[Other] Create a Mesh with Sketchup and Tetgen
Old   February 4, 2015, 02:53
Default Create a Mesh with Sketchup and Tetgen
Peter
opedrofunk is on a distinguished road
Here's a simple, free preprocessor/mesh generation utility.
Its a plugin for Sketchup (http://www.sketchup.com)(also free) to facilitate mesh generation with Tetgen (http://wias-berlin.de/software/tetgen/) . Supports complex geometry, multiple regions, boundaries, and refinement (both boundary and volume based). Makes generating a quality mesh with boundary markers quick and easy for complex geometry.
Check it out:
https://extensions.sketchup.com/en/c...y-tetgen-tools
Hope this helps!
Regards,
Peter
opedrofunk is offline   Reply With Quote
Old   February 17, 2015, 19:02
Default tetgen-sketchup
Abhinay
soankerabhinay is on a distinguished road
I did generate .smesh file using sketchup and was wondering how to run in tetgen and generate mesh files (.ele .node .face)
I never used tetgen directly, but used gibboncode (matlab interface for tetgen) to generate tetgen files!
Thank you!
-Abhinay
soankerabhinay is offline   Reply With Quote
Old   February 17, 2015, 19:30
Peter
Sure, no problem. Tetgen is a command-line tool. To start using tetgen you need to:
1) Download tetgen here: http://wias-berlin.de/software/tetgen/
2) Compile (very simple for tetgen)
Tetgen provides many options; these are detailed on the site. However, if using the sketchytetgentools sketchup preprocessor for OpenFoam, the ones of most interest probably are:
-p triangulate a plc (the smesh file)
-q create a quality mesh (also accepts parameters to control quality)
-m use the boundary sizing functions (the .mtr file generated)
-A apply the region/boundary attributes (important)
-a if you specified a tet size on the region, this flag will cause tetgen to enforce that
I typically specify refinement on the boundaries (i.e., using the mtr file), so the command and options I most commonly use are:
$ tetgen -pq1.414Am input_file.smesh
Hopefully, that should be enough to get started. After that, have a look at the documentation and try a few combinations :-)
Kind regards,
Peter
Old   February 18, 2015, 00:59
Abhinay
I did download the file! I am confused with platform I need to run this code $ "tetgen -pq1.414Am input_file.smesh." where do I have to type this command, is it the C++ platform or some other command line tool ?
Sorry for the ignorance! but please bear with my questions! Thank you
Old   February 18, 2015, 02:51
Peter
Are you running linux? Windows? Mac?
Old   February 18, 2015, 02:55
Abhinay
windows!!!!
Best Mesh generation software ehsanakrami Mesh Generation & Pre-Processing 3 February 4, 2015 02:45
