January 29, 2012, 05:28 |
OpenFOAM Installation
Meisam
Rep Power: 14 |
Dear friends,
can you help me for OpenFOAM installation, please? I attempted to install the OpenFOAM, but I could not overcome. would I should install Debian pack and then install Source pack or in the first step I should install the Source pack? Essentially, what sections of the OpenFoam site should be installed by me? Thanks a lot. |
January 29, 2012, 10:46 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Meisam and welcome to the forum!
Well, it basically depends on what your goals are. But if you are just getting started, then simply follow the instructions for the Debian pack, assuming of course that you have installed Ubuntu or Debian: http://www.openfoam.org/download/ubuntu.php The system was broken yesterday, but today it should be working! Best regards, Bruno
January 29, 2012, 11:57 |
#3 | |
Meisam
Rep Power: 14 |
Thank you Bruno I think that installing the source pack is necessary, is it? I explain my installation process in bellow: 1- VERS=`lsb_release -cs` 1- sudo sh -c "echo deb http://www.openfoam.org/download/ubuntu $VERS main >.... 2- sudo apt-get update 3- sudo apt-get install openfoam210 but after downloading some files, I encountered with following error: Failed to fetch http://www.openfoam.com/download/ubu...1_0-1_i386.deb Got a single header line over 360 chars E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? what do I need to perform? thanks |
January 29, 2012, 12:27 |
#4 | |
Bruno Santos
Rep Power: 128 |
Mmm... I thought that had already been fixed. I guess that when connections are too far away, they still get bounced around.
OK, the not so pretty way of doing this is to run the following commands... and be sure that you fully copy-paste each line, otherwise it will not work as intended: Quote:
Best regards, Bruno
January 30, 2012, 14:41 |
#5 | |
Meisam
Rep Power: 14 |
thanks I should test it . |
January 31, 2012, 03:46 |
Meisam
Rep Power: 14 |
Dear Bruno,
Thanks for your kindness. I ran these three line in terminal after running the following line : apt-get install openfoam170 apt-get install paraviewopenfoam380 but I received error comments as follow: E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission denied) E: Unable to lock the administration directory (/var/lib/dpkg/), are you root? Do I can install OpenFOAM finally? I need to install that for my thesis. thanks. |
January 31, 2012, 16:43 |
Bruno Santos
Rep Power: 128 |
Hi Meisam,
I'm not quite certain why you are stepping back into the past and installing that version, but anyway this should work: Code:
sudo apt-get install openfoam170 sudo apt-get install paraviewopenfoam380 Best regards, Bruno
[OpenFOAM.com] OpenFOAM 1.7.1 installation on LINUX UBUNTU 10.10 | electrosin | OpenFOAM Installation | 40 | May 31, 2016 06:11 |
Installation of OpenFOAM 1.7.1 to OprnSUSE 11.2 | superfxfund | OpenFOAM Installation | 3 | November 11, 2010 03:15 |
OpenFOAM Installation Ubuntu 9.04 Problems | Sumontro | OpenFOAM Installation | 8 | July 21, 2009 22:40 |
Some Query on Installation of OpenFoam | lzgwhy | OpenFOAM Installation | 1 | July 15, 2009 04:20 |
Problem in installation of OpenFOAM | sachin | OpenFOAM Installation | 7 | January 22, 2008 02:40 |
