[Other] Mesh Conversion: OpenFoam (polyMesh format) to Calculix
Like Tree1Likes
  • 1 Post By hjasak
Old   April 21, 2015, 08:18
Default Mesh Conversion: OpenFoam (polyMesh format) to Calculix
gillers18 is on a distinguished road
Hello All,
Currently working on a Problem dealing with Fluid Sturcture Interaction using the both programms OpenFoam and Calculix. I have already done the CFD Simulation in Open Foam and the results have been stored in OpenFoam polymesh format. Now I would like to use these Results to perform the FEM-Simulation, but Calculix canīt read these results because the exported polymesh contains some elements, which are not available in Calculix(only Hexa8 elements are supported).
How do i go about converting the polymesh from Openfoam in a mesh format with only hexa8 elements? Is there a converter available for this case?
Best Regards
Thierry
gillers18 is offline   Reply With Quote
Old   April 22, 2015, 04:37
Hrvoje Jasak
You need to decompose the polyhedral cells into shapes your software can understand. Paraview converter/module has a similar problem, so you can find code snippets there.
Hrv
gillers18 likes this.
Hrvoje Jasak
Old   April 24, 2015, 04:37
Thx fo your help. I really appreciate it.
Actually I m not used to work with the Paraview Converter /Module. Could you please explain me how to go about finding the code snippets on that module, which could help me to decompose the Polyhedral cells?
Best Regards
Thierry
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
[Commercial meshers] mesh conversion from ansys mesher to openfoam Dusan1224 OpenFOAM Meshing & Mesh Conversion 2 November 5, 2015 04:41
[Salome] Mesh conversion Salome to OpenFOAM VMartinez OpenFOAM Meshing & Mesh Conversion 11 April 21, 2014 03:54
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
