[OpenFOAM.org] Installation without root access |
February 11, 2015, 10:44 |
Rep Power: 12 |
Dear Community,
actually, I am facing an installation problem, which I can't solve by myself. I am trying to compile OpenFOAM on a SUSE EL 11 system, where I do not have root access. The problem is, that parts of the libraries do not compile. For example "dsmcFields.o", which I need. Obviously, this is because of the missing boost installation. Now my question: Is there any way to compile boost by myself and tell OpenFoam, where to search for these libraries? Thank you all for your ideas in advance! |
February 11, 2015, 11:03 |
In fact it is not so obvious with Boost. Can you please post the error? To build Boost yourself, go to boost.org, download source tar-ball, unpack tar-ball, cd to the folder (it should be something like boost_1_5x_0), execute "./bootstrap -prefix=$HOME/boost/1.5x.0", then execute "./b2 install" (change x to the digit from the version you've downloaded). That's it, now you have Boost installed in your home folder. Add "export BOOST_ARCH_PATH=$HOME/boost/1.5x.0" to your prefs.sh. |
February 11, 2015, 13:12 |
Rep Power: 12 |
Hi alexeym,
I followed your advise and compiled boost by myself. The error appears anyway. When I compile the Third Party package the following error occurs at the end. Code:
======================================== Build Metis decomposition optional component Metis was not found ======================================== Build CGAL + cgalPACKAGE=CGAL-4.3 + boostPACKAGE=boost-system + gmpPACKAGE=gmp-system + mpfrPACKAGE=mpfr-system + wmakeCheckPwd /home/vacusim/nobackup/OpenFOAM/ThirdParty-2.3.x + . etc/tools/ThirdPartyFunctions ++ buildBASE=/home/vacusim/nobackup/OpenFOAM/ThirdParty-2.3.x/build/linux64Gcc ++ installBASE=/home/vacusim/nobackup/OpenFOAM/ThirdParty-2.3.x/platforms/linux64Gcc ++ unset WM_HOSTS WM_SCHEDULER +++ wc -l ++ export WM_NCOMPPROCS=16 ++ WM_NCOMPPROCS=16 ++ '[' 16 -le 1 ']' ++ '[' 16 -ge 8 ']' ++ WM_NCOMPPROCS=8 + '[' -n g++ ']' + export CXX=g++ + CXX=g++ + '[' 0 -gt 0 ']' + BOOST_ARCH_PATH=/home/vacusim/nobackup/OpenFOAM/ThirdParty-2.3.x/platforms/linux64Gcc/boost-system + BOOST_SOURCE_DIR=/home/vacusim/nobackup/OpenFOAM/ThirdParty-2.3.x/boost-system + '[' -d /home/vacusim/nobackup/OpenFOAM/ThirdParty-2.3.x/platforms/linux64Gcc/boost-system ']' + '[' -d /home/vacusim/nobackup/OpenFOAM/ThirdParty-2.3.x/boost-system ']' + boostInc=/usr/include + '[' 64 = 64 ']' + boostLib=/usr/lib64 + '[' -f /usr/include/boost/version.hpp ']' + echo 'Boost does not appear to be installed' Boost does not appear to be installed + echo 'stopping build' stopping build + exit 1 ======================================== Done ThirdParty Allwmake ======================================== Code:
+ BOOST_ARCH_PATH=/home/vacusim/nobackup/OpenFOAM/ThirdParty-2.3.x/platforms/linux64Gcc/boost-system Do you have any ideas? |
February 11, 2015, 15:27 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
Check the instructions that are meant for CentOS 5.10: http://openfoamwiki.net/index.php/In...EL#CentOS_5.10 - namely steps #7, #9 and #13, where you can find the necessary hacks for using a custom built Boost. Best regards, Bruno |
February 12, 2015, 04:20 |
@Chris_DSMC, the reason for the behaviour are these lines in makeCGAL script: Code:
BOOST_ARCH_PATH=$installBASE/$boostPACKAGE BOOST_SOURCE_DIR=$WM_THIRD_PARTY_DIR/$boostPACKAGE Also there are these lines: Code:
elif [ -d "$BOOST_SOURCE_DIR" ] then boostInc="$BOOST_ARCH_PATH/include" boostLib="$BOOST_ARCH_PATH/lib" echo "Starting build: boost" ... Code:
boostPACKAGE=boost-system ... BOOST_SOURCE_DIR=$WM_THIRD_PARTY_DIR/$boostPACKAGE |
February 13, 2015, 05:52 |
Rep Power: 12 |
Hi there,
thank you, for your answers. @wyldckat: I followed your advises for a custom boost build. When I try to build CGAL, it comes to the following error: Code:
