[snappyHexMesh] Snappyhexmesh- pont inside mesh
Like Tree1Likes
  • 1 Post By elvis
Old   July 24, 2012, 06:42
Default Snappyhexmesh- pont inside mesh
Alessandro Pani
Dr.Faustus is on a distinguished road
hi to everybody
i'm founding great difficulties to find the internal point of the mesh
(moreover, i'm not so sure of what this point does)
even if i insert a point on the bounding box it will be shown an error message like this...
--> FOAM FATAL ERROR:
Point (0 0 1.9) is not inside the mesh or on a face or edge.
Bounding box of the mesh:(-4 -1.95 -4) (8 0.05 4)
Dr.Faustus is offline   Reply With Quote
Old   July 25, 2012, 05:02
Elvis
elvis will become famous soon enough
there is a brilliant tutorial (download and untar it "tar -xzf ") I believe it will guide you throught most of your SHM questions
wyldckat likes this.
elvis is offline   Reply With Quote
Old   July 25, 2012, 06:37
Alessandro Pani
Sorry, but the link doesn't work
Anyway i've found the problem: i was building a blockmesh with an incorrect position of vertexs, so the system of reference was badly rotated
Old   August 17, 2012, 08:03
Eloïse
Eloise is on a distinguished road
Hi!
The link to this tutorial is dead, could you update it?
Thanks
Eloise is offline   Reply With Quote
Old   August 17, 2012, 08:57
colinB is on a distinguished road
Hey there,
the site mentioned above is under attack as you can read here:
http://www.cfd-online.com/Forums/ope...er-attack.html
so I guess so far there is no alternative link until everything is restored
regards
colinB is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 06:53
[snappyHexMesh] problem with snappyHexMesh kanes OpenFOAM Meshing & Mesh Conversion 10 January 26, 2016 07:11
[snappyHexMesh] Error with a turbine mesh with SnappyHexMesh DOliveira OpenFOAM Meshing & Mesh Conversion 1 July 16, 2015 09:02
[snappyHexMesh] Inside and outside mesh with snappyhexmesh nzy102 OpenFOAM Meshing & Mesh Conversion 0 September 1, 2008 00:50
