Undefined reference to %60mainb
Old   June 12, 2007, 14:12
Default Hi, I am compiling OpenFOAM
Kuan Tek Seang
seang is on a distinguished road
I am compiling OpenFOAM 1.4 with gcc 4.1.2 on OpenSUSE 10.1 and had the following strange error. Any help or hints is appreciated!
regards,
Tek Seang
SOURCE=gambitToFoam.L ; flex++ -f $SOURCE ; mv lex.yy.cc Make/linux64Gcc4DPOpt/gambitToFoam.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/tskuan/CFD/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -c Make/linux64Gcc4DPOpt/gambitToFoam.C -o Make/linux64Gcc4DPOpt/gambitToFoam.o
stdin:16159: m4: Warning: Excess arguments to built-in `m4_ifdef' ignored
lex.yy.cc: In member function âvirtual int yyFlexLexer::yylex()â:
lex.yy.cc:14023: warning: use of old-style cast
lex.yy.cc:14039: warning: use of old-style cast
lex.yy.cc:14599: warning: use of old-style cast
lex.yy.cc: In member function âint yyFlexLexer::yy_get_next_buffer()â:
lex.yy.cc:14847: warning: use of old-style cast
lex.yy.cc:14870: warning: use of old-style cast
lex.yy.cc:14883: warning: use of old-style cast
lex.yy.cc:14904: warning: use of old-style cast
lex.yy.cc: In member function âyy_state_type yyFlexLexer::yy_get_previous_state()â:
lex.yy.cc:14952: warning: use of old-style cast
lex.yy.cc: In member function âvoid yyFlexLexer::yyunput(int, char*)â:
lex.yy.cc:15012: warning: use of old-style cast
lex.yy.cc:15013: warning: use of old-style cast
lex.yy.cc:15021: warning: use of old-style cast
lex.yy.cc: In member function âint yyFlexLexer::yyinput()â:
lex.yy.cc:15088: warning: use of old-style cast
lex.yy.cc: In member function âvirtual yy_buffer_state* yyFlexLexer::yy_create_buffer(std::istream*, int)â:
lex.yy.cc:15168: warning: use of old-style cast
lex.yy.cc:15177: warning: use of old-style cast
lex.yy.cc: In member function âvirtual void yyFlexLexer::yy_delete_buffer(yy_buffer_state*)â:
lex.yy.cc:15199: warning: use of old-style cast
lex.yy.cc:15202: warning: use of old-style cast
lex.yy.cc:15204: warning: use of old-style cast
lex.yy.cc: In member function âvoid yyFlexLexer::yyensure_buffer_stack()â:
lex.yy.cc:15331: warning: use of old-style cast
lex.yy.cc:15349: warning: use of old-style cast
lex.yy.cc: In member function âvoid yyFlexLexer::yy_push_state(int)â:
lex.yy.cc:15367: warning: use of old-style cast
lex.yy.cc:15370: warning: use of old-style cast
lex.yy.cc: In function âvoid* yyalloc(yy_size_t)â:
lex.yy.cc:15450: warning: use of old-style cast
lex.yy.cc: In function âvoid* yyrealloc(void*, yy_size_t)â:
lex.yy.cc:15462: warning: use of old-style cast
lex.yy.cc: In function âvoid yyfree(void*)â:
lex.yy.cc:15467: warning: use of old-style cast
g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/home/tskuan/CFD/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC Make/linux64Gcc4DPOpt/gambitToFoam.o -L/home/tskuan/CFD/OpenFOAM/OpenFOAM-1.4/lib/linux64Gcc4DPOpt \
-lOpenFOAM -liberty -ldl -lm -o /home/tskuan/CFD/OpenFOAM/OpenFOAM-1.4/applications/bin/linux64Gcc4DPOpt/gambitT oFoam
/usr/lib/../lib64/crt1.o: In function `_start':
init.c.text+0x20): undefined reference to `main'
collect2: ld returned 1 exit status
make: *** [/home/tskuan/CFD/OpenFOAM/OpenFOAM-1.4/applications/bin/linux64Gcc4DPOpt/gambit ToFoam] Error 1
seang is offline   Reply With Quote
Old   June 12, 2007, 14:53
Default Think it was that that version
Mattijs Janssens
mattijs is on a distinguished road
Think it was that that version of flex++ does not like ']]'. Put space inbetween any two angle brackets in gambitToFoam.L
mattijs is offline   Reply With Quote
Old   June 13, 2007, 00:33
Default Hi Mattijs, thanks for your
Kuan Tek Seang
Hi Mattijs,
thanks for your suggestion! that worked wonders!
