[snappyHexMesh] Meshing U-shaped cylindical pipe
Old   November 11, 2012, 22:01
Unhappy Meshing U-shaped cylindical pipe
Jakub Pola
stainboy is on a distinguished road
Hello
I'm learning sHM and I'm having a problem with generating internal mesh for an U-shaped cylindrical pipe presented on the image ushape.jpg.
I generated successfully a mesh for straight cylinder so I moved to U shaped geometry but it is not easy.
I'm having a problem with strange tetWedges which I can't get rid of. Could anyone please help me with some advices which might help me to generate fine mesh.
This problem was raised in thread: http://www.cfd-online.com/Forums/ope...of2-0-1-a.html
Case dir can be found here (blockMesh is in system dir). There is as well a VTK folder where i've separated those bad tetWedges.
One of my aproaches was to define refinement box around the my shape but that does not helped. I tried the same stl as a refinement surface but it doesn't helped either.
I was looking on the SwiftSnap tutorial and I saw that it is possible to generate a nice mesh from bend pipe. I did tried blender plugin but I failed.
Second problem little bit less important is to generate boundary layers. (currently switched off in attached case dir). I did not managed to generate them as well.
I'm using OF 2.1.1:
Build : 2.1.1-221db2718bbb
Exec : snappyHexMesh
Thank you in advance for your help.
Best regards,
Jakub.
stainboy is offline   Reply With Quote
internal mesh, pipe, snappyhexmesh
[ICEM] Hexa meshing branched pipe with different angles about its perimeter fascinatedbyCFD ANSYS Meshing & Geometry 1 November 19, 2015 11:11
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
[snappyHexMesh] snappyHexMesh - spiral shaped pipe internal flow callmety OpenFOAM Meshing & Mesh Conversion 2 July 31, 2015 00:28
[GAMBIT] GAMBIT Meshing of Pipe with Holes Perpendiculer to Flow Stream rocketman1151 ANSYS Meshing & Geometry 7 November 30, 2011 03:39
[Other] Meshing Techniques for Heat Transfer with Cube Shaped Objects cbritan OpenFOAM Meshing & Mesh Conversion 4 March 2, 2011 02:12
