November 11, 2009, 01:48 |
connecting 2 blocks
Alex Christantho
Rep Power: 17 |
I'm using buoyantPisoFoam solver for this case. I made 2 similar blocks, with 1 block adjacent to other.
Here is the blockMeshDict file: FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( (0 0 0) (10 0 0) (10 5 0) (0 5 0) (0 0 10) (10 0 10) (10 5 10) (0 5 10) (10 0 0) (20 0 0) (20 5 0) (10 5 0) (10 0 10) (20 0 10) (20 5 10) (10 5 10) ); blocks ( hex (0 1 2 3 4 5 6 7) (20 10 20) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (20 10 20) simpleGrading (1 1 1) ); edges ( ); patches ( wall floor ( (0 4 7 3) ) wall ceiling ( (10 14 13 9) ) wall fixedWalls ( (3 7 6 2) (2 6 5 1) (1 5 4 0) (0 3 2 1) (4 5 6 7) (11 15 14 10) (8 12 15 11) (9 13 12 8) (8 11 10 9) (12 13 14 15) ) ); mergePatchPairs ( ); // ************************************************** *********************** // the 0/T file is: dimensions [0 0 0 1 0 0 0]; internalField uniform 300; boundaryField { floor { type fixedValue; value uniform 300; } ceiling { type fixedValue; value uniform 320; } fixedWalls { type zeroGradient; } } and part of the controlDict file is: startFrom startTime; startTime 0; stopAt endTime; endTime 1000; deltaT 100; writeControl timeStep; writeInterval 1; When I'm using the solver, i got the error message: Maximum number of iterations exceeded#0 Foam::error::printStack(Foam::Ostream&) in "/home/alex/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/alex/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::hRhoThermo<Foam::pureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/home/alex/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" #3 Foam::hRhoThermo<Foam::pureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::correct() in "/home/alex/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" #4 main in "/home/alex/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/buoyantPisoFoam" #5 __libc_start_main in "/lib/libc.so.6" #6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 68. FOAM aborting I try to change the endTime to 300 and the process was successful, but the paraFoam looks strange. I attach 4 files, in t=0,t=100, t=200, and t=300. My questions are: 1. why I can't simulate until t=1000? 2. if I want to see the gradient of air temperature (different temperature inside the box, not an "uniform" color like this), what should I do? 3. what's going on with those pictures, specially for the last picture (t=300)? 4. how to delete the center wall that separate these 2 blocks? I try not to insert (2 6 5 1) and (8 12 15 11) in the patches, but there's a problem in generating the blockMesh.. Any help will be greatly appreciated.. Thanks! |
November 13, 2009, 06:14 |
#2 | |
Sebastian Gatzka
Rep Power: 20 |
Otherwise you have to specify a boundary condition which would make no sense inside your computational domain! Especially "wall" in your case! If there is a problem with blockMesh (please tell us what kind of problem) without (2 6 5 1) and (8 12 15 11) you should have to take a careful look, there maybe something else whats wrong - but this is on you! By the way: Why don't you use a single block?
Schrödingers wife: "What did you do to the cat? It's half dead!" |
November 15, 2009, 20:13 |
Alex Christantho
Rep Power: 17 |
Thanks for your information, Sebastian..
I'm not using a single block, because my "real" project needs more than 2 blocks that connected each other. before i go into that more complex situation, i think it will be easier to simulate simpler condition first (by using 2 blocks like this). after I used checkMesh, i got this information: there are 2 regions that not connected each other. and now i think this is the fundamental problem: I didn't connected them so each region will have its independent condition. am I right? so my next questions, is is possible to make these 2 regions connected each other without changing the blockMeshDict file? Thanks. |
November 20, 2009, 06:21 |
#4 | |
Sebastian Gatzka
Rep Power: 20 |
But you can make the two blocks connect by altering the blockMeshDict if the "touching faces" are not declared as boundary patches!
November 20, 2009, 06:47 |
Sebastian Gatzka
Rep Power: 20 |
One problem was that your vertices 1 and 8, 5 and 12, 6 and 15, 2 and 11 are identical.
So the skipping of (2 6 5 1) and (8 12 15 11) in the patch-part of blockMesh was not enough. You even had to skip building the blocks out of different vertice numbers even if they are geometrically identical. The connection of the blocks is obviously done by choosing identical vertice numbers! Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: http://www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( (0 0 0) (10 0 0) (10 5 0) (0 5 0) (0 0 10) (10 0 10) (10 5 10) (0 5 10) (10 0 0) (20 0 0) (20 5 0) (10 5 0) (10 0 10) (20 0 10) (20 5 10) (10 5 10) ); blocks ( hex (0 1 2 3 4 5 6 7) (20 10 20) simpleGrading (1 1 1) hex (1 9 10 2 5 13 14 6) (20 10 20) simpleGrading (1 1 1) ); edges ( ); patches ( wall floor ( (0 4 7 3) ) wall ceiling ( (10 14 13 9) ) wall fixedWalls ( (3 7 6 2) // (2 6 5 1) (1 5 4 0) (0 3 2 1) (4 5 6 7) (2 6 14 10) // (8 12 15 11) (9 13 5 1) (1 2 10 9) (5 13 14 6) ) ); mergePatchPairs ( ); // ************************************************** *********************** //
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface | manuc | OpenFOAM Meshing & Mesh Conversion | 1 | July 25, 2017 04:13 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 06:59 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 17:14 |
[Other] How to create an MRF zone ? | aminem | OpenFOAM Meshing & Mesh Conversion | 2 | December 8, 2014 11:45 |
[ICEM] Connecting of Blocks | FrankW | ANSYS Meshing & Geometry | 4 | May 15, 2012 11:05 |