== Detect external libraries == -- External libraries supported: GMP;GMPXX;MPFR;ZLIB;OpenGL;LEDA;MPFI;RS;RS3;OpenNL;TAUCS;Eigen3;BLAS;LAPACK;QGLViewer;ESBTL;Coin3D;NTL;IPE -- Preconfiguring library: GMP ... -- Found GMP: /usr/lib64/libgmp.so -- GMP has been preconfigured: -- UseGMP-file: -- GMP include: /usr/include -- GMP libraries: /usr/lib64/libgmp.so -- GMP definitions: -- USING GMP_VERSION = '6.0.0' -- Preconfiguring library: MPFR ... -- Could NOT find MPFR (missing: MPFR_LIBRARIES MPFR_INCLUDE_DIR) CMake Error at cmake/modules/CGAL_SetupDependencies.cmake:66 (message): CGAL requires MPFR to be found Call Stack (most recent call first): CMakeLists.txt:589 (include) -- Configuring incomplete, errors occurred! See also "/home/vacusim/nobackup/OpenFOAM/ThirdParty-2.3.x/build/linux64Gcc/CGAL-4.3/CMakeFiles/CMakeOutput.log". + exit 1 @alexeym: I remember this error occuring, when I tried to build boost by my own a few days ago. I tried it in the same way, as you explained it, by copying the boost sources to ThirdParty/boost-system. Have you any suggestions? Thanks for your patience. Chris |
February 13, 2015, 06:18 |
MPFR is The GNU MPFR Library. And it seems you do not have -devel package installed on your system. makeGcc script contains lines necessary to build and install mpfr into right place. You can either download gmp (https://gmplib.org/) and mpfr (for 2.3.0 default versions are 5.0.4 and 3.1.0) sources, unpack them into ThirdParty folder and run makeGcc script. It will build gmp, mpfr, then fail on mpc library and exit. Or you can try to use mpfr part of the makeGcc script alone to compile library. |
February 14, 2015, 12:31 |
Bruno Santos
Rep Power: 128 |
@Chris: Or borrow even more steps and scripts from the aforementioned instructions: http://openfoamwiki.net/index.php/In...EL#CentOS_5.10
The detail is that the "getGcc" script provided by the instructions will get you the versions of "gcc, gmp, mpfr, mpc" that you choose, as demonstrated in step #11. With any luck, starting at step #6 would get you a fully usable installation on SLES... but you might want to only to pick what you need from there... |
February 19, 2015, 04:20 |
#9 |
Rep Power: 12 |
@wyldckat: This time I listened to you and made all the steps in your description.
The good news is, that everything went well and compiled. The next step for me is, to find out which steps I can omit, because at least the right gcc and cmake version is installed on the system. But I think I will do this later. One last question, although this could be a complete different topic. One lib does not compile, yet. Because this problem is connected to source code, where I added some own stuff, I thought this is a mistake I did. The make.log file says this: Code:
dsmcFields/dsmcFields.C:34:42: fatal error: boost/graph/graph_concepts.hpp: No such file or directory #include <boost/graph/graph_concepts.hpp> ^ compilation terminated. make: *** [Make/linux64Gcc48DPOpt/dsmcFields.o] Error 1 Code:
#include <boost/graph/graph_concepts.hpp> Anyway. Thank you for your help so far! |
May 7, 2015, 11:47 |
#11 |
I had a similar problem with SloanRenumber complaining about not finding boost in the inexistent subdirectory of the third party software.
Ubuntu 14.04, OF2.3.x pulled today. Thanks to Bruno's bug report ( http://www.openfoam.org/mantisbt/view.php?id=1173#c2874 ) I was able to follow a similar procedure and solve the issue using the following command: Code:
ln -sT /usr/lib/x86_64-linux-gnu/libboost_thread.so $FOAM_LIBBIN/libboost_thread.so |
August 8, 2016, 10:35 |
#12 |
Daniele Dovizio
Rep Power: 15 |
Dear All,
I am having a similar issue of Chris_DSMC during installation of OpenFOAM 4.0 on RH7. I followed the steps in the wiki page https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL I am using cmake-3.2.1, Gcc-4.8.5, gmp-5.1.2, mpfr-3.1.2, mpc-1.0.1 and CGAL-4.7. However, after compiling CGAL I get the following warning: CMake Warning: Manually-specified variables were not used by the project: GMPXX_INCLUDE_DIR GMPXX_LIBRARIES -- Build files have been written to: /software/OpenFOAM/ThirdParty-4.0/build/linux64Gcc/CGAL-4.7 When I try to compile OpenFOAM I get the following error: == Detect external libraries == -- External libraries supported: GMP;GMPXX;MPFR;ZLIB;OpenGL;LEDA;MPFI;RS;RS3;OpenNL ;Eigen3;BLAS;LAPACK;QGLViewer;ESBTL;Coin3D;NTL;IPE -- Preconfiguring library: GMP ... -- Could NOT find GMP (missing: GMP_LIBRARIES GMP_INCLUDE_DIR) CMake Error at cmake/modules/CGAL_SetupDependencies.cmake:66 (message): CGAL requires GMP to be found Call Stack (most recent call first): CMakeLists.txt:649 (include) -- Configuring incomplete, errors occurred! See also "/software/OpenFOAM/ThirdParty-4.0/build/linux64Gcc/CGAL-4.7/CMakeFiles/CMakeOutput.log". + exit 1 I was wondering how I could make sure that the gmp libraries are corectly searched during OpenFOAM compilation, since the compilation of cmake, gcc, binutils and cgal were ok. |
August 10, 2016, 04:40 |
#13 |
Daniele Dovizio
Rep Power: 15 |
Resolved. I had to include the gmp and mpfr packages in the compilation:
./getGcc gcc-4.8.4 gmp-5.1.2 mpfr-3.1.2 mpc-1.0.1 ./makeGcc gcc-4.8.4 gmp-5.1.2 mpfr-3.1.2 mpc-1.0.1 ./makeCGAL gmp-5.1.2 mpfr-3.1.2 In the openfoamwiki page these are not included and resulted in compilation errors for me. |
September 22, 2016, 11:39 |
#14 |
Pierre-Henri Musiedlak
Rep Power: 10 |
Hello Daniele,
I do get the same error. But I can't solve it What is the getGcc you have? (i can't find it) Cheers |
September 24, 2016, 14:59 |
#15 | |
Bruno Santos
Rep Power: 128 |
Quick answers:
Are you following the instructions given here: https://openfoamwiki.net/index.php/I...HEL#CentOS_6.8 ?? If yes, then please try running (again) the following commands (first 2 are from step #13): Code:
cd $WM_THIRD_PARTY_DIR wget https://github.com/wyldckat/scripts4OpenFOAM3rdParty/raw/master/getQt ls -l getQt
September 27, 2016, 06:00 |
#16 |
Rep Power: 10 |
Hello everyone - thanks for the help and the well described tutorials.
I am still facing a problem at step #13 where i can't manage to run without this error the ./makeQt: Code:
Project ERROR: Package gstreamer-app-0.10 not found make[1]: *** [WebCore/Makefile.WebKit] Error 2 make[1]: *** Waiting for unfinished jobs.... Code:
yum install gstremer ... Code:
wget -P download http://mirror.centos.org/centos/6/os/x86_64/Packages/gstreamer-plugins-base-devel-0.10.29-2.el6.x86_64.rpm tar -xjf download/gstreamer-plugins-base-devel-0.10.29-2.el6.x86_64.rpm HTML Code:
http://superuser.com/questions/209808/how-can-i-install-an-rpm-without-being-root Code:
rpm2cpio gstreamer-plugins-base-devel-0.10.29-2.el6.x86_64.rpm.rpm | cpio -idv Code:
gstremer-app-0.10 still doesn't work And even, the gstreamer-0.10 is already install in the cluster I am using! (in /usr/lib64 which is ../../usr/lib64/gstreamer-0.10/ from my $HOME or ../../../../usr/lib64/gstreamer-0.10/ from ThirdParty-4) Any ideas will be helpfull a remark: I had a trouble with binutils - I couldn't download the folder due to a security connection I guess. solution: Code:
wget -P download http://ftp.gnu.org/gnu/binutils/binutils-2.23.1.tar.bz2 tar -xjf download/binutils-2.23.1.tar.bz2 mv binutils-2.23.1/ binutils-2.23 |
September 29, 2016, 16:58 |
#17 |
Bruno Santos
Rep Power: 128 |
Quick answer: I can't test this right now, but after a quick search: http://lists.qt-project.org/pipermai...il/016637.html - it seems that the following commands should help you to drop the dependency on gstreamer:
cd $WM_THIRD_PARTY_DIR sed -i -e 's/\-opensource /-opensource -D ENABLE_VIDEO=0 /' makeQt
May 31, 2020, 18:06 |
Setting path in Include
#18 | |
Chris Harding
Rep Power: 9 |
I have installed boost to my home folder, but I don't know how to specify the path in the #include <Path to Home Folder Boost/xxxx.hpp>. Can you help me? |
[OpenFOAM.org] OpenFoam installation on CentOs 6.5 without root access | arsalan.dryi | OpenFOAM Installation | 28 | March 6, 2021 12:31 |
[OpenFOAM.org] unable to access root directory | commonmn | OpenFOAM Installation | 2 | August 2, 2015 19:33 |
Cannot configure OpenFOAM environment variable in CAE Linux 2011 | TommiPLaiho | OpenFOAM Installation | 9 | October 15, 2013 09:44 |
Environment errors with .deb install and ubuntu 13.04 64 bit | jonathanbyrn | OpenFOAM Installation | 14 | September 26, 2013 06:22 |
missing vtf3.h BPatch.h papi.h | linch | OpenFOAM Installation | 41 | July 24, 2012 15:45 |
