June 30, 2011, 19:00 |
#21 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Maurizio,
Check my blog post again! I have now updated the post to teach how to modify both OpenFOAM 1.7 and 2.0 Best regards, Bruno
July 4, 2011, 06:38 |
#22 |
Rep Power: 17 |
Hi, Bruno.
I think there was a misunderstanding - or maybe I was not able to get the right infos from your guide about ParaView. Anyway, today I'm not working with OpenFOAM 1.5-dev and the same computer as in last days (I have it back in one week), but I've just installed OpenFOAM 1.6-ext via CAE Team PPA on a new computer and I guess the procedure could be similar - from what I need for OpenFOAM 1.5-dev on the first one. In other words, $WM_PROJECT_DIR/etc/bashrc contains this rem lines (I'm talking about OpenFOAM 1.6-ext): Code:
# Source user setup files for optional packages # ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ # _foamSource $WM_PROJECT_DIR/etc/apps/paraview/bashrc # _foamSource $WM_PROJECT_DIR/etc/apps/paraview3/bashrc #_foamSource $WM_PROJECT_DIR/etc/apps/ensight/bashrc Thanks again for your help and pardon for my ignorance about linux and OpenFOAM :-/ |
July 4, 2011, 20:34 |
#23 |
Bruno Santos
Rep Power: 128 |
Hi Maurizio,
I'm sorry, I got lost in my own train of thought back then OK, modifying paraFoam in 1.5-dev and 1.6-ext is not necessary at all ! It's a script originally named pvFoam, it's not the original paraFoam script So it will open .foam by default Says so on the line: Code:
ext=foam
Best regards, Bruno
Last edited by wyldckat; July 4, 2011 at 20:43. Reason: fixed a few typos... and forgot about a detail... |
July 6, 2011, 09:19 |
#24 |
Rep Power: 17 |
Hi Bruno,
now my $WM_PROJECT_DIR/etc/bashrc (OpenFOAM 1.6-ext via CAE Team PPA) includes Code:
# Source user setup files for optional packages # ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ # _foamSource $WM_PROJECT_DIR/etc/apps/paraview/bashrc # _foamSource $WM_PROJECT_DIR/etc/apps/paraview3/bashrc #_foamSource $WM_PROJECT_DIR/etc/apps/ensight/bashrc _foamSource /opt/openfoam200/etc/config/paraview.sh Thank you, thank you very much for your help. I owe you a dinner, when you're in Venice or Trieste (Italy) :-) |
July 6, 2011, 20:10 |
#25 | ||
Bruno Santos
Rep Power: 128 |
Hi Maurizio,
Best regards, Bruno
[OpenFOAM] ParaFoam instalation in OpenFoam 1.5 dev | titio | ParaView | 2 | July 25, 2010 00:24 |
OpenFOAM 1.5 dev | LVDH | OpenFOAM | 98 | May 5, 2010 18:01 |
[OpenFOAM] ParaView/ParaFoam in OpenFoam 1.5 dev | titio | ParaView | 2 | February 27, 2010 15:02 |
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev | titio | ParaView | 0 | December 9, 2009 13:13 |
[OpenFOAM] Paraview/Parafoam in OpenFoam 1.5 dev | titio | ParaView | 0 | December 9, 2009 13:12 |
