[Commercial meshers] fluent3DMeshToFoam
Old   March 21, 2013, 05:46
Default fluent3DMeshToFoam
Sasan Ghomi
sasanghomi is on a distinguished road
Hi foamers ,
We know that for importing 2D mesh to openfoam (from GAMBIT) we can use fluentMeshToFoam -writeSets
This command creates a Sets folder in the polymesh directory and you can see faces of all boundaries...
How can I do this action for importing 3D mesh??? I want to importing a 3D mesh from GAMBIT to openfoam and I want to have a Sets file including faces of all boundaries..
any utilities? any commands???
Thanks and best regards,
Sasan.
sasanghomi is offline   Reply With Quote
Old   March 21, 2013, 07:41
Olivier
olivierG is on a distinguished road
hello,
In fact fluentMeshToFoam work with 3D mesh too, so the same with "-writeSets" will work.
You can also use fluent3DMeshToFoam, which does almost the same as "fluentMeshToFoam -writeSets -writeZones".
Regards,
olivier
olivierG is offline   Reply With Quote
Old   March 21, 2013, 11:27
Sasan Ghomi
Dear Olivier ,
fluent3DMeshToFoam -writeSets doesn't work...(I am using 1.6-ext)
I appreciate any help....
Thanks,
Sasan.
Old   March 21, 2013, 11:37
Olivier
hello,
This is because with fluent3DMeshToFoam, you don't need the "-writeSets" options, just "fluent3DMeshToFaom mesh.msh" will be fine.
regards,
olivier
Old   March 21, 2013, 13:22
Sasan Ghomi
I want to have a Sets file including faces of all boundaries....for 3D mesh...
How can I do this action??
thanks,
Sasan.
Old   March 22, 2013, 02:26
Sasan Ghomi
I got it....
patchToFace can do this action...
Sasan.
Old   March 26, 2013, 12:42
Dogan
dogan is on a distinguished road
Hi Sasan,
i am also dealing with fluent3DMeshToFoam, and i also need the sets file in polyMesh directory. As you also had the same problem, fluent3DMeshToFoam command doesn't create a sets directory inside of the polyMesh directory. You mentioned that patchToFace can do this actioin, but i am using openFoam 2.1.x, and i don't know how to create the sets file in 2.1.x.
thanks
Dogan
dogan is offline   Reply With Quote
Old   March 26, 2013, 15:00
Sasan Ghomi
Hi Dear dogan ,
You can use faceSetDict :
| \\      /  F ield         | OpenFOAM Extend Project: Open Source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      faceSetDict;
name faceSet;
action new;
topoSetSources
  patchToFace
       name presin; // name of boundary faces
Create this file in the system directory and type below command in the terminal :
faceSet
But this idea doesn't support interior faces because OpenFOAM doesn't know interior faces as a boundary face...
I think this utility exists in all versions of OpenFoam.
best regards,
Sasan.
Old   April 2, 2013, 06:21
Dogan
Hi Sasan,
thank youz very much for your answer. I don't know why, but unfortunately i couldn't mabage to do it with faceSetDict. it may not be the right way but i tried something else, and it worked. i copied the points file in constant, to the rotor file in constant>sets. i know it souds so wrong, but it worked.
thanks and regards
Dogan
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
periodic (cyclic) boundary - fluent3DMeshToFoam cyln OpenFOAM 1 October 17, 2017 03:59
[Commercial meshers] fluent3DMeshToFoam conversion problem CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 14 March 12, 2014 06:16
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
OpenFOAM command from inside MATLAB sega OpenFOAM Post-Processing 18 September 25, 2012 08:35
