] SnappyHexMesh and MultiRegion - get regions from Salome to OF
Old   July 1, 2014, 11:07
Default SnappyHexMesh and MultiRegion - get regions from Salome to OF
dzi
dzi is on a distinguished road
Hello Foamers
I tried many things and read a lot of snappyHexMesh threads but still I do not get it working to define regions in Salome and get them as patches in OF.
Mesh preparation in Salome:
Construct 2 bodies, here cylinder1 and cylinder2. The cylinders have a intersection.
I exploded the bodies into faces and meshed them with tetras.
I want to define regions at this state to find them in my case structure and set them as boundary.
Here cylinder2 is exploded to faces, the highlighted submesh is a face called cyl2botaussen.stl to be found as a patch.
After meshing, all faces are written out as cyl1*.stl
(total 3:
  cyl1bot.stl cyl1top.stl  cyl1wall.stl
) merged into one file
 cyl1.stl
and cyl2*.stl
(total 4:
cyl2botaussen.stl  cyl2botinner.stl cyl2top.stl  cyl2wall.stl
merged into
cyl2.stl
cyl2botinner and cyl1top are the interface between the cylinders, the mesh is matching/the same.
The salome-hdf and the resulting stl file one can be found here:
https://www.dropbox.com/sh/bkalhcqwv...pEOPQ2fz9KAMva
SHM:
For the next steps, I use this standard case structure. Meshing2 contains the mesh preparation folders. cyl1.stl and cyl2.stl are copied to /constant/triSurfaces.
The snappyHexmesh is invoked by the steps (=makeMesh.sh):
ideasUnvToFoam outbox.unv
surfaceFeatureExtract
snappyHexMesh -overwrite
splitMeshRegions -cellZones -overwrite
paraFoam -touchAll
After snappyhexmesh I get the expected 3 regions domain:
cylinder1, cylinder2, domain0
and the default patches inbetween.
My snappyHexmeshDict has the sections:
geometry
     cyl1.stl
         type triSurfaceMesh;
         name cylinder1;
     cyl2.stl
     name cylinder2;
     regions
         cyl2botaussen        { name cylinder2aussen; }
    features
             file "cyl1.eMesh";
             level 2;
             file "cyl2.eMesh";
             level 2;
 refinementSurfaces
         cylinder1
             // Surface-wise min and max refinement level
             level (2 3);
             faceZone cylinder1;
             cellZone cylinder1;
             cellZoneInside inside;
         //cyl2.stl
     cylinder2
           level (2 3);
           faceZone cylinder2;
           cellZone cylinder2;
 //        regions     -- must this be here?
 //          cylinder2aussen { level (3 3);  }
I want to see „cylinder2aussen“ in paraview as a patch.
What is going wrong, why my patch „cylinder2aussen“ is lost after SHM and and how can I get it? (Do I need putting the desired patch in a separate stl-file? Different entries in the snappyHexMeshDict? In SurfaceFeatureExtractDict?) None of the tutorials and threads could really help me.
Maybe somebody can give me the missing link. Thanks for reading and support
dirk
All files and the complete case are here:
https://www.dropbox.com/s/awk8noaanm...ppyMRFEasy.tgz
(on Salome 7.2.0 and OF 2.2.2)
dzi is offline   Reply With Quote
Old   July 30, 2014, 06:39
dzi
... FYI there was an answer on another thread http://www.cfd-online.com/Forums/openfoam-meshing/135307-splitmeshregion.html#post503707
using
splitMeshRegions -cellZonesOnly -useFaceZones
but this issue still not solved for me yet.
Old   September 4, 2014, 11:04
dzi
fyi, latest updates are in that thread:
http://www.cfd-online.com/Forums/openfoam-meshing/135307-splitmeshregion.html#post509069
multiregion, salome, snappyhexmesh
[snappyHexMesh] Multiregion snappyhexmesh obiscolly50 OpenFOAM Meshing & Mesh Conversion 0 April 18, 2019 01:51
[snappyHexMesh] Unzoned cells by SnappyHexMesh for a Multiregion Mesh mujika OpenFOAM Meshing & Mesh Conversion 5 February 14, 2018 15:38
[snappyHexMesh] combine blockMesh features cyclicGgi and mixingPlane with multiregion snappyHexMesh AmRo OpenFOAM Meshing & Mesh Conversion 5 June 8, 2016 07:36
snappyHexMesh axisymmetric multiRegion Henning86 OpenFOAM Running, Solving & CFD 0 October 23, 2014 13:05
Simulation of SnappyHexMesh multiregion nithishgupta OpenFOAM Running, Solving & CFD 0 June 24, 2014 06:31
