OpenFOAM-1.7.0 for CentOS/RHEL/SL 5.x 64bit released |
June 25, 2012, 05:21 |
#61 | |||
Jindo
Rep Power: 15 |
thanks phuc |
June 25, 2012, 19:09 |
#62 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings phuchuynh,
I can't go into much details about this, so I'll point you to a couple of possibilities:
Bruno
October 9, 2012, 16:14 |
#63 |
I'm looking into using paraview on my shared cluster. I just want to clarify, your tarball for paraview 3.14 on your sourceforge page runs on OpenMPI not mpich?
October 10, 2012, 02:39 |
#64 |
Niels Nielsen
Rep Power: 27 |
Hi, Yes that is correct.
Linnemann PS. I do not do personal support, so please post in the forums. |
November 29, 2012, 03:11 |
#65 |
Short tip from me:
centFoam.py script works perfectly, except one has to fix installation path in the etc/bashrc as following: Code:
########################################### # USER EDITABLE PART: Changes made here may be lost with the next upgrade # # either set $FOAM_INST_DIR before sourcing this file or set # 'foamInstall' below to where OpenFOAM is installed # # Location of the OpenFOAM installation # ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ foamInstall=/home/my_OF_user/centFOAM/$WM_PROJECT #foamInstall=$HOME/$WM_PROJECT Alex
Best regards, Dr. Alexander VAKHRUSHEV Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics" Simulation and Modelling of Metallurgical Processes Department of Metallurgy University of Leoben http://smmp.unileoben.ac.at |
October 24, 2013, 15:06 |
#66 |
Vishal Nandigana
Rep Power: 18 |
Hi Linnemann,
I was reading your posts on OF installation on CentOS and Rocks cluster. I am trying to install CENTFOAM on my cluster using your link "http://sourceforge.net/apps/mediawiki/centfoam/index.php?title=Main_Page". However, the version of our CentOS is 4.4, while I see that your installation procedure is for 5.x. Does the procedure still be valid for 4.x operating system. Please let me know. Thanks Regards, Vishal |
October 26, 2013, 14:04 |
#67 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Vishal: Which version of OpenFOAM are you looking for to install on your CentOS 4.4? Because AFAIK, CentFOAM only supports CentOS 5.x and 6.x: http://sourceforge.net/projects/centfoam/files/ - and it's unlikely that any of those binaries will work on CentOS 4.x Best regards, Bruno edit: Moved Vishal's answer to here: http://www.cfd-online.com/Forums/ope...ata_found.html
OpenFOAM 1.7.0 Released | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 1 | May 26, 2011 04:09 |
OpenFOAM 1.7.0 on OpenSUSE 11.1 | Bufacchi | OpenFOAM Installation | 8 | August 6, 2010 10:57 |
OpenFOAM Version 1.4.1 Released | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | August 3, 2007 08:31 |
OpenFOAM Version 1.3 Released | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | March 29, 2006 19:06 |
OpenFOAM Version 1.1 Released | OpenFOAM discussion board administrator | OpenFOAM Announcements from ESI-OpenCFD | 0 | March 11, 2005 06:33 |
