[blockMesh] defining and connecting two circular pipes using blockMesh
Like Tree3Likes
  • 1 Post By Yosmcer
  • 2 Post By Yosmcer
Old   July 29, 2013, 11:42
Default defining and connecting two circular pipes using blockMesh
Hale
Hale is on a distinguished road
I'm having trouble in defining two circular pipes that are connected with an angle of 90 degrees using blockMesh.
Is there any tutorials or any example that shows how to define such a L-shaped circular pipe in openfoam?
thanks alot
Hale is offline   Reply With Quote
Old   July 29, 2013, 18:22
Yosmcer Mocktai
Yosmcer will become famous soon enough
You can make this with a block and some edges.
Here are two examples I just made. You can copy it and adapt to your needs:
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 1.292893219 0.707106781)//0
(0 2.707106781 0.707106781)//1
(0 2.707106781 -0.707106781)//2
(0 1.292893219 -0.707106781)//3
(2.707106781 0 0.707106781)//4
(1.292893219 0 0.707106781)//5
(1.292893219 0 -0.707106781)//6
(2.707106781 0 -0.707106781)//7
blocks
hex (5 4 7 6 0 1 2 3) (50 50 50) simpleGrading (1 1 1)
edges
arc 0 1 (0 2 1)
arc 1 2 (0 3 0)
arc 2 3 (0 2 -1)
arc 3 0 (0 1 0)
arc 4 5 (2 0 1)
arc 5 6 (1 0 0)
arc 6 7 (2 0 -1)
arc 7 4 (3 0 0)
arc 0 5 (0.914213563 0.914213563 0.707106781)
arc 3 6 (0.914213563 0.914213563 -0.707106781)
arc 1 4 (1.914213562 1.914213562 0.707106781)
arc 2 7 (1.914213562 1.914213562 -0.707106781)
boundary
mergePatchPairs
or
FoamFile
version 2.0;
format ascii;
class dictionary;
convertToMeters 1;
vertices
(0 1 0)//0
(0 2 1)//1
(0 3 0)//2
(0 2 -1)//3
(3 0 0)//4
(2 0 1)//5
(1 0 0)//6
(2 0 -1)//7
blocks
hex (5 4 7 6 1 2 3 0) (50 50 50) simpleGrading (1 1 1)
edges
arc 0 1 (0 1.292893219 0.707106781)
arc 1 2 (0 2.707106781 0.707106781)
arc 2 3 (0 2.707106781 -0.707106781)
arc 3 0 (0 1.292893219 -0.707106781)
arc 4 5 (2.707106781 0 0.707106781)
arc 5 6 (1.292893219 0 0.707106781)
arc 6 7 (1.292893219 0 -0.707106781)
arc 7 4 (2.707106781 0 -0.707106781)
arc 0 6 (0.707106781 0.707106781 0)
arc 1 5 (1.414213562 1.414213562 1)
arc 2 4 (2.121320344 2.121320344 0)
arc 3 7 (1.414213562 1.414213562 -1)
boundary
mergePatchPairs
Theses two edge pipe are are quite similar, but depending of how you made the pipes you want to connect, you may prefer one way to the other.
Theses case are quite general with pipes of radius 1 and small curve radius to 1 too (you may need to not have this curve).
m.b. likes this.
Yosmcer is offline   Reply With Quote
Old   July 30, 2013, 06:43
Hale
Thank you very much Yosmcer. It was a great help Would you please tell me how you calculated the arc midpionts?
Old   July 30, 2013, 11:52
Yosmcer Mocktai
I used the Pythagoras theorem with the simplified fact that the triangles were isosceles.
So basically, for a radius circle (hypotenuse) of 1, I have sqrt(2)/2.
For more general shapes, you can use trigonometry.
ramakant and m.b. like this.
Old   July 31, 2013, 08:10
Hale
Thanks you very much for the explanation.
defining cells where connecting to one node Asghari FLUENT 0 July 11, 2006 10:36
