OpenFOAM-1.7.0 for CentOS/RHEL/SL 5.x 64bit released
Like Tree1Likes
Old   July 5, 2010, 10:17
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
OK, but then I dont understand from where you managed to run
the configure script when you got the error in the first place.
N
niklas is offline   Reply With Quote
Old   July 5, 2010, 10:24
niklas's Avatar
Niklas Nordin
I just checked your error message and saw that its located in
/home/user/build/gcc-4.4.4/build
which makes me wonder if your foam intallation is located under your home-catalog,
because if it isnt the configure script needs to be adjusted accordingly.
N
Old   July 5, 2010, 10:43
bhh
Bjorn H. Hjertager
bhh is on a distinguished road
Niklas,
Yes the gcc.4.4.4 is located as you saw also confirmed below. This became so after following the recipe from Niels. The OpenFOAM is located in:
[user@OpenFOAM OpenFOAM]$ ls
OpenFOAM-1.6 OpenFOAM-1.7.0.gtgz.1 ThirdParty-1.7.0 user-1.6
OpenFOAM-1.6.x OpenFOAM-1.7.x ThirdParty-1.7.0.gtgz
OpenFOAM-1.7.0 ThirdParty-1.6 ThirdParty-1.7.0.gtgz.1
OpenFOAM-1.7.0.gtgz ThirdParty-1.6.x ThirdParty-1.7.x
[user@OpenFOAM OpenFOAM]$ pwd
/home/user/OpenFOAM
Bjorn
___________________________________
checking for suffix of object files... configure: error: in `/home/user/build/gcc-4.4.4/build/i686-pc-linux-gnu/libgcc':
configure: error: cannot compute suffix of object files: cannot compile
See `config.log' for more details.
make[2]: *** [configure-stage1-target-libgcc] Error 1
make[2]: Leaving directory `/home/user/build/gcc-4.4.4/build'
make[1]: *** [stage1-bubble] Error 2
make[1]: Leaving directory `/home/user/build/gcc-4.4.4/build'
make: *** [all] Error 2
[user@OpenFOAM build]$ pwd
bhh is offline   Reply With Quote
Old   July 6, 2010, 06:37
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
adding these lines to your $HOME/.bashrc file should make it possible to compile gcc-4.4.4
export LD_LIBRARY_PATH=$HOME/OpenFOAM/ThirdParty-1.7.0/platforms/linux/gmp-5.0.1/lib:$LD_LIBRARY_PATH
export  LD_LIBRARY_PATH=$HOME/OpenFOAM/ThirdParty-1.7.0/platforms/linux/mpfr-2.4.2/lib:$LD_LIBRARY_PATH
Please make sure these paths exists by doing
ls -l $HOME/OpenFOAM/ThirdParty-1.7.0/platforms/linux/gmp-5.0.1/lib
ls -l $HOME/OpenFOAM/ThirdParty-1.7.0/platforms/linux/mpfr-2.4.2/lib
If these directories do exists go into the $HOME/build/gcc-4.4.4/build folder and issue
. $HOME/.bashrc
make -j2
This worked for me in 64bit getting the same error you posted.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   July 6, 2010, 08:11
bhh
Bjorn H. Hjertager
Niels,
I tried your new scheme and it did not give any errors. I take that I should execute 'make install ' and follow your instructions from before.
When I came to OpenFOAM OpenFOAM-1.7.0] and execute ./Allwmake I got these errors:
+ wmake libso OpenFOAM
SOURCE=global/global.Cver ; sed -e 's/VERSION_STRING/1.7.0/' -e 's/BUILD_STRING/1.7.0-21131bcbd876/' $SOURCE > Make/linuxGccDPOpt/global.C; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/user/OpenFOAM/ThirdParty-1.7.0/zlib-1.2.3 -IlnInclude -I. -I/home/user/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linuxGccDPOpt/global.C -o Make/linuxGccDPOpt/global.o
SOURCE=global/argList/argList.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/user/OpenFOAM/ThirdParty-1.7.0/zlib-1.2.3 -IlnInclude -I. -I/home/user/OpenFOAM/OpenFOAM-1.7.0/src/OpenFOAM/lnInclude -I/home/user/OpenFOAM/OpenFOAM-1.7.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/argList.o
lnInclude/dictionaryTemplates.C: In member function ‘T Foam::dictionary::lookupOrDefault(const Foam::word&, const T&, bool, bool) const [with T = Foam::Switch]’:
global/argList/argList.C:396: instantiated from here
lnInclude/dictionaryTemplates.C:44: error: call of overloaded ‘Switch(Foam:Traits<Foam::Switch>)’ is ambiguous
lnInclude/Switch.H:140: note: candidates are: Foam::Switch::Switch(int)
lnInclude/Switch.H:134: note: Foam::Switch::Switch(bool)
lnInclude/Switch.H:62: note: Foam::Switch::Switch(const Foam::Switch&)
make: *** [Make/linuxGccDPOpt/argList.o] Error 1
Any guide for what went wrong?
