[OpenFOAM.com] v3.0+ Compiling/installing problems on Ubuntu 15.10
Old   May 31, 2016, 09:53
Default v3.0+ Compiling/installing problems on Ubuntu 15.10
anonymous
cute is on a distinguished road
I am having problem installing OF-V3.0+ with ubuntu 15.10.
I am getting the following error message
make[2]: *** [/home/mytest/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Debug/bin/cavitatingFoam] Error 1
make[1]: *** [cavitatingFoam] Error 2
/home/mytest/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Debug/lib/openmpi-system/libPstream.so: undefined reference to `MPI::Op::Init(void (*)(void const*, void*, int, MPI::Datatype const&), bool)'
/home/mytest/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Debug/lib/openmpi-system/libPstream.so: undefined reference to `PMPI::Intracomm::current_op'
/home/mytest/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Debug/lib/openmpi-system/libPstream.so: undefined reference to `PMPI::Comm::mpi_comm_map'
/home/mytest/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Debug/lib/openmpi-system/libPstream.so: undefined reference to `MPI::Is_initialized()'
/home/mytest/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Debug/lib/openmpi-system/libPstream.so: undefined reference to `PMPI::Comm::mpi_err_map'
/home/mytest/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Debug/lib/openmpi-system/libPstream.so: undefined reference to `MPI::Op::Free()'
/home/mytest/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Debug/lib/openmpi-system/libPstream.so: undefined reference to `op_intercept'
collect2: error: ld returned 1 exit status
make[2]: *** [/home/mytest/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Debug/bin/solidDisplacementFoam] Error 1
make[1]: *** [solidDisplacementFoam] Error 2
It looks to me MPI problem. But when I run mpirun, i get
mpirun --version
mpirun (Open MPI) 1.6.5
Thanks for reading and helping.
cute is offline   Reply With Quote
Old   June 1, 2016, 16:45
anonymous
Anyone has any suggestion regarding installation problem. I am trying to compile source code with Debug option.
Old   June 21, 2016, 02:35
anonymous
I am still stuck on this error for a long time. Any suggestion.
Old   June 21, 2016, 03:44
anonymous
Here is my log file,if you would like to see errors.
Old   June 21, 2016, 13:23
pgh
Pawan Ghildiyal
pgh is on a distinguished road
Two thing to try :
i) remove debug flag and recompile . See if you can any error
ii) compile thirdparty openmpi by yourself with debug flag and then compile openfoam in debug mode
pgh is offline   Reply With Quote
Old   June 21, 2016, 13:27
anonymous
Quick question, how to compile openmpi with debug option. Is there any line I need to change in a file.
Old   June 22, 2016, 04:49
pgh
Pawan Ghildiyal
HI Sorry . i missed the point. You donot need to compile openmpi with debug flag.
check this link
http://www.cfd-online.com/Forums/ope...i-related.html
Old   June 22, 2016, 05:09
anonymous
Thanks for the reply. I was able to fix that error by compiling openmpi separately.
Now I am getting following errors: (Note I used grep command to display all Errors)
Error FODC0002 in file:///home/mytest/OpenFOAM/OpenFOAM-v3.0: Error opening /home/mytest/OpenFOAM/OpenFOAM-v3.0: No such file or directory
Error FODC0002 in file:///applications/utilities/postProcessing/graphics/PV4Readers/PV4blockMeshReader/PV4blockMeshReader/PV4blockMeshReader_SM.xml: Error opening /applications/utilities/postProcessing/graphics/PV4Readers/PV4blockMeshReader/PV4blockMeshReader/PV4blockMeshReader_SM.xml: No such file or directory
Error FODC0002 in file:///applications/utilities/postProcessing/graphics/PV4Readers/PV4FoamReader/PV4FoamReader/PV4FoamReader_SM.xml: Error opening /applications/utilities/postProcessing/graphics/PV4Readers/PV4FoamReader/PV4FoamReader/PV4FoamReader_SM.xml: No such file or directory
I am installing OpenFOAM-v3.0+, but why in the error code it looks for OpenFOAM-v3.0.
Thanks for the help.
Old   June 23, 2016, 01:19
pgh
Pawan Ghildiyal
check whether you have sourced bashrc from desired openfoam folder
Old   June 23, 2016, 03:32
anonymous
yes, it is in OpenFoam/OpenFoam-v3.0+/etc/bashrc.
I was able to compile with Debug switch with above 4 errors. I ran icoFoam, it is working through Debugger gdb. I read somewhere that it is possible to debug openfoam source code without debugging ThirdParty. How can I do that?
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
Problems installin OpenFoam-1.5-dev in Ubuntu 8 tmata2002 OpenFOAM Installation 2 September 23, 2009 11:50
OpenFOAM Installation Ubuntu 9.04 Problems Sumontro OpenFOAM Installation 8 July 21, 2009 22:40
Compile problems on ubuntu 810 with gcc432 deepblue17 OpenFOAM Bugs 10 March 2, 2009 08:32
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
