The install test problem of OpenFOAM1.6
Old   August 22, 2009, 05:59
Default The install test problem of OpenFOAM1.6
M. Li
cnlimin is on a distinguished road
Hello, everybody
I'm a complete beginner of OF and Linux. I tried my best to install OpenFOAM 1.6 on ubuntu 9.04 according to the readme. However, I excute the command foamInstallationTest in the /bin after the installation, I get the messages as follows:
Checking basic setup...
Shell: bash
Host: ThinkPad-X61
OS: Linux version 2.6.28-15-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/limin/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/limin/OpenFOAM/limin-1.6.x yes no
$WM_THIRD_PARTY_DIR /home/limin/OpenFOAM/ThirdParty-1.6.x yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/limin/OpenFOAM/OpenFOAM-1.6.x yes yes yes
$FOAM_APPBIN ...6.x/applications/bin/linux64GccDPOpt yes yes yes
$FOAM_SITE_APPBIN ...nFOAM/site/1.6.x/bin/linux64GccDPOpt no no
$FOAM_USER_APPBIN ...6.x/applications/bin/linux64GccDPOpt no no
$WM_DIR .../limin/OpenFOAM/OpenFOAM-1.6.x/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...M/OpenFOAM-1.6.x/lib/linux64GccDPOpt yes yes yes
$FOAM_SITE_LIBBIN ...nFOAM/site/1.6.x/lib/linux64GccDPOpt no no
$FOAM_USER_LIBBIN ...FOAM/limin-1.6.x/lib/linux64GccDPOpt no no
$MPI_ARCH_PATH ...nmpi-1.3.3/platforms/linux64GccDPOpt yes yes yes
Third party software
Software Version Location
gcc 4.3.3
WARNING: Conflicting installations:
OpenFOAM settings : /home/limin/OpenFOAM/ThirdParty-1.6.x/gcc-4.3.3/platforms/linux64/bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.3.12 /bin/gzip
tar 1.20 /bin/tar
icoFoam
OpenFOAM settings : /home/limin/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/icoFoam
current path :
CRITICAL ERROR
Summary
Base configuration ok.
The foam installation contains 2 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
How can I resolve the 2 critical errors?
Thank you!
cnlimin is offline   Reply With Quote
Old   August 24, 2009, 04:52
az_monger is on a distinguished road
Hi cnlimin,
check your depencies, especially gcc.
Check, if the needed software is installed or not AND check the versions.
If needed, update your software. Do it with your favourit graphical
package manager, if you don't want to use shell-software.
Greedings
az_monger is offline   Reply With Quote
Old   August 24, 2009, 06:22
M. Li
Dear az_monger,
Thank you very much for your advices.
I upgraded the softrwares including the gcc, python, qmake, camke and so on. The messages seem to tell me gcc have been installed in the wrong place.
Any way, thank you again.
Best.
M. Li
Old   August 27, 2009, 18:13
Default solved?
Alex
fossy is on a distinguished road
Hi. I´ve got the same problem.
How did you finally solved the problem? My files are all up to date .
Alex
fossy is offline   Reply With Quote
Old   August 28, 2009, 01:05
M. Li
Alex
Hi, fossy,
I have installed OF 1.6 according to the following steps:
1)Download and move the files into the $HOME/OpenFOAM directory
2)extract ALL FOUR downloaded files within $HOME/OpenFOAM directory by:
tar -xzf OpenFOAM-1.6.General.gtgz
tar -xzf OpenFOAM-1.6.linux64GccDPOpt.gtgz
tar -xzf ThirdParty-1.6.General.gtgz
tar -xzf ThirdParty-1.6.linux64Gcc.gtgz
3)Then you can execute the foamSystemCheck script in the bin/ directory to check your system:
cd $HOME/OpenFOAM/OpenFOAM-1.6/bin/
./foamSystemCheck
4)Environment variable setting (details see Section 3 of official Readme). for bash users:
sudo gedit $HOME/.bashrc
then add following line to the .bashrc file (there is a space between the dot and $)
. $HOME/OpenFOAM/OpenFOAM-1.6/etc/bashrc
after saving and returning termial, execute following command:
. $HOME/.bashrc
5) If everything is OK, you have successfully installed OF except paraView and you can test the setup: $HOME/OpenFOAM/OpenFOAM-1.6/bin/foamInstallationTest
6) If you want to post-processe with paraView, you need to compile it.
before compiling, please confirm you have installed Qt and cmake 2.6. For ubuntu 9.04 users, executing command "sudo apt-get install libq4-dev" in terminal can finish the qt setup. However, cmake 2.6 need to download.
after installation of qt and cmake 2.6, execute following command in the ThirdParty-1.6 directory of OF to compile paraview:
sh makeParaView
All above are my installation processes, hoping they can hellp you.
Good luck!
M. Li
Old   September 2, 2009, 22:48
Default did you build from source?
niudie is on a distinguished road
Originally Posted by cnlimin View Post
Hi, fossy,
./foamSystemCheck
. $HOME/.bashrc
sh makeParaView
Good luck!
M. Li
Dear cnlinin, M. Li and fossy,
I am experiencing the same problem. But I am installing by building the source. According to your above steps, I guess you installed the binary, instead of building the source. If it is the case, OpenFOAM-1.6.General.gtgz ThirdParty-1.6.General.gtgz would be unnecessary. Can you share me more details ? Thanks.
Niudie
niudie is offline   Reply With Quote
Old   September 3, 2009, 03:22
Gijsbert Wierink
gwierink is on a distinguished road
Hi Niudie,
It may be that you need to tell OpenFOAM to use its own gcc and not the system's. You can do this by going to
~/OpenFOAM/OpenFOAM-<your_version>/etc
and opening the settings.sh or settings.csh file (depending on your shell) and changing in lines 93-96
# Select compiler installation
WM_COMPILER_INST = OpenFOAM | System
# WM_COMPILER_INST=OpenFOAM
into
# WM_COMPILER_INST = OpenFOAM | System
Hope this helps.
Best regards,
Gijs
gwierink is offline   Reply With Quote
Old   September 3, 2009, 04:27
Gijs,
Thanks a lot. I did it that way and is suffering from the lib linking problems, as mentioned in another thread. Thanks.
Niudie
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
Problem in Tutorial problem of fluent Phanindra FLUENT 5 April 17, 2007 10:57
problem in solving "wave generation" problem san FLUENT 2 April 4, 2006 00:37
setup vof test problem Fang Jin FLUENT 1 June 14, 2005 09:27
Install problem of X-windows for Tascflow Alex Deng CFX 2 November 1, 2001 12:33
