[Helyx OS] Helyx-OS (GUI for SnappyHexMesh
Like Tree44Likes
Old   August 14, 2013, 14:41
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
This error is associated with improper definition of WM_PROJECT_INST_DIR and WM_THIRD_PARTY_DIR.
if both
echo  $WM_PROJECT_INST_DIR
and
echo $WM_THIRD_PARTY_DIR
return a valid path then this error should not happen. I'm guessing that there may be a step that you may have missed. Did you do the
sudo apt-get install paraviewopenfoam3120
step? Also, see what
gives you.
chegdan is offline   Reply With Quote
Old   August 14, 2013, 14:52
izna O'connor
izna is on a distinguished road
on doing the first 2 commands
izna@izna-MS-7592:~$ echo $WM_PROJECT_INST_DIR
/opt
izna@izna-MS-7592:~$ echo $WM_THIRD_PARTY_DIR
/opt/ThirdParty-2.2.1
paraview has been installed..
on doing the last command..
izna is offline   Reply With Quote
Old   August 14, 2013, 15:02
Daniel P. Combest
Izna,
Alright, then we are looking at something similar to
http://www.cfd-online.com/Forums/ope...tml#post376326 post 26 from Wyldckat
but with some differences. In HELYX-OS bin directory, find all the *.run scripts and add
. /opt/openfoam221/etc/bashrc
after the first line. See if this is a solution. Sometimes if you have multiple installations defined you will run into these problems.
wyldckat likes this.
Old   August 14, 2013, 15:26
izna O'connor
IT WORKSSSSSSSSSSSSSSSSSSSSSSSSSSSS
Thanks a lot Dan. :*
Old   August 29, 2013, 18:53
atg
Karl
atg is on a distinguished road
Originally Posted by chegdan View Post
Comment Edited : I am going through to try and reproduce this issue, but I am unable to do so. I have an STL file with the name, ExportedfromBlender-263(sub17).stl and everything is imported into HelyxOS fine and meshes as expected. Also, it really should be ok to have a file with a minus sign in it... Can you give some more details on how to reproduce this?
Right now its on the sourceforge ticket tracker but it needs some more detail. Otherwise, thanks for pointing this one out.
Ok I reproduced this error. Process for generating file is as follows:
1. Import stl to Blender
2. Divide surface into layers
3. Export each layer as a separate stl file
4. Import each stl file into HelyxOS. They receive the name of the stl file on the top level in the Surfaces list, with a sublayer indented beneath having the long "exported_from_blender" name automagically assigned
5. Set up number of layers and thickness on the sublayers of interest
6. Run the meshing command. Meshing goes fine until
7. Layer generation stalls with following error message for each stl/patch (note the name of the file it cannot find appears identical to the name listed in the "Valid patches are" section):
Mesh snapped in = 5630.23 s.
Layer thickness specified as final layer and expansion ratio.
--> FOAM Warning :
    From function polyBoundaryMesh::patchSet(const wordReList&, const bool, const bool) const
    in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 777
    Cannot find any patch or group names matching bottom_Exported_from_Blender-2.68_(sub_0)
--> FOAM Warning :
    From function layerParameters::layerParameters(..)
    in file autoHexMesh/autoHexMeshDriver/layerParameters/layerParameters.C at line 286
    Reading "/home/karl/OpenFOAM/karl-2.2.x/run/newCase21i_1/processor0/../system/snappyHexMeshDict.addLayersControls.layers" from line 224 to line 239
    Layer specification for bottom_Exported_from_Blender-2.68_(sub_0) does not match any patch.
Valid patches are
18
ffminx
ffmaxx
ffminy
ffmaxy
ffminz
ffmaxz
far_Exported_from_Blender-2.68_(sub_0)
symmetry_Exported_from_Blender-2.68_(sub_0)
top_Exported_from_Blender-2.68_(sub_0)
tip_Exported_from_Blender-2.68_(sub_0)
leading_Exported_from_Blender-2.68_(sub_0)
procBoundary0to15
procBoundary0to1
procBoundary0to16
procBoundary0to3
procBoundary0to18
procBoundary0to6
I have not tried the fix described above by stetz, but just wanted to confirm the error. System is starcluster Ubuntu 12.04 standard HVM AMI with 2.2.x and v1.0.3 helyx. Thanks for any thoughts. Maybe there is a maximum length? I will go back and edit the stl files so the first line matches the filename, reimport and see if that works.
