[OpenFOAM.com] Installation Problem
Old   July 7, 2016, 21:07
Default Installation Problem
Sam Bazgi
Manyway is on a distinguished road
Hello all, I would really appreciate if you help me.
I keep getting the errors while compiling the OpenFoam. Here is the result of the installation test:
moto@ubuntu:~/OpenFOAM/OpenFOAM-v1606+$ foamInstallationTest
Executing /home/moto/OpenFOAM/OpenFOAM-v1606+/bin/foamInstallationTest:
Checking basic setup...
Shell:              bash
Host:               ubuntu
OS:                 Linux version 4.4.0-21-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory                Valid      Crit
$WM_PROJECT_INST_DIR /home/moto/OpenFOAM                      yes       yes
$WM_PROJECT_USER_DIR /home/moto/OpenFOAM/moto-v1606+          yes       no
$WM_THIRD_PARTY_DIR  /home/moto/OpenFOAM/ThirdParty-v1606+    yes       yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory                Valid Path Crit
$WM_PROJECT_DIR      /home/moto/OpenFOAM/OpenFOAM-v1606+      yes  yes  yes
$FOAM_APPBIN         ...+/platforms/linux64GccDPInt32Opt/bin  yes  yes  yes
$FOAM_SITE_APPBIN    ...+/platforms/linux64GccDPInt32Opt/bin  no        no
$FOAM_USER_APPBIN    ...+/platforms/linux64GccDPInt32Opt/bin  no        no
$WM_DIR              .../moto/OpenFOAM/OpenFOAM-v1606+/wmake  yes  yes  yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN         ...+/platforms/linux64GccDPInt32Opt/lib  yes  yes  yes
$FOAM_SITE_LIBBIN    ...+/platforms/linux64GccDPInt32Opt/lib  no        no
$FOAM_USER_LIBBIN    ...+/platforms/linux64GccDPInt32Opt/lib  no        no
$MPI_ARCH_PATH       /usr/lib/lam                             yes  yes  yes
Third party software
Software Version   Location
flex     2.6.0     /usr/bin/flex
gcc      5.3.1     /usr/bin/gcc
g++      5.3.1     /usr/bin/g++
gzip     1.6       /bin/gzip
tar      1.28      /bin/tar
icoFoam
WARNING:  Conflicting installations:
          OpenFOAM settings        : /home/moto/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/bin/icoFoam
          current path             :
          CRITICAL ERROR
Summary
Base configuration ok.
The foam installation contains 1 critical error(s).
The full log file is attached.
Attachment 48974
So, the errors it shows:
collect2: error: ld returned 1 exit status
/home/moto/OpenFOAM/OpenFOAM-v1606+/wmake/makefiles/general:132: recipe for target '/home/moto/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/bin/laplacianFoam' failed
make[2]: *** [/home/moto/OpenFOAM/OpenFOAM-v1606+/platforms/linux64GccDPInt32Opt/bin/laplacianFoam] Error 1
make[2]: Leaving directory '/home/moto/OpenFOAM/OpenFOAM-v1606+/applications/solvers/basic/laplacianFoam'
/home/moto/OpenFOAM/OpenFOAM-v1606+/wmake/makefiles/apps:39: recipe for target 'laplacianFoam' failed
make[1]: *** [laplacianFoam] Error 2
make[1]: Leaving directory '/home/moto/OpenFOAM/OpenFOAM-v1606+/applications/solvers/basic'
/home/moto/OpenFOAM/OpenFOAM-v1606+/wmake/makefiles/apps:39: recipe for target 'basic' failed
make: *** [basic] Error 2
I installed libboost and everything I could find.
What can be the problem?
Manyway is offline   Reply With Quote
Old   July 8, 2016, 06:45
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
I have noticed, you are using LAM as MPI implementation (yet, you have configuration for OpenMPI). Quick search revealed several messages on mailing lists with the same problem (without solution). Also there is http://www.cfd-online.com/Forums/ope...on-v3-0-a.html without solution also. So you could try to...
1. Compile with OpenMPI.
2. Check if all necessary compilation flags for LAM are there.
3. Ask user cute if (s)he solved problem of missing symbols.
alexeym is offline   Reply With Quote
Old   July 8, 2016, 14:47
Sam Bazgi
Alexey, spasibo)
I've found the reason and recompiled the mpi library
HTML Code:
Pstream
separately.
Then I run
./Allwmake
again and voila
Thanks for a hint)
[swak4Foam] [OpenFOAM plus] [v1612+] swak4Foam installation problem in Windows (Allwmake) LThomes OpenFOAM Community Contributions 7 October 6, 2020 14:36
[foam-extend.org] foam-extend-4.0 openSUSE Leap 42.1 Installation Problem icab OpenFOAM Installation 5 April 8, 2017 08:09
Problem with installation florvit ANSYS 0 December 8, 2016 10:10
Installation problem - calling blockMesh - libblockMesh.so aylalisa OpenFOAM Installation 5 November 28, 2012 10:55
ParaView installation problem on Suse 11.4 victorz OpenFOAM Installation 4 February 6, 2012 18:26
