OpenFOAM14 for Mac OSX Darwin 104
Old   March 20, 2008, 15:20
Default Hi Bernhard, thank for for g
  #81
hjg
Heinz-Jürgen Geurtz
Location: Althengstett-Neuhengstett, Baden-Württemberg, Deutschland
hjg is on a distinguished road
Hi Bernhard,
thank for for giving me some assistance.
Please excuse my late response since i am currently on vacation on Fuerteventura (just with external internet access). Bye the way, the weather is much more better than in good old germany.
As soon as I´m back home I will make the installation as you suggested and give you feedback.
Thank you in advance...
Live long and prosper..
HJ
Live long and prosper ...
Glückauf
HJG
hjg is offline   Reply With Quote
Old   March 24, 2008, 13:43
Default Hi Bernhard, back home again
  #82
hjg
Heinz-Jürgen Geurtz
Hi Bernhard,
back home again I ran Allwmake with file output.
I went trough all the stuff.
wmake says:
"ld: library not found for -lOpenFOAM
collect2: ld returned 1 exit status" prior to exiting - indicationg a linker problem (?).
This error appears also in other link-runs, always with the problem not finding the OpenFOAM-library
What can I do???
HJ
Glückauf
HJG
Old   March 25, 2008, 14:23
Default Hi HJ! Some questions: I
  #83
Assistant Moderator
Bernhard Gschaider
Hi HJ!
Some questions:
Is there a library libOpenFOAM.dylib there? Check with "ls $FOAM_LIBBIN"
Is the variable DYLD_LIBRARY_PATH correctly set? (== is FOAM_LIBBIN included?)
Are any applications compiled (check with "ls $FOAM_APPBIN")?
Look in the compile.log for the first occurence of an error (propably that might be the cause)
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   March 26, 2008, 06:35
Default Hi! Apparently no applicati
  #84
Assistant Moderator
Bernhard Gschaider
Hi!
Apparently no applications get linked because the OpenFOAM-lib is missing (did not get linked). Could you try "cd $FOAM_SRC/OpenFOAM; wmake libso" (Or check the compile.log - there should be some kind of problem up there)
Bernhard
Old   March 26, 2008, 11:08
Default onyx-bridge 313% gdb ../../../
  #85
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
onyx-bridge 313% gdb ../../../wmake/rules/sgi*/wmkdep
GNU gdb 6.6
Copyright (C) 2006 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "mips-sgi-irix6.5"...
(gdb) r dynamicFvMesh.C
Starting program: /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1/wmake/rules/sgiN32Gcc/wmkdep dynamicFvMesh.C
Making dependency list for source file dynamicFvMesh.C
$(OBJECTS_DIR)/dynamicFvMesh.o: dynamicFvMesh.dep
1111dynamicFvMesh.dep: dynamicFvMesh.C
1111dynamicFvMesh.dep: dynamicFvMesh.H
could not open file fvMesh.H for source file dynamicFvMesh.C
could not open file autoPtr.H for source file dynamicFvMesh.C
could not open file runTimeSelectionTables.H for source file dynamicFvMesh.C
Program received signal SIGSEGV, Segmentation fault.
fread () at /xlv42/6.5.23m/work/irix/lib/libc/libc_n32_M4/stdio/fread.c:37
37 /xlv42/6.5.23m/work/irix/lib/libc/libc_n32_M4/stdio/fread.c: No such file or directory.
in /xlv42/6.5.23m/work/irix/lib/libc/libc_n32_M4/stdio/fread.c
(gdb) bt
#0 fread () at /xlv42/6.5.23m/work/irix/lib/libc/libc_n32_M4/stdio/fread.c:37
#1 0x10002b74 in yylex ()
#2 0x10003250 in main ()
(gdb) q
The program is running. Exit anyway? (y or n) y
onyx-bridge 314% uname -a
IRIX64 onyx-bridge 6.5 01080747 IP35
onyx-bridge 315% ulimit -a
time(seconds) unlimited
file(blocks) unlimited
data(kbytes) unlimited
stack(kbytes) 65536
memory(kbytes) 29096416
coredump(blocks) unlimited
nofiles(descriptors) 200
vmemory(kbytes) unlimited
concurrency(threads) 1024
onyx-bridge 316%
Hi Bernhard,
Concerning the beginning of this thread, I have a question.