Incidentally, a command line guide to running Helyx would be nice for those of us working across SSH connections. I set up the case on my home machine then put it on the server to run it, so all I need to do is load the case into helyx and initiate the "create mesh" (or run solver) steps. I guess I will study the terminal log files to figure out how to manage this from the command line.
--ADDENDUM--
Changing the name in the first line of each stl file to a simple short name e.g. "top" "bottom" "tip" etc. fixes this problem. Maybe something to do with the parentheses characters or something. Easy fix for those exporting blender files.
atg is offline   Reply With Quote
Old   September 19, 2013, 14:36
Daniel P. Combest
This is exactly what I do when I use Blender. So getting rid of the text that says
Exported_from_Blender-blah.blah
in STL files and replacing it with nicer names is much better.
Old   September 19, 2013, 14:39
Daniel P. Combest
Just to inform everyone that there is a slight change in the buoyantBoussinesq*Foam using alphat instead of kappat that is defined in HELYX-OS. This was pointed out by JR22 at
http://www.cfd-online.com/Forums/ope...tml#post452585
and I posted a general workaround if someone is running into problems before the next release.
Old   September 25, 2013, 12:05
Default Hello
  #108
Vishal Chauhan
vishu343 is on a distinguished road
Hello guys, I just installed helyxOS on my ubuntu os v.12.04. But unfortunately as I am totally new to don't know from where it should be started. Also I have extracted all the files from the archive file.
vishu343 is offline   Reply With Quote
Old   September 25, 2013, 16:18
Daniel P. Combest
Do you have OpenFOAM installed? Once you have a working installation of OpenFOAM-2.2.x then HELYX-OS should work with relative ease.
To install OpenFOAM-2.2.x I suggest the steps on the OpenFOAM.org site. From there its pretty much all copy paste if you read through slowly.
Old   November 8, 2013, 20:28
Andrew Mortimer
AndrewMortimer is on a distinguished road
Hi all,
I'm not sure if this is the correct place to post but I cannot find a specific sub-forum for HelyxOS.
I am running xubuntu 12.04, openfoam2.2.2 and helyxos v1.02 on a 64bit machine.
Using the single core solver works fine, but I am running into trouble with parallel.
Creating the mesh and geometry and running works fine, and there is a definite speed-up with using multiple cores over a single core so this seems fine. After meshing when I go to re-open the folder to go through the solver properties, it asks for Serial or Parallel but is accompanied by this error:
Clicking serial only brings in part of the mesh, clicking parallel brings in the whole mesh as it should be.
When I put in my values for the solver and click start, the output logfile is:
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.2.2-9240f8b967db
Exec   : simpleFoam -parallel -case /home/andrew/Helyx/p1
Date   : Nov 09 2013
Time   : 00:23:22
Host   : "andrew-pc"
PID    : 8600
Case   : /home/andrew/Helyx/p1
nProcs : 6
Slaves :
5
"andrew-pc.8601"
"andrew-pc.8602"
"andrew-pc.8603"
"andrew-pc.8604"
"andrew-pc.8605"
Pstream initialized with:
    floatTransfer      : 0
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Also for some reason the logfile stops recording there, and the rest is left in a terminal which I cannot seem to copy text from so have taken the screenshots of the output:
Many thanks if anyone has the time to take a look at this and suggest a solution
Andrew
AndrewMortimer is offline   Reply With Quote
Old   November 9, 2013, 10:11
Retired Super Moderator
Bruno Santos
Greetings Andrew,
Actually, the official forum is on their project: http://sourceforge.net/p/helyx-os/discussion/
Mmm... v1.0.2... I'm guessing that you haven't seen that there is a patch for 1.0.2 and that the latest version is 1.0.3: http://sourceforge.net/projects/helyx-os/files/
My advice is to jump directly to 1.0.3, since the issues you are reporting probably have already been fixed.
Best regards,
Bruno
Old   November 9, 2013, 14:39
Andrew Mortimer
Hi Bruno,
Cheers for looking over the post, I'm afraid I mis-typed the version, and I am running v1.0.3 currently.
I will make a post on the project forum though, thanks for the link.
Andrew
Old   November 11, 2013, 06:37
Default Same problem
  #113
Sture Smidt
sture is on a distinguished road
I have the same problem. HelyxOS v1.0.3 does not make the p, U, k, etc files when running a parallel case that has been meshed in parallel.
How do you switch from a parallel to a serial case and vice versa?
sture is offline   Reply With Quote
Old   November 29, 2013, 13:00
Default Helyx-OS 2.0.0
  #114
Sture Smidt
How do you reconstruct a Helyx parallel case after a run?