rgds
Bjorn
Old   July 6, 2010, 08:40
linnemann's Avatar
Niels Nielsen
Hi
Did you remember to run Allwmake in the Thirdparty folder first?
What is the output of
OF17
which gcc
This should list gcc as located in $HOME/OpenFOAM/ThirdParty-1.7.0/platforms/linux/gcc-4.4.4/bin/gcc
If this is the case I have no idea what should be going on.
Linnemann
Old   July 6, 2010, 08:47
bhh
Bjorn H. Hjertager
Niels,
Yes, I did the procedure as you mention.
When I issue the command
which gcc I get
/usr/bin/gcc
This is not what you would expect? Any clue what is wrong?
Bjorn
Old   July 6, 2010, 08:54
linnemann's Avatar
Niels Nielsen
Hi is there anything in the folder
if not then the make install step did not install gcc-4.4.4 the right place.
as a side note open the openFOAM/etc/settings and check that the compiler version is as below
# Select compiler installation
# compilerInstall = OpenFOAM | system
: ${compilerInstall:=OpenFOAM}
I'm guessing this is set to system and it will fail.
After changing run
OF17
which gcc
again and check the output
Linnemann
Old   July 6, 2010, 09:09
bhh
Bjorn H. Hjertager
Niels,
That seemed to do the trick!
I changed the settings.sh file to (in red):
case "${compilerInstall:-OpenFOAM}" in
OpenFOAM)
case "$WM_COMPILER" in
Gcc)
# gcc_version=gcc-4.4.3
gcc_version=gcc-4.4.4
Now it compiles and probably will generate OF1.7.0
Bjorn
Old   July 6, 2010, 10:44
bhh
Bjorn H. Hjertager
Niels,
It compiled and passed the cavity check! Thank you very much for your help!
My next task will be to tray to install paraFoam.
Bjorn
PS! There were some warnings during the compilation (unused variables). Is this something that you also found? Will it be a problem?
Old   July 7, 2010, 10:00
bhh
Bjorn H. Hjertager
Following the successfull installation of OF1.7.0 on my 32 bit CentOS linux maschine I have now moved over to install paraFoam. The following error comes at the very end after the command ./makeParaView:
________________________________________
Linking CXX executable ../../../../bin/GraphicsCxxTests
../../../../bin/libvtkRendering.so.pv3.8: undefined reference to `QPainter::drawImage(QPointF const&, QImage const&)'
../../../../bin/libvtkRendering.so.pv3.8: undefined reference to `QTextDocument::setDocumentMargin(double)'
collect2: ld returned 1 exit status
make[2]: *** [bin/GraphicsCxxTests] Error 1
make[1]: *** [VTK/Graphics/Testing/Cxx/CMakeFiles/GraphicsCxxTests.dir/all] Error 2
Installation complete for paraview-3.8.0
Set environment variables:
export ParaView_DIR=/home/user/OpenFOAM/ThirdParty-1.7.0/platforms/linuxGcc/paraview-3.8.0
export PATH=$ParaView_DIR/bin:$PATH
export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.8
Done
Anybody out there that migth help me?
rgds
Bjorn
Old   August 13, 2010, 18:09
Default Didn't work at all.
  #32
sahm's Avatar
Seyyed Ali H.M.
sahm is on a distinguished road
Hi everyone
I tried to compile OF17, but got problems, then I saw this thread. I want to install it on a RHEL 5.0 64bit.
I don't have access to root, so I couldn't run the Yum command in post #4.
Then I went through gcc part, and got the same error as post #5 and #6.
Right now I have gcc 4.3.3 under OpenFoam 1.6 third parties, and my OF16 works perfectly.
But when I want to make gcc 4.4.4 I get error.
under OF17 environment, My Gcc is
/usr/bin/gcc
and under 1.6 its
~/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux64/bin/gcc
SAHM
sahm is offline   Reply With Quote
Old   August 14, 2010, 14:41
Default question
  #33
Silvano
Ti_Pago_Da_Bere is on a distinguished road
Send a message via Skype™ to Ti_Pago_Da_Bere
Guys, I have a question:
I have a cluster with 64bit RHEL 5.0, and previously I have installed OpenFoam 1.6 on it.