I try to compile OpenFOAM on Irix6.5, yet I met core dump everytime when wmkdep is called. So, it is quite fatal
that after compilation icoFoam failed with SegV.
For instance, when I wmake libso dynamicFVMesh, after it is finished, I get a bad dynamicFVMesh.so and with a core
file under src/dynamicFVMesh directory.
Here is the information when I try to debug it.
GNU gdb 6.6
(gdb) bt
(gdb) q
stack(kbytes) 65536
onyx-bridge 316%
So, what does this line mean?
Please help, thanks!
Daniel
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   March 26, 2008, 11:29
Default Hi Daniel! Which posting ar
  #86
Assistant Moderator
Bernhard Gschaider
Hi Daniel!
Which posting are you refering to? (just the date would be helpful)
The line means that it has some problem reading the file. My guess is because of an invalid filehandle. The number of possible file descriptors (200) in your ulimit-output is to small I'm afraid. Raise it to a larger value (1024 is standard on linux) and try again. (my guess is that the error occurs when trying to read the 201st file. Because this is beyond the ulimit the file handle is invalid and the read fails. But this is only a guess - I don't speak IRIX)
Bernhard
Old   March 26, 2008, 13:34
Default Hi Bernhard, I checked your h
  #87
hjg
Heinz-Jürgen Geurtz
Hi Bernhard,
I checked your hint.
wmake says:
SOURCE=primitives/uint/uintIO.C ; g++ -Ddarwin -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -ffast-math -DNoRepository -ftemplate-depth-30 -DWM_PROJECT_VERSION='"'1.4.1'"' -I/Users/heinzjuergengeurtz/OpenFOAM/OpenFOAM-1.4.1/src/zlib-1.2.1 -IlnInclude -I. -I/Users/heinzjuergengeurtz/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/darwinDPOpt/uintIO.o
primitives/uint/uintIO.C: In function 'Foam::Istream& Foam::operator>>(Foam::Istream&, unsigned int&)':
primitives/uint/uintIO.C:69: error: 'uint' was not declared in this scope
make: *** [Make/darwinDPOpt/uintIO.o] Error 1
This is a first information.
I'm investigation, what is te problem with uint and crosscheck in other posts.
Greetings
HJ
Glückauf
HJG
Old   March 26, 2008, 13:47
Default Hi, From Bernhard (same th
  #88
Pierre-Olivier Dallaire
podallaire is on a distinguished road
From Bernhard (same thread) :
Try to replace the offending line
i = uint(t.labelToken());
with
i = (unsigned int)(t.labelToken());
(you WILL get a warning about an old-style cast)
Good luck
podallaire is offline   Reply With Quote
Old   March 26, 2008, 13:59
Default Hello Pierre & Bernhard, yes,
  #89
hjg
Heinz-Jürgen Geurtz
yes, you are right. This is also what I found. I modified uintIO.C and launched wmake libso which ran.
Now currently I started ./Allwmake to verify and (hopefully) finis the make.
As soon as I have a result I will dive you a feedback.
Greetings
HJ
Glückauf
HJG
Old   March 26, 2008, 15:15
Default Hello Pierre & Bernhard, we
  #90
hjg
Heinz-Jürgen Geurtz
well, after replacing the "uint" I started Allwmake again.
SUCCESS
I checked icoFoam and checked it with paraview3.2.1. Looks quiet good.
I make some some tutorials, but from the current view I'm through. Now I have to patch paraview to directly open Foam-cases. But tat's another thing...
Thank you everbody for your assistance...
Greeting
HJ
Glückauf
HJG
Old   March 26, 2008, 19:30
Default Hi HJ! You're welcome. But
  #91
Assistant Moderator
Bernhard Gschaider
Hi HJ!
You're welcome. But we could have saved ourselfs some iterations. So everbody repeat after me "The most important compilation error is the first one in the logfile. If we fix that most of the others will go away" (OK. Would sound better if it would rhyme)
Bernhard
Old   March 26, 2008, 21:55
Default Sorry for the last bad posting
  #92
lakeat's Avatar
Daniel WEI (老魏)
Sorry for the last bad posting.