I have tried reconstructPar, but I get an Error message.
sture_ii@SturePCUbuntu:~/OpenFOAM/sture_ii-2.2.2/run/analyser/body03_00b/body03_00c$ reconstructPar -latestTime
Exec : reconstructPar -latestTime
Date : Nov 29 2013
Time : 17:53:24
Host : "SturePCUbuntu"
PID : 3823
Case : /home/sture_ii/OpenFOAM/sture_ii-2.2.2/run/analyser/body03_00b/body03_00c
nProcs : 1
Create time
Reconstructing fields for mesh region0
Time = 1000
Reconstructing FV fields
--> FOAM FATAL ERROR:
Size of maps does not correspond to size of mesh for processor 0
faceProcAddressing : 123032 nFaces : 640997
cellProcAddressing : 39721 nCell : 203707
boundaryProcAddressing : 9 nFaces : 16
From function fvFieldReconstructor::fvFieldReconstructor
fvMesh&,
const PtrList<fvMesh>&,
const PtrList<labelIOList>&,
in file fvFieldReconstructor.C at line 66.
FOAM exiting
Old   November 29, 2013, 15:27
Bruno Santos
Greetings Sture,
A bit more information would come in handy. More specifically, what was the case set-up you've made and the steps you've taken up to the point where you tried to use reconstructPar.
Best regards,
Bruno
Old   November 30, 2013, 09:47
  #116
Sture Smidt
Thanks for your response!
I did:
  1. Set up a case with HelyxOS 2.0.0 in parallel on 6 processors
  2. Do the run
  3. Postprocess some in ParaView started from HelyxOS (then I can see a parallel case without reconstructing it)
  4. Close HelyxOS and ParaView
  5. Run preconstructPar (no qualifiers) from the case directory
  6. Then got the ERROR msg as above
If you need more info I will happily post it.
Rgds
Sture
Old   November 30, 2013, 12:10
Daniel P. Combest
Sture,
Have you reconstructed the serial mesh from your parallel generated mesh? You probably need to do something like
reconstructParMesh -constant -mergeTol 1e-6
or similar to reconstruct your mesh and then reconstructPar your latest times to map your fields to your reconstructed mesh. There is a thread which encounters the same error you are and does exactly this procedure
http://www.cfd-online.com/Forums/ope...tml#post337465
Try that and see if it resolves your issue.
louisgag likes this.
Old   December 5, 2013, 16:46
Default Helyx OS 2.0.0
  #118
Sture Smidt
It works like a charm in the new version.
chegdan likes this.
Old   February 13, 2014, 04:33
JCFD
jlp56 is on a distinguished road
I previously asked this on sourceforge but was redirected here: The gui looks great from the screenshots so I am keen to try it. I am running into problems installing the bin file on mac osx - during the install, at the select install directory prompt it doesn't seem to recognise any destination I give it. It always returns "destination doesn't exist". Any pointers would be greatly appreciated.
Cheers
jlp56 is offline   Reply With Quote
Old   February 20, 2014, 08:19
Andrew
Antech is on a distinguished road
Hello.
I'm getting started with OpenFOAM and find it convenient enough to use Helyx-OS to create mesh and manage cases. First I tried to create a mesh and encountered a problem. Official Helyx-OS v2.0.0 successfully read my STL geometry that contains many small elements (small holes on perforated plate). Base (block) mesh generates and snappyHexMesh then works (launched from Helyx-OS interface) but it's too coarse (it doesn't even "catch" the holes). Okay, I set Geometry => My geometry => Refinement => SURFACE => Min and Max levels (doesn't matter what levels, say 1 and 10). I click Create button and mesh is built. But no any refinement occures. And when I look at the Min and Max levels for surface refinement in Helyx-OS interface there are all zeroes. Why does it happen? How can I avoid this and apply surface refinement?
STL is large enough (50+ MiB) but if it matters I'll upload it with the whole test case.
Thanks for attension.
Antech is offline   Reply With Quote
cases setup, preprocessor, snappyhexmesh
Helyx-OS Open Source GUI for OpenFOAM eugene OpenFOAM Announcements from Other Sources 31 March 9, 2020 17:55
TUI Commands from GUI? Carlos FLUENT 6 May 22, 2013 19:05
User Defined GUI Frederik FLUENT 0 June 23, 2006 17:12
Command Line vs. GUI Menus Go FLUENT 0 June 8, 2005 17:05
GUI window settings cmv Siemens 0 February 7, 2005 07:22