The flex++ version i am using is 2.5.31
regards,
Tek Seang
Old   June 20, 2007, 11:04
Default Had the same problem on an Ubu
Jens Klostermann
jens_klostermann is on a distinguished road
Had the same problem on an Ubuntu (debian based) machine.
Also change:
ansysToFoam.L
fluentToFoam.L
as suggested by Mattijs.
jens_klostermann is offline   Reply With Quote
Old   July 2, 2007, 03:08
Default Had a similar problem when try
sradl's Avatar
Stefan Radl
sradl is on a distinguished road
Had a similar problem when trying to compile a new viscosity model (should give a new library). The error message is:
/usr/lib/gcc/x86_64-linux-gnu/4.1.2/../../../../lib64/crt1.o: In function `_start':
../sysdeps/x86_64/elf/start.S:109: undefined reference to `main'
Followed by a bunch of other error messages
Can anyone help?
br
Stefan
sradl is offline   Reply With Quote
Old   July 2, 2007, 04:33
Default Use 'wmake libso' if you are c
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Use 'wmake libso' if you are compiling a library.
A plain 'wmake' will attempt to create an application, which requires 'main()' and yields a failure if it is missing.
olesen is offline   Reply With Quote
Old   January 30, 2014, 01:22
Default Similar error
Srivathsan N
Sherlock_1812 is on a distinguished road
I know this is a really old thread. But i get a similar error. I am not compiling a library, just a solver. However, I still get this error message.
/usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/x86_64/elf/start.S:109: undefined reference to `main'
make: *** [/home1/ms/me12s056/OpenFOAM/me12s056-2.1.1/platforms/linux64GccDPOpt/bin/thermoSolutalPisoFoam] Error 1
Any help?
Regards,
Srivaths
Sherlock_1812 is offline   Reply With Quote
Old   February 1, 2014, 14:19
Retired Super Moderator
Bruno Santos
Greetings Srivaths,
This isn't enough information to work with, so here are some questions, to help isolate the source of the problem:
  1. Which Linux Distribution are you using and which architecture (32 or 64 bit)?
  2. What installation instructions did you follow for installing OpenFOAM 2.1.1.?
  3. Do you have more than one OpenFOAM version installed? If you do, how are you keeping them apart?
Best regards,
Bruno
Old   February 1, 2014, 14:48
Srivathsan N
Hello Bruno,
I am using Ubuntu 12.04 32 bit system. The 2.1.1 version was on a cluster that i'm running my cases on.
I would like to say that I've got the issue resolved. It was a beginner's error and I just didn't spot it initially.
Thank you for your time.
Regards,
Srivaths
[OpenFOAM.com] Undefined reference to %60yyFlexLexeryywrapb arjaan OpenFOAM Installation 13 June 1, 2016 13:33
Undefined reference mateusz_slowikowski OpenFOAM Running, Solving & CFD 7 February 27, 2015 15:35
Undefined reference to %60yyFlexLexeryywrapb zhoubinwx OpenFOAM Bugs 1 May 28, 2008 06:57
Undefined reference mateusz_slowikowski OpenFOAM Running, Solving & CFD 3 March 11, 2008 13:19
Compiling liftDrag crashed with initc%3cIMG SRC%3d%22httpopenfoamcfdonlinecomforumclipartsadgif%22 ALT%3d%22%22 BORDER%3d0%3etext0x20 undefined reference to %60mainb sponiar OpenFOAM Running, Solving & CFD 2 January 17, 2008 05:00