Hi Bernhard, thanks for your help. I meant the posting by James Turner on Wednesday, May 02, 2007 - 06:35 am
Now I change the nofiles to 2500, (Actually I use "unlimit" and got the following. (Seems 2500 is my IRIX's upper limit of nofiles, is it enough?))
onyx-bridge 17% ulimit -a
stack(kbytes) 524288
nofiles(descriptors) 2500
onyx-bridge 18%
but no luck, here's what i got after a few ./Allwmake in src/Pstream/dummy
-> a core file
and i tried to gdb,
onyx-bridge 18% gdb
GNU gdb 6.6
(gdb) core core
Core was generated by `wmkdep'.
Program terminated with signal 11, Segmentation fault.
warning: wrong size gregset struct in core file
#0 0x00000000 in ?? ()
(gdb) bt
And it seems obvious that the problem lies in wmkdep....
Regards,
Daniel
Daniel WEI
Beijing, China
Email
Old   March 27, 2008, 07:12
Default HI Bernhard, Not confident
  #93
lakeat's Avatar
Daniel WEI (老魏)
HI Bernhard,
Not confident on wmkdep on my IRIX system, so I tried to replace "wmkdep" with "cpp -M" under rules/general, while make a soft link under /rules/sgiN32Gcc and wcleanAll and recompile again. (Is it ok by doing so?)
Now, no core any more came out in each directory during compilation, however, in the end, the execution of icoFoam died all the same with Segmentation fault or bus error etc.
Please help, Thank you.
Daniel
Daniel WEI
Beijing, China
Email
Old   March 27, 2008, 08:10
Default Hi Daniel! No idea. In Linu
  #94
Assistant Moderator
Bernhard Gschaider
Hi Daniel!
No idea. In Linux I would recommend doing an strace (don't know if Irix has something like that).
gdb doesn't give you anything because there is no debug-information included. Try the following: switch your OF-Compiler-Options to debug. Remove all the .o files you find in wmake and remake it. The core-dump should be more helpful then
Bernhard
Old   March 27, 2008, 10:34
Default I have already switch my OF-Co
  #95
lakeat's Avatar
Daniel WEI (老魏)
I have already switch my OF-Compiler-Options to debug in .OpenFOAM-1.4.1/cshrc.
onyx-bridge 52% icoFoam
Bad system call (core dumped)
onyx-bridge 53% ls
FoamX Make core createFields.H icoFoam.C icoFoam.dep
onyx-bridge 54% gdb icoFoam
GNU gdb 6.6
(gdb) r
Starting program: /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1/applications/bin/sgiN32GccDPD ebug/icoFoam
Program terminated with signal SIGSEGV, Segmentation fault.
The program no longer exists.
You can't do that without a process to debug.
(gdb) core core
Reading symbols from /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libtriSurface.so...do ne.
Loaded symbols for /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libtriSurface.so
Reading symbols from /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libmeshTools.so...don e.
Loaded symbols for /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libmeshTools.so
Reading symbols from /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libPstream.so...done.
Loaded symbols for /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libPstream.so
Reading symbols from /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/liblagrangian.so...do ne.
Loaded symbols for /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/liblagrangian.so
Reading symbols from /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libfiniteVolume.so... done.
Loaded symbols for /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libfiniteVolume.so
Reading symbols from /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libOpenFOAM.so...done .
Loaded symbols for /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libOpenFOAM.so
Reading symbols from /usr/lib32/libfpe.so...done.
Loaded symbols for /usr/lib32/libfpe.so
Reading symbols from /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libstdc++.so.6...done .
Loaded symbols for /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libstdc++.so.6
Reading symbols from /usr/lib32/libm.so...done.
Loaded symbols for /usr/lib32/libm.so
Reading symbols from /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libgcc_s.so.1...done.
Loaded symbols for /disk4/usr/people/student3/OpenFOAM/sgiN32/gcc-4.2.1/lib32/libgcc_s.so.1
Reading symbols from /usr/lib32/libc.so.1...done.
Loaded symbols for /usr/lib32/libc.so.1
Reading symbols from /usr/lib32/libz.so...done.
Loaded symbols for /usr/lib32/libz.so
(gdb) bt
(gdb) q
onyx-bridge 55% ulimit -a
onyx-bridge 56%
1. Is nofiles(descriptors)=2500 enough?
2. what do "Reading symblols" and "Loaded symbols" mean? Do they mean that my *.so files are correctly generated?
3. How could I know whether *.so files is correctly "wmake libso"? How to test it?
4. How to use strace in such cases? (IRIX has strace utility)
I really appreciate your help.
