August 27, 2008, 15:01 |
compiling gmshFoam Error en make
blo blo
Rep Power: 17 |
Hi foamers,
I'm trying to compiile gmshFoam and i get an error on ./Allwmake. I began like this : $ cd $WM_PROJECT_USER_DIR/applications/utilities $ tar -zxf gmshFoam-YYYYMMDD.tar.gz $ ln -s gmshFoam-YYYYMMDD gmshFoam <<--- Necessary for gmshFoam to be recognized by FoamX $ cd gmshFoam then ./Allwmake and I get this : ... (several lines) /home/blo/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/polyMesh.H:254: note: candidates are: Foam::polyMesh::polyMesh(const Foam::IOobject&, const Foam::pointField&, const Foam::cellShapeList&, const Foam::faceListList&, const Foam::wordList&, const Foam::wordList&, const Foam::word&, const Foam::word&, const Foam::wordList&, bool) /home/blo/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/polyMesh.H:239: note: Foam::polyMesh::polyMesh(const Foam::IOobject&, const Foam::pointField&, const Foam::faceList&, const Foam::cellList&, bool) /home/blo/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/polyMesh.H:227: note: Foam::polyMesh::polyMesh(const Foam::IOobject&, const Foam::pointField&, const Foam::faceList&, const Foam::labelList&, const Foam::labelList&, bool) /home/blo/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/polyMesh.H:215: note: Foam::polyMesh::polyMesh(const Foam::IOobject&) /home/blo/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/polyMesh.H:162: note: Foam::polyMesh::polyMesh(const Foam::polyMesh&) polyMeshConversion/polyMeshConversion.C: In member function 'Foam::polyMeshConversion* Foam::polyMeshConversion::renumberedMesh(Foam::lab el) const': polyMeshConversion/polyMeshConversion.C:231: error: 'allFaces' was not declared in this scope polyMeshConversion/polyMeshConversion.C:264: error: 'allPoints' was not declared in this scope make: *** [Make/linux64GccDPOpt/polyMeshConversion.o] Error 1 Any idea ? |
August 28, 2008, 09:20 |
Hi blo blo,
Sorry but it'll t
Takuya OSHIMA
Rep Power: 20 |
Hi blo blo,
Sorry but it'll take a while until I can have a look into the issue. Meanwhile you can try the genuine gmshToFoam. Takuya |
August 29, 2008, 09:01 |
Hi, thanks for the answer. Wha
blo blo
Rep Power: 17 |
Hi, thanks for the answer. What do you mean by 'genuine gmshToFoam' ?
Best regards. |
April 5, 2009, 06:55 |
Luca COLZANI
Rep Power: 17 |
Hello everyone,
I've got exactly the same 'Error 1' as blo listed. I am used to the genuine gmshToFoam, but with it I'm not able to set more than one patch without getting my hands into the text file. I think that gmsh2ToFoam should have solved this problem, right? Thank you so very much for your support, guys. Luca |
April 5, 2009, 08:54 |
Takuya OSHIMA
Rep Power: 20 |
Hi Luca,
Did you try the SVN-version? If not can you get the version with svn co https://of-interfaces.svn.sourceforg...trunk/gmshFoamand see if it works? |
October 5, 2009, 12:37 |
Dennis Rown
Rep Power: 17 |
Hello!
I am getting this problem, too. Does someone know why this occurs? Greets |
October 6, 2009, 11:12 |
#10 |
Dennis Rown
Rep Power: 17 |
Hi! I meant the:
"polyMeshConversion/polyMeshConversion.C:231: error: 'allFaces' was not declared in this scope polyMeshConversion/polyMeshConversion.C:264: error: 'allPoints' was not declared in this scope make: *** [Make/linux64GccDPOpt/polyMeshConversion.o] Error 1 " By the way, I am trying to install the gmsh2ToFoam into my USER OpenFoam directory (where originally only the folder "tutorials" exist and I had to create the folders "application/utilities..." Does this play a role? |
October 6, 2009, 12:27 |
#11 | |
Takuya OSHIMA
Rep Power: 20 |
So, my comment on another thread was
October 8, 2009, 06:18 |
#12 |
Dennis Rown
Rep Power: 17 |
Hello 7islands!
I somehow cannot install SVN (don't have the rights to install apr which seems to be needed for SVN). Could you upload the actual SVN of gmsh2ToFoam into a tar file? |
[foam-extend.org] OF-extend 4.0: compiling with CUDA | jgross | OpenFOAM Installation | 5 | December 8, 2022 09:35 |
[OpenFOAM.org] Compiling OpenFOAM 5.0 on the Titan Supercomputer | wildfire230 | OpenFOAM Installation | 20 | May 6, 2020 08:30 |
[waves2Foam] Waves2Foam Related Topics | ngj | OpenFOAM Community Contributions | 660 | August 20, 2018 13:39 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 03:32 |
a way to make lots of money quick and easy no lies | Dob | Main CFD Forum | 0 | October 10, 2006 17:45 |
