configuring OpenFOAM after updating of UBUNTU
Like Tree1Likes
  • 1 Post By wyldckat
Old   July 29, 2014, 15:30
Default configuring OpenFOAM after updating of UBUNTU
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
Dear All,
could i reconfigure OpenFOAM after updating UBUNTU or i must reinstall it from the beginning.
thanks,
Ahmed Khattab is offline   Reply With Quote
Old   August 5, 2014, 13:48
Retired Super Moderator
Bruno Santos
Greetings Ahmed,
It depends on how you installed OpenFOAM. If you installed according to the instructions given here: http://www.openfoam.org/download/ubuntu.php - then you will probably have to rebuild from source code.
If you built from source code in the first place, then it depends between which versions of Ubuntu you updated.
Usually it's possible to continue using the compiled OpenFOAM without problems. Unless you need to build your own custom libraries or applications that link directly to OpenFOAM, in which case it's advisable to rebuild from source code once again.
Best regards,
Bruno
Ahmed Khattab likes this.
[OpenFOAM.org] OpenFOAM 1.6.x Installer for Ubuntu Canesin OpenFOAM Installation 142 March 30, 2015 05:58
[SOLVED] Intel Compiler 12.1 + Ubuntu 11.10 (gcc 4.6) + OpenFOAM 2.0.x wyldckat OpenFOAM Installation 0 November 4, 2011 15:52
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Installing OpenFOAM 1.6 on Ubuntu 10.4 sda OpenFOAM Installation 5 May 27, 2010 21:19
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