Daniel
Daniel WEI
Beijing, China
Email
Old   March 27, 2008, 10:44
Default 5. Do you think that I can rep
  #96
lakeat's Avatar
Daniel WEI (老魏)
5. Do you think that I can replace "wmkdep" with "cpp -M"?
I noticed that makeWmake only resulted out two files in wmake/rules/sgiN32Gcc, wmkdep and dirToString. So to remake it is not hard for me, yet with only one warning.
onyx-bridge 59% ./makeWmake
gcc -mabi=n32 -mips4 -Wall -O1 -DFULLDEBUG -fPIC dirToString.c -o /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1/wmake/rules/sgiN32Gcc/dirToSt ring
flex wmkdep.l ; gcc -mabi=n32 -mips4 -Wall -O1 -DFULLDEBUG -fPIC lex.yy.c -o /disk4/usr/people/student3/OpenFOAM/OpenFOAM-1.4.1/wmake/rules/sgiN32Gcc/wmkdep
lex.yy.c:1393: warning: 'yyunput' defined but not used
onyx-bridge 60% flex -V
flex version 2.5.4
Any ideas?
Daniel
Daniel WEI
Beijing, China
Email
Old   March 27, 2008, 12:02
Default @1: Yeah 2500 is plenty @2:
  #97
Assistant Moderator
Bernhard Gschaider
@2: It's got to do with http://en.wikipedia.org/wiki/Dynamic...ynamic_linking Don't wory about it
@3: Don'T understand the question
@4: I let it run and look what the last system-calls before the segfault are
@5: Don't know the difference. But I guess it is only there for performance reasons
Old   April 5, 2008, 08:34
Default Dear OF Community, I have b
  #98
Kevin Maki
kjmaki is on a distinguished road
Dear OF Community,
I have been greatly enjoying 1.4.1-dev on my linux workstations, but I still have not been able to successfully compile on my Mac. I recently upgraded the OS to 10.5.2, and still I have no success.
Could someone offer any advice?
In my compile log, this is the first error:
superusers-macbook-pro-15:~/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM kjmaki$ wmake libso
/Users/kjmaki/OpenFOAM/OpenFOAM-1.4.1-dev/wmake/rules/darwin/flex++:6: warning: overriding commands for target `.L.dep'
/Users/kjmaki/OpenFOAM/OpenFOAM-1.4.1-dev/wmake/rules/General/flex++:6: warning: ignoring old commands for target `.L.dep'
*** Assembler
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -p
checking the name lister (/usr/bin/nm -p) interface... ./configure: line 23524: External.*some_variable: command not found
rm: conftest.dSYM: is a directory
BSD nm
checking for fgrep... grep -F
checking whether to enable smp locks... yes
checking if .proc/endp is needed... rm: conftest.dSYM: is a directory
no
checking directive for setting text section... .text
checking directive for exporting symbols... .globl
checking for objdump... no
checking if .note.GNU-stack is needed... no
checking suffix for labels... :
checking prefix for global symbol labels... rm: conftest.dSYM: is a directory
none
configure: error: Could not determine global symbol label prefix
+ make
make: *** No targets specified and no makefile found. Stop.
+ make install
make: *** No rule to make target `install'. Stop.
+ make distclean
make: *** No rule to make target `distclean'. Stop.
