[Gmsh] False name of internal faceZone/faceSet by Gmsh
Like Tree1Likes
  • 1 Post By Hisham
Old   November 29, 2012, 09:01
Default False name of internal faceZone/faceSet by Gmsh
Hisham's Avatar
Hisham Elsafti
Hisham is on a distinguished road
Dear Foamers,
I try to make an internal faceZone/faceSet in a Gmsh geometry. I defined a physical surface of the internal surfaces in question. I run
gmsh -3 file.geo; gmshToFoam file.msh
. By viewing the output in paraFoam, the faceZone/faceSet exists but has a different name than the physical surface. It has the name of a cellZone that is not even adjacent to the surfaces.
Question time:
1. Did anyone face the same problem or has anyone produced internal faceZones without this problem?
2. Is there a workaround?
Best regards,
Hisham
Hisham is offline   Reply With Quote
Old   November 29, 2012, 10:25
Hisham's Avatar
Hisham Elsafti
It seems that there is a bug in gmshToFoam. Changing:
01058         forAll(zoneFaces, zoneI)
01059         {
01060             if (zoneFaces[zoneI].size())
01061             {
01062                 label physReg = zoneToPhys[zoneI];
01063
01064                 Map<word>::const_iterator iter = physicalNames.find(physReg);
01065
01066                 word zoneName = "faceZone_" + name(zoneI);
01067                 if (iter != physicalNames.end())
01068                 {
01069                     zoneName = iter();
01070                 }
01071
01072                 Info<< "Writing zone " << zoneI << " to faceZone "
01073                     << zoneName << " and faceSet"
01074                     << endl;
to:
01059         {
01061             {
01062                 label physReg = patchToPhys[zoneI];
01063
01065
01068                 {
01070                 }
01071
01074                     << endl;
solves the problem for me!
Regards,
Hisham
Ramzy1990 likes this.
faceset, facezone, gmsh, gmshtofoam, internal face
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
[Gmsh] Internal faces from gmsh how to create patches in OpenFoam podallaire OpenFOAM Meshing & Mesh Conversion 27 April 25, 2012 22:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