Can I replace all the source code for 1.7 with all the source code for 1.6 and wmake it?
does this work?
Ti_Pago_Da_Bere is offline   Reply With Quote
Old   August 16, 2010, 02:26
linnemann's Avatar
Niels Nielsen
Hi
@ SAHM
you need to edit the OpenFOAM settings.sh file to reflect where gcc is installed lige Bjorn did. With the compilation of GCC try and export the library path for mpfr and gmp in your .bashrc file like so.
export LD_LIBRARY_PATH=/pathToGmp/lib:$LD_LIBRARY_PATH
export LD_LIBRARY_PATH=/pathToMpfr/lib:$LD_LIBRARY_PATH
Source the .bashrc file
. $HOME/.bashrc
and try and compile gcc again.
OpenFOAM)
Gcc)
Bjorn
@ Ti_Pago_Da_Bere
I do not think that is possible. you can use the ThirdParty stuff from my binary release and then get the sources for OF and then do wmake. If you do it this way remember to change the settings.sh file like above.
Otherwise download both my packages and you are ready to run.
1.6 and 1.7 will live happily alongside each other on the same system and a good way to keep them seperate is to use aliases for them in your $HOME/.bashrc file like so.
alias OF16=". $HOME/OpenFOAM/OpenFOAM-1.6.x/etc/bashrc"
alias OF17=". $HOME/OpenFOAM/OpenFOAM-1.7/etc/bashrc"
Then if you run OF16 from terminal you will use OF 1.6 and if you type OF17 you will switch to OF 1.7.
Linnemann
Old   September 14, 2010, 02:57
dhoom is on a distinguished road
Hello Linneman,
I am trying to install CentFOAM and I am getting the following errors when
./centFOAMInstall yum all
No package ncurses-devel available.
No package libXt-devel available.
Nothing to do"
Thanks
D
dhoom is offline   Reply With Quote
Old   September 14, 2010, 10:01
Originally Posted by dhoom View Post
Hello Linneman,
Nothing to do"
Thanks
D
Phew!!! got the script to work.
sometimes I wish I could just disappear into one of those cracks on the walls.
Old   September 15, 2010, 13:26
anfho is on a distinguished road
Dear All,
is it possible to install the here cited version of CentFOAM on RHEL 4.1.2-46 (I do not know what SL 5.x stands for) on a cluster to which I do not have the root rights? I know the installation requires the "yum" command, which needs root rights that I do not have... Thanks!
Andreas
anfho is offline   Reply With Quote
Old   September 15, 2010, 14:10
linnemann's Avatar
Niels Nielsen
Hi
No that will not be possible. It is possible to get OF working on RHEL 4.x releases it will although take some time and will be somewhat more difficult if you cant install packages as root.
SL-5.x is Scientific Linux 5.x where x can be 0,1,2,3,4 or 5.
Best
Linnemann
Old   September 15, 2010, 18:47
Hi Linnemann,
thanks for the quick reply. More difficult but thankfully not impossible. According to other threads (http://www.cfd-online.com/Forums/ope...linux-5-a.html) it is possible to install gcc4.3.3 from OF1.6ThridParty and then use OF1.7.1 ... do you agree with that?
Thanks, Andreas
Old   September 16, 2010, 08:40
linnemann's Avatar
Niels Nielsen
Hi
If only you were that lucky, I've installed OF-1.5 on a RHEL 4 release and it was not the most trivial task :-) and 1.6 and 1.7 are most likely not easier.
There are some libraries in rhel 4 that are to old for gcc-4.3.x so you need to compile new ones of those and a whole lot of other stuff I cant remember.
But again Google is your friend
http://cheminsilico.blogspot.com/200...-on-rhel4.html
From here on you are on your own I'm afraid, unless some other member has a cluster/workstation with rhel/centos 4 on it.
Linnemann
OpenFOAM 1.7.0 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 1 May 26, 2011 04:09
OpenFOAM 1.7.0 on OpenSUSE 11.1 Bufacchi OpenFOAM Installation 8 August 6, 2010 10:57
OpenFOAM Version 1.4.1 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 August 3, 2007 08:31
OpenFOAM Version 1.3 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 29, 2006 19:06
OpenFOAM Version 1.1 Released OpenFOAM discussion board administrator OpenFOAM Announcements from ESI-OpenCFD 0 March 11, 2005 06:33