+ cd /Users/kjmaki/OpenFOAM/OpenFOAM-1.4.1-dev/src
+ '[' OPENMPI = LAM -a '!' -r /lib/libmpi.a -a '!' -r /lib/libmpi.so -a '!' -r /lib/libmpi.dylib ']'
+ '[' OPENMPI = MPICH -a '!' -r /lib/libmpich.a -a '!' -r /lib/libmpich.so -a '!' -r /lib/libmpich.dylib ']'
+ cd /Users/kjmaki/OpenFOAM/OpenFOAM-1.4.1-dev/applications/utilities/miscellaneous
+ wmake exe foamFlex
The second and all subsequent errors appear like this:
SOURCE=triSurface/interfaces/STL/readSTLASCII.L ; foamFlex++ -f $SOURCE ; mv lex.yy.cc Make/darwinDPOpt/readSTLASCII.C ; g++ -Ddarwin -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -ffast-math -DNoRepository -ftemplate-depth-30 -IlnInclude -I. -I/Users/kjmaki/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude -fPIC -c Make/darwinDPOpt/readSTLASCII.C -o Make/darwinDPOpt/readSTLASCII.o
SOURCE=triSurface/interfaces/GTS/writeGTS.C ; g++ -Ddarwin -DDP -Wall -W -Wno-unused-parameter -Wold-style-cast -O3 -ffast-math -DNoRepository -ftemplate-depth-30 -IlnInclude -I. -I/Users/kjmaki/OpenFOAM/OpenFOAM-1.4.1-dev/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/darwinDPOpt/writeGTS.o
dyld: Symbol not found: __ZN4Foam8OPstream5writeEPKc
Referenced from: /Users/kjmaki/OpenFOAM/OpenFOAM-1.4.1-dev/lib/darwinDPOpt/dummy/libPstream.dylib
Expected in: dynamic lookup
/bin/sh: line 1: 46335 Trace/BPT trap foamFlex++ -f $SOURCE
mv: rename lex.yy.cc to Make/darwinDPOpt/readSTLASCII.C: No such file or directory
i686-apple-darwin9-g++-4.0.1: Make/darwinDPOpt/readSTLASCII.C: No such file or directory
i686-apple-darwin9-g++-4.0.1: no input files
make: *** [Make/darwinDPOpt/readSTLASCII.o] Error 1
make: *** Waiting for unfinished jobs....
+ wmake libso edgeMesh
Additional information that might be of use:
superusers-macbook-pro-15:~/OpenFOAM/OpenFOAM-1.4.1-dev kjmaki$ gcc -v
Using built-in specs.
Target: i686-apple-darwin9
Configured with: /var/tmp/gcc/gcc-5465~16/src/configure --disable-checking -enable-werror --prefix=/usr --mandir=/share/man --enable-languages=c,objc,c++,obj-c++ --program-transform-name=/^[cg][^.-]*$/s/$/-4.0/ --with-gxx-include-dir=/include/c++/4.0.0 --with-slibdir=/usr/lib --build=i686-apple-darwin9 --with-arch=apple --with-tune=generic --host=i686-apple-darwin9 --target=i686-apple-darwin9
Thread model: posix
gcc version 4.0.1 (Apple Inc. build 5465)
superusers-macbook-pro-15:~/OpenFOAM/OpenFOAM-1.4.1-dev kjmaki$ flex -V
flex 2.5.33
Thanks!
Kevin
kjmaki is offline   Reply With Quote
Old   April 14, 2008, 18:54
Default Dear FOAMers, I am waiting
  #99
Kevin Maki
Dear FOAMers,
I am waiting for someone to throw me the gem that I know is out there! I am still stuck trying to get over the flex++ or foamFlex++ issue on my mac laptop.
I have followed the advice on the closely related thread titled (I dont know how to point to urls of specific threads, sorry): Yy_current_buffer undefined flexx2.5.33 vs flexx2.5.4
And whether I use foamFlex++ or flex++ makes no differnce, and I run Allwmake twice.
Please help :-)
Kevin
Old   April 15, 2008, 07:39
Default Hi Kevin! Looks like libPSt
  #100
Assistant Moderator
Bernhard Gschaider
Hi Kevin!
Looks like libPStream does not get linked and consequently all other links fail.
Is the MACOSX_DEPLOYMENT_TARGET-variable set (although I'm not quite sure whether this is still required on 10.5 or whether it is just folklore that it is set on my machine: http://paulbeachsblog.blogspot.com/2007/12/i-have-read-in-number-of-places-that- i.html)
If that does not help grep the .o-files in PStream/dummy/Make/darwinDPOpt
Bernhard
PS: One afterthought: In your previos post you start with "wmake libso OpenFOAM". You already made the Pstream-library?
OpenFOAM13 for Mac OSX Darwin 104 hjasak OpenFOAM Installation 70 September 24, 2010 06:06
VTK errors in ParaFOAM on OpenFOAM14 stevemchale OpenFOAM Installation 5 August 29, 2007 16:39
Compilation from source failed OpenFOAM14 hsieh OpenFOAM Installation 1 June 20, 2007 11:06
Probes in OpenFOAM14 otsuki OpenFOAM Running, Solving & CFD 2 May 16, 2007 07:18
Port of OpenFOAM14 to FreeBSD thierry OpenFOAM Installation 0 April 28, 2007 10:36
