Scripted install for CentOS/RHEL/SL 5.x 64bit
Old   January 23, 2010, 07:15
Default Scripted install for CentOS/RHEL/SL 5.x 64bit
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi all
I've created install/update script for OpenFOAM-1.6.x and OpenFOAM-1.5-dev on sourceforge.
This should make installation much easier for CentOS/RHEL/SL 5.x 64.
The script can also update the current installation to the newest git/svn.
The update will put a local snapshot on your computer and the first time you update it will recompile everything. The next updates should be faster because it retains the update folder and only update the files.
Please post your findings on the official centFOAM forum.
Link to wikipage
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   February 2, 2010, 11:54
Exclamation
Joaquín J. Correa
Pytthon is on a distinguished road
Any idea if it could work on CentOS 4.x?
Regards
Pytthon is offline   Reply With Quote
Old   February 7, 2010, 12:31
linnemann's Avatar
Niels Nielsen
Hi
I have no idea since 4.x is outdated in my world :-)
I have although compiled 1.4.1 and 1.5 on RHEL 4.x so it is certainly doable. This is a very long time ago and I cant remember the steps.
If possible I would see if the IT people wouldn't be interested in upgrading your cluster to ROCKS 5.3. There is really a big gain in upgrading.
This is what I did, but I'm also in a position where I maintain our cluster install.
Linnemann
Old   February 28, 2010, 03:16
Default Don't know how to start the script
ggruber
ggruber is on a distinguished road
Hello linnemann,
that would be pretty good to get OpenFOAM and the most pre-processing/meshing Software very easy installed with your script. So I made a fresh installation of centOS-5.4.
But I don't know how to run the script ?
[ggruber@vostro1710 ~]$ su
Passwort:
[root@vostro1710 ggruber]# cd /root
[root@vostro1710 ~]# chmod 777 centFOAMInstall
[root@vostro1710 ~]# ls -l
insgesamt 100
-rw------- 1 root root 988 27. Feb 21:33 anaconda-ks.cfg
-rwxrwxrwx 1 root root 13716 27. Feb 21:06 centFOAMInstall
drwxr-xr-x 2 root root 4096 27. Feb 20:57 Desktop
-rw-r--r-- 1 root root 39647 27. Feb 21:33 install.log
-rw-r--r-- 1 root root 4607 27. Feb 21:29 install.log.syslog
-rw-r--r-- 1 root root 195 27. Feb 20:48 scsrun.log
[root@vostro1710 ~]# ./centFOAMInstall
Usage: {yumDependencies|installOpenFOAM|installNetgen|ins tallEngrid|installGmsh|installQt|installVTK|all|up dateOpenFOAM|help}
Can you help me to get it work ?
ggruber is offline   Reply With Quote
Old   February 28, 2010, 04:03
linnemann's Avatar
Niels Nielsen
Hi
Yep you just have to put a space after the centFoamInstall command.
like
 ./centFoamInstall yumDependencies
or
 ./centFoamInstall installOpenFOAM
Linnemann
Old   February 28, 2010, 05:57
ggruber
Sorry, doesn't work:
[root@vostro1710 ~]# ./centFOAMInstall yumDependencies
REQUIRES ROOT
insgesamt 100
But i'am root ? I don't know
Old   February 28, 2010, 06:01
linnemann's Avatar
Niels Nielsen
Well thats funny,,
The script is setup to check if you are root when running the yumDependencies option.
You could just open the script and comment the part about root in the yumDependencies function.
I've done it on my own computer at everything is fine.
It could be that you logged in as root using the "su" command. This will not work at the terminal still thinks you are the "user" and not root.
Logging in like so
ssh -Y root@localhost
will give you the right permissions. Or logging in as root from the login window.
Linnemann
Old   February 28, 2010, 06:34
Default script works !
ggruber
This work's:
Logging in like so
Great script ! Thanks !
Old   April 10, 2010, 14:43
VNPenguin
vnpenguin is on a distinguished road
Excellent work!
Thank you, linnemann!
vnpenguin is offline   Reply With Quote
Old   April 10, 2010, 15:36
Default discretizer in centfoam install script ?
ggruber
Hello Linnemann,
i prefur to work with discretizer http://www.discretizer.org as "GUI" (pre-processing-Tool) for OpenFOAM.
When i install the actual binary and start discretizer(_setup) the desktop freezes completely (no more action possible).
Is it possible for you to integrate discretizer in your installation script so that it will work in the future ?
Regards
Gerhard
Old   April 11, 2010, 03:50
linnemann's Avatar
Niels Nielsen
Hi Gerhard
I will look into it next week.
Linnemann
Old   April 12, 2010, 05:03
linnemann's Avatar
Niels Nielsen
Hi Gehard
I do not have any issues by just downloading the binary and then running
sh discretizer64.sh
I do not need to install, I can easily create simple stuff. Please report back. As of now I wont be including this into CentFOAM. There are way too many dependencies with specific version numbers (which aren't in default CentOS). And since the binary version is working I do not see a need to compile it for CentOS. I only include programs in CentFOAM if a working binary isn't available. You could do it yourself using the instructions on the homepage for discretizer here (Ubuntu)
Linnemann
Old   April 12, 2010, 13:37
Thumbs up
  #13
VNPenguin
Hi Linnemann,
I know that your binary package should work also under CentOS 5.4. But it would be nicer if you could update your build for CentOS 5.4
Waiting for your files
OpenFOAM-1.6.x_CentOS-5.4_x86-64.tar.gz
ThirdParty-1.6.x_CentOS-5.4_x86-64.tar.gz
Thank you for your work,
Regards,
Old   April 13, 2010, 03:06
linnemann's Avatar
Niels Nielsen
Hi Vnpenguin
As there is no problem with the current version on 5.4 besides the name containing 5.3. It would be more right to just name it 5.x, but this is how I did it since I hadn't thought it through
When CentOS 5.5 comes out I will be cleaning the whole project up and do a complete recompile of both 1.6.x and 1.5-dev, and maybe 1.7 if its out by that time.
For now you will have to live with the "wrong" naming convention.
Linnemann
Old   April 17, 2010, 09:27
dhoom is on a distinguished road
I am trying to use the script in Centos5.4 x64 and I am getting some errors, can you please have a look, I have attached the log.
Thanks,
D
dhoom is offline   Reply With Quote
Old   April 17, 2010, 18:00
linnemann's Avatar
Niels Nielsen
Hi
gzip: stdin: unexpected end of file
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
This means that the archives was not downloaded correctly.
Also you have the error
2010-04-17 11:56:11 ERROR 503: Service Temporarily Unavailable.
Which could mean SF was down at the time. I know sourceforge had some scheduled maintenance, but I don't know if that's why you get the errors.
The script is working fine the packages is just not able to be downloaded so it is a connection problem.
If I were you I would start over and delete the archives in /tmp.
Linnemann
Old   April 18, 2010, 11:53
Originally Posted by linnemann View Post
Hi
Thanks linnemann, I will do the install again.
D
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 10:23
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
